Question about Dishwashers
My dishwasher will start any cycle then half way
My Hotpoint dishwasher will start any cycle then half way through rinse turns itself to delicate with both rinse aid and salt lights flashing
  • 619 Answers
The touch pad has gone bad. Common problem with the GE made dishwashers.
Posted on May 12, 2010
Samsung dishwasher dmt 300rfb wont drain and is humming
Hello Randy Lowe,
There is an EXPECTED INITIAL failure period
on new equipment...!!
Use your warranty...
Brand new = Take it back & get a GOOD ONE.
Carnac the Magnificent
Apr 22, 2017 | Samsung DMT300RFS Builtin Dishwasher
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
I have an hda3400go2ww, and it's leaving soap scum and food on the dishes after a wash and rinse cycle. What do I do?
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Oct 25, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Cycles are off
if you can pull knob off make sure shaft is not cracked inside if thats alright take screws out of dishwasher down the sides and around console to access timer make sure timer mounts are not broken
Sep 08, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint dwt10 not working rinse aid light flashing
I have DWT10P dishwasher.It is displaying two rapidly fashing E lights (Fast & Delicate )wash cycle.Can you tell me what its mean?
Mar 24, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Hotpoint NVL333EYOWW mfg 9/99
I encountered the same problem. Turned out to be a blown thermostat, caused by too much moisture from the washer not spinning the delicate cycle enough and / or oversized dryer loads. Cut your load sizes in half and avoid using delicate cycles for cotton items. Very easy fix, Prices in the Midwest range from 30 to 40 USD. Godspeed.
Apr 13, 2008 | Hotpoint NVL333EY Electric Dryer
HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Mar 18, 2008 | Hotpoint 24 in. FDW60 Free-standing...
FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Mar 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Not rinsing or drying
This appliance should be on warranty; call seller.
Nov 06, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius dishwasher
Oversudsing
This can be due to using a laundry or handwash detergent instead of a specific dishwasher detergent instead. It could also be due to excessive amounts of rinse aid in the dispenser or certain food soils that contain a high level of protein such as eggs.
Oct 08, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
194 people viewed this question
Top Dishwashers Experts
