Question about Keurig B60 Coffee Maker
Where would I get the rubber that comes down on top of the k cup
    Champion:
  • 213 Answers
Give me about an hour and I will have it listed for you here; http://iwantsweetdeals.com/
Posted on Jun 14, 2010
When i use my reusable k cup, water comes out all over
Use the $15 reusable Kcup with a rubber seal ring. If the lid is not down and sealed it will over flow with grinds. Press down firmly after filling with grinds. Also, clean tubes Top/Bottom with a paper clip to free them from debris that clog the tubes. Use distilled water also.
Jan 07, 2014 | Keurig Coffee Makers & Espresso Machines
I have a K10 mini cup keurig brewer. It worked fine until this morning. When I try to brew a cup, it comes out the top. It does with this with or without a k-cup in. I tried to clean out the needles...
First: You need to check a Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
Second: Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 27, 2013 | Keurig Coffee Makers & Espresso Machines
I need some rubber cup for grabber?
There are small clear colored rubber cups that are approx the same size as the rubber grabbers that are used to old things like small stained glass sun catchers on winders there usage is to be a rubber suction cup. These can be used with perhaps a small amount of alterations like you might have to snip off the part that comes down with the small hole in it to hold the metal hook that holds the suncatcher and you will have to drill a hole into the top part to attacj it to the grabber. Just find a screw that fits if you don't have the original.
Apr 11, 2011 | Ontel Products GOP2-MC18/6 Gopher 2 Pick...
I have ahd problems with clutch, checked master cylinder reservoir and there is a small rubber cup on top that seems low. I have filled this and it makes the clutch better for a short time. Top fill this,...
yes, the rubber cup is suppose to be attached to the bottom of the cap and should come off the reservoir with the cap, we see this all the time the caps are not made very well.
Feb 21, 2011 | 2007 Dodge Ram 3500 Quad Cab Laramie
Special Edition B60 Coffee Maker: Coffee grounds coming up through the k cup???...
make sure the k-cup is being punctured at the bottom... If the answer is YES... then take the K-cup holder out of the Keurig unit... verify you can put a paperclip into the needle of that piece from the inside of the shell and it comes out the bottom
that shell is actually 2 pieces and unsnaps... making it earier for you to check... once we know there is no obstruction in the bottom needle, then we need to make sure the rubber gasket in the top arm is ok... didnt come off..
the top needle that punches a hole in the k-cup, has a round rubber seal around it..
If it's not there, then it got stuck on the top of a k-cup, and you need to search the garbage for it...
in summary
clogged bottom needle
missing rubber top seal
If the rubber seal is there... hmm. while your making coffee next time....press down on the top arm... just enough to see if the ground stop... id that's the case, then we need to step back and think if we are dealing with either a bad seal, or a fatigued top arm..
My hunch is a bad seal... and possibly try to attempt to reseat it back into the arm... it cound be smashed in and needs to be coaxed back out..
May 06, 2010 | Keurig Special Edition B60 Coffee Maker
Coffee grounds in the cup
since you said usually... I suspect the rubber seal that surrounds the top needle is not seating well...
you can verify this by making a beverage with a k-cup and, just before the water starts, add a little hand pressure to the K-cup arm pushing down a little bit... not hard...
If it consistently makes a good beverage, then we focus our attention to that piece of the brewer...
when the consistency of the water changes, it tells me to look for leaks or unusual percolation of water...
you can verify the K-cup holder is ok... but another way to simulate the hand pressure is to put a shim of some sorts under the lip of the k-cup... like the thickness of a couple sheets of paper under the rim... not the actual k-cup... but the k-cup holder... raising it up a smidge is the same as the slight hand pressure...
I would look to see if the rubber seal has come loose around the top needle....
May 04, 2010 | Keurig Platinum B70 Coffee Maker
Coffee won't pass through pod
the K-cup is punctured at the top and at the bottom.
you can take a corkscrew, and puncture a number of holes in the bottom of the K-Cup... verify there is a hole at the top... just before you start to brew... press down on the black arm over the cup... but not too hard...Lets see what happens... if it all looks good... no problems... then we need to either adjust the arm... or shim the k-Cup up a little bit...
you may also check the rubber Seal around the top pin that punctures the K-cup...
sounds like you lost your rubber seal around the top of the K-cup...
you can re-phrase after looking and testing....
Apr 28, 2010 | Keurig B60 Coffee Maker
Leaking water when using my k cup
Long story short, it will leak from under the screw cap (rarely) and from the rubber ring around the puncture pin. The grounds clog the metal filter and creates pressure that escapes from under that rubber ring. I cut a thin styrofoam plate to fit under the screw cap. It's really snug for the first few times, then it will loosen up. Second is to tighten the seal between the top of the 'my cup' and that rubber seal. I used 2 styrofoam rings that sit between the 'my cup' and the hard plastic it sits on when you fit it in the hole. It bring the cup like 1/8 inch higher to the pin and increases that seal. I made many cups after that and it has never leaked. I'm looking for a good rubber ring to fit around the 'my cup' to replace the rings for the seat.
Apr 10, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
K-Cups disappointing
I had same problem and called Keurig. They advised me that the gasket in the upper portion, where the top needle is needs to be brought down about half way, almost even with the bottom of the top needle. Be careful not to poke yourself. I brewed a cup with the resuable filter assembly and it worked great. It should stay in that position until you use an actual k-cup. When using it will push the gasket back up, as it needs pressure to puncture the hole. To go back to the resuable filter, you will need to lower the gasket again. She advised me that they are working on a fix for this issue and will notify you of any replacement parts, as long as they have your current contact info.
Feb 06, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
When I installed my delta replacement cartridges, RP1740 two handeled faucet, the water will not turn off no matter which way I turn the handle. I have a new rubber cup and spring. It looks so easy, I must...
Sounds like you might have the rubber cup seals installed upside down? The spring goes int he body first, then the cup seal goes over and on top of the spring.
Jun 25, 2009 | Delta Plumbing
Keurig B60 Coffee Maker Logo
51 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
