Question about Philips Magnavox DVD/VCR Dual Player
VHS to DVD - D-VR4XSU
When I try to dub "home made" VHS tapes to DVD-R, after about 30 minutes of copying I receive the message "Cannot record, protected image". I have tried different home-made VHS tapes and even different DVD-R manufactures but I always get the "Cannot record, protected image" message after 15-30 minutes. NOTE: The "auto chapter" is turned off because I thought that maybe it was causing the error message but it wasn't. Any suggestions are greatly appreciated ..... theallde I have magnavox model mwr20v6 after dubbing for about 2 mins a message comes up that says this program is not allowed to record and it is a vhs that I recorded of a dance
  • 1 more comment
  • buster baby Apr 01, 2008
    I also have the same problem. Tried another VCR run through the front input connectors, but that had the same result.
    It worked fine when I recorded directly from a video recorder.
  • Anonymous Apr 01, 2008
    I would love know how to get a manual I have tried that also but when I go to down load it shows the front page and than says file damaged could not be repaired by adobe
  • Anonymous Apr 24, 2008
    I can't record a home VHS to DVD with the D-VR4XSU if there are gaps in the recording. I can't get it to add more to the DVD once it stops at the gap. Can't finalize and unfinalize to get it going again even with the DVD-RW disks.
I can't record a home VHS on the D-VR4XSU if there are gaps in between recordings. It stops and I can't get it started again.
Shadow Prohet
Posted on Apr 24, 2008
    Problem Solver:
  • 15 Answers
Have u tried the seting on the vcr, you know how u can change the lenght of recording on the vhs
Posted on Mar 29, 2008
SOURCE:
VHS to DVD-R
You say "home made" - not sure what you mean by that. If it was a copy of something that was originally retail, it's possible the Macrovision encoding copied over with it - in which case your DVD recorder is working as it's supposed to to prevent illegal copying of disks. I'm a bit wary of getting into this in any depth, as it treads the lines of legality. If I found a way for you to bypass this copy protection, it would allow you to pirate movies freely. I'm not going to discuss my own feelings on that, but I will say that I'm not going to support such actions on a public forum. That being said, if for some reason your totally legitimate home made tape managed to get something that's being interpreted as Macrovision coding on it, you may want to do a google search for digital video stabilizer. That will point you in the right direction.
Aug 12, 2007 | Toshiba DR4 DVD Recorder
Hi I am trying to dub from a VHS tape to a DVD+RW disc and I get an error message "CAN NOT DUB WITH THIS DISC" I have tryed different disc and different brands and I still get the error message?...
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Jan 14, 2011 | JVC DR-MX1 DVD Recorder/VCR
Copy from vhs to dvd- want to speed process ???
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
Nov 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Recording dvd's
As long as the tapes do not have a copy gaurd on them they should record to the dvd. Home moves, tv shows that were recorded or unprotected tapes can also be dubbed.
Jan 23, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia IS-DVD100121
thisCD recorder wont DUB COPY PROTECTED MATERIALS (COPY RIGHTED) AS IT WILL RECORD HOMEMADE VIDEO FROM A VIDEO CAMERA BUT NOT FROM A STORE BOUGHT TAPE AS THEy ARE COPY PROTECTED.
Dec 31, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Philips Magnavox DVD/VCR Dual Player Logo
398 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
