Question about Intermatic T8845PV - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA 3R
My intermatic controller only works manually?
    Guru:
  • 351 Answers
That is a 120 volt timer with a 24 volt output .. if the valves are being activated manually but the clock wheel is not turning to select the zones automatically, first check the wheel . it can become hung up when setting the time, and not be set on its spindlle so it can rotate with the clock motor. If the clock wheel is set and still does not turn, then the clock may be bad
Please vote !!
Posted on May 12, 2010
  • Rich May 12, 2010
    Oh ya .. that switch is an ON / OFF / AUTO .. so make sure you are in AUTO
    Please vote !!
Where are the fuses located on the t40004r
http://waterheatertimer.org/Intermatic-control-centers-and-manuals.html#T40000
http://waterheatertimer.org/How-to-wire-Intermatic-control-centers.html
Breakers are usually located in the control panel
Push breaker fully OFF and then fully on
Check that breaker voltage is same as motor... for example if breaker is supplying 240V to pump, but pup is set up for 120Volt, then pump will not work.
Use override switch on timer to see if you can manually start the pump
Check that timer dial rotates ... 1 full turn for each 24 hours
Gene
Sep 01, 2014 | Intermatic T40004R - Pool-Spa Control...
Where are the fuses located?
Open door on control center, and push breakers fully off and then fully on
Use manual override lever located on each timer to see if pump can be manually operated
Gene
Manual for intermatic timer part no. 2T511GA
2T511GA is an Intermatic enclosure (or box)
2T511GA is a grey standard Indoor/Outdoor Nema3R metal enclosure.
http://waterheatertimer.org/pdf/Intermatic-Enclosures.pdf
Any intermatic box timer will fit into the enclosure.
Tork makes the IAP adapter so Tork/ GE timers will also fit into same enclosure.
This includes digital timer and analog timers made by both companies.
To find the exact manual, add a comment and describe the timer and number of terminals, and what voltage is being used, and what you are controlling with the timer. For example 6 screw terminals A 1 2 3 4 and controlling 2-speed 240 pool pump. etc.
Also copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Aug 16, 2012 | Intermatic Hardware & Accessories
My EJ35IC timer seems to be preprogrammed, and i cannot erase it. can you help? thank you
There is no repair for defective timer.
Unknown if this is new timer, or timer that worked before and stopped working.
Add a comment any time.
Try resetting timer using instructions from manual: Move control lever to OFF-CLEAR position for about 20 seconds. Red indicator light will go off, and all previous programming will be cleared.
Then move control lever to ON position and red indicator will start flashing. Reprogram timer.
If functionality is not restored, then timer might be defective.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Timer has 1 year limited warranty fro Intermatic:
http://www.intermatic.com/customer%20service.aspx
Resources:
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 18, 2011 | Intermatic Programmable 24 Wall Switch...
I can't download the instruction manual from Intermatic's website. I have a EJ500C timer and want to know why they caution against using it with CFL's and how to program it to shut off...
EJ500 7-day or astronomic timer is incandescent light bulb timer.
Different timers have different Load ratings.
Intermatic ST01C timer can control CFLs.
Aube timers have same wiring capability as Intermatic, and offer CLF control, but you have to choose either astronomic timer, or 7-day timer.
Open following links for manual and timer information.
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
http://waterheatertimer.org/Aube-timers.html
Jul 16, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
I have an Intermatic E1020 timer and the manual control does not work consistently. The timer will turn the appliance on and off automatically but I cannot get the manual control to work. Please help!
If timer dial is rotating and keeping good time, then clock motor is good, and wiring is correct.
If timer turns the load on-off, then set of 156EB945A trippers are good.
http://waterheatertimer.org/pdf/Intermatic-e1020-english.pdf
I believe the manual control button reverses the program.
So if timer is ON, and manual is pushed, then timer turns OFF, and timer resumes programming at next tripper.
So the manual override is not an on-off switch.
All plug-in timers work same way, and most of the hardwire timers and in-wall timers.
The exception is the analog GE 15070, Woods 59017, Tork 701A, Intermatic E1120, Intermatic KM2 series. These timers have a true on-and-off switch that slides back and forth.
http://waterheatertimer.org/Programmable.html#15070
http://waterheatertimer.org/images/GE-15070-mechanical-timer.jpg
Add a comment for more help.
Upvote the help.
Jun 06, 2011 | Hardware & Accessories
I need timer motor for paragon mod# 7007-00
1) Open following link for Paragon timers and manuals:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
2) 7007-00 is 4PST timer with 120Volt clock motor.
3) M3099-00 120Volt clock motor for 7000 series is available at Invensys for $32.24
http://www.energyequipment.com/p-88069-invensys-climate-controls-m3099-00.aspx
3 to 4 weeks lead time.
4) Intermatic replacement is T7401B
40 amp 7-day timer with 125 volt clock motor, 4 independent loads, each load turns on-off at same time
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7401b%20-%20english.ashx
Intermatic at 1000 bulbs 135.52
http://www.1000bulbs.com/product/3377/ELEC-T7401B.html
Intermatic Amazon 122.00
http://www.amazon.com/Intermatic-T7401B-7-Day-Switch-Steel/dp/B000GHN9JG
5) If you want 30 amp electronic timer with 4 independent programmable circuits that can turn on-and-off with different schedules, then Intermatic ET70415CR for $700+
Upvote the help.
May 10, 2011 | Hardware & Accessories
After entering pulse secs it shows error 1C
You posted under Intermatic ET70215CR timer.
Best source of information about this product is 1) Manual and 2) Intermatic.
1) Manual: Click product number to download manual
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
a) ET70215CR Manual search for 1C shows following: ERR 1C One or more of the selected circuits has a program conflict.
-For example: program 1 says ON 8pm Tuesday, OFF 9pm Tuesday, but program 2 says opposite.
-Another example: program 1 says ON 8pm Tuesday, OFF 9pm All days of week
b) Manual also says: NOTE: Error messages are subject to change with later software revisions.
2) Intermatic customer service:
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 14, 2011 | Intermatic ET70215CR Electronic Energy...
I am installing an intermatic t104m with firemans switch.I hooked up the switch to the pool heater and no power to heater?
Add a comment and provide more information.
A lot of factors need to be narrowed down.
Did everything work fine before connecting fireman burn-out protection switch?
What happens when you disconnect switch?
Is the timer rotating?
Does the manual override work?
Is this a new installation?
This sounds like a dual T-104 pool timer that controls more than the heater, what else is controlled, and do the other Loads work correctly?
Nov 19, 2010 | Intermatic HEATER DELAY SHUT OFF SWITCH...
My intermatic works in manual position but it doesn't work on auto.isbrand new
You posted under Intermatic mechanical dial timer
Open following link for troubleshooting Intermatic timer.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Sounds like your timer is wired wrong.
Maybe wires coming from breaker are reversed with wires going to load
Add a comment with model number of timer for exact wiring help. And say what load(s) you are controlling, what voltage, and what color wires.
Also take advantage of fixya expert assistance live.
Jul 19, 2010 | Intermatic R8806P101C -...
Intermatic T8845PV - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA 3R Logo
397 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
