Copiers
Problem for Copiers
Generic problem for all Copiers
Ricoh Aficio340
By quilt on Mar 29, 2008
What is this code and how do we clear the open door symbol and the tool symbol so that the copier will start up?
Comment by quilt, posted on Mar 28, 2008 The copier is a Ricoh Aficio 340 and the screen said SC 547 00
We can't use your Premium Assistance plan. We don't have a credit card and live 100's of miles from shops etc.
Hope you can help, thanks
Solution #1
posted on Sep 14, 2009
Not Rated)
delfortomac
Rank: Guru
Rating: 95%, 17 votes
SC547 - Zero cross signal malfunction
Zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
- Possible causes -
· Power supply board defective
· Noise on the ac power line
Open door
Check the fuse FU1 y FU2 in the power supply board FU1 display open door Without saying as. But it would have to review all the fuses.
Comments:
- The flat cable of the laser also can cause the fault of open door, cut or badly connected this also it can be indicate door opened without indicating as. But all the problem seems to come from the power supply...
Good luck...
Comments:
Oct 27, 2009
- - Check the fuse FU1 y FU2 in the power supply board FU1 display open door Without saying as.
Comments: Aug 22, 2009 - The flat cable of the laser also can cause the fault of open door,
El cable plano del laser cortado o mal conectado, tambien puede provocar la falla de puerta abierta sin indicar cual de ellas está abierta.
Oct 18, 2009 - For that they visit this post… nothing costs to be thankful…
Was this helpful?
Yes
No
Solution #2
posted on Mar 29, 2008
Not Rated)
TheMacGyver
Rank: Guru
Rating: 92%, 168 votes
Well, you sound like you figured out part of your problem. If the open door symbol is showing, then you need to find out which door the machine thinks its still open.
Check all the doors, front, both right and left doors, and if the machine has a bottom console, then check those doors also.
I would open every door and reclose them again and see if you can get the DOOR OPEN symbol to go away. Need to start with the basic first.
Once this is cleared then we can see if we can troubleshoot any other problems.
(Most doors have a little stub that sticks out that either goes in between a sensor, or pushes on a switch to tell the machine that the door is closed.
If after opening and closing each door, and the machine still says Door open, then Next step I would take is to see if there are any places on the door that looks like a small piece of plastic might have broken off.
Let me know what you find.
Good luck.
Mac
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
i want the coast of canon xerox machine modle no 3300
Answer
I was laminating and the pouch got stuck. Is there a way to unjam the laminator?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repairmen
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
