Philps HDTV Hi, I got my hands on a hi voltage probe and meter. there is still hi voltage coming out of the flyback. What else do you think may be wrong with the TV?
  • 8,617 Answers
It could possibly be something in the deflection circuits. Exactly what are the symptoms when you try to power up the set? Have you tried to see if you can locate the Chassis number of your set, As a philips/magnavox is almost impossible to diagnose without that chassis number as all service info is crossed by chassis number.
Posted on Mar 29, 2008
Sony KP-57WV700
Hi. It seems that the g2 voltage of the picture tube is too high, resulting in a white screen, often with white horizontal lines. The g2 (= second grid) voltage is derived from the flyback high voltage. The voltage divider is mostly integrated in the flyback trafo housing.(including the adjustment knobs). A failure in this divider may lead to this defect. The static you hear may come from sparking in the divider. The flyback trafo is soldered onto the main printed cirrcuit board. Sometimes, one of the pins sits loose in the soldering pads.
Turn on the set and observe for any sparking around the entire flyback circuitry, and, or the flyback trafo itself
The screen turns black after a while, as a too high beamcurrent is detected. The set disables the flyback. Stand-by blinks meaning that there is a fault condition.
Be carefull with the high voltages. The flyback voltage is very high (20-30 Kilovolts !) and may be lethal !!
Jul 02, 2012 | Sony KP-57WV600 57" Rear Projection...
I TURN ON MY TV AND THERE IS NO PICTURE AND THE RED LIGHT IS BLINKING
is there (audio) sound?........dont know make or model but more likely in the high voltage section,flyback,transistor,fuse...have to have the proper testing equipment to check it =.......ohm meter,voltage probe,exc
Feb 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HOW DO I CHECK VOLTAGE WITH A FLUKE METER?
User guide is here http://us.fluke.com/usen/Support/Manuals/default.htm?pid=37115
Includes info on how to measure voltage. For lower voltages it is simply a matter of selecting voltage measurement and putting the probes across the voltage (i.e. on each terminal of a 9v battery). For much higher voltages you may need special probes that effectively step down the voltage by a factor.
If this helps please leave feedback, if not let me know and I'll trya nd help some more!
Jan 26, 2010 | Fluke Networks Fluke T+PRO Electrical...
Panasonic pt-47wx53g horizontal outout transitor short whit new transistor flyback voltage are all to low the tv does notlight up the crt
Hello oncle_jc,
You may have a problem with your flyback transformer, I would suggest that you perform a ring test to see if any of your windings on the flyback are shorted. In addition You may want to also check the input to the Horizontal Output Transistor, to see if the driver pulses are of the proper amplitude. Besides these two things the only other issue colud the the high voltage trippler (if this is not part of the flyback). Check these things, you will need the following equipment:
1) oscilloscope
2) voltmeter (multimeter set to DC volts)
3) High Voltage probe
4) A test set that can perform a ring test (My shop uses the Sencore LC102)
Or what you can do is take the flyback out and take it to a TV shop and for a small fee they can run the test for you, (My shop usually charges $20.00 - $30.00 for this
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 24, 2009 | Panasonic PT-47WX53 47" Rear Projection...
8 Flashes, Changed Flyback... still no good.
Try the High Voltage block first. Very common failure.
Jan 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
RCA d52w20 will not come on
sounds likje the flyback those sets are famous for the flybacks needing replacement.They dont always blink 3 times when the flyback fails, often they justrefuse to power up.
Sep 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KP-53Hs30 projector tv
you will need two STK392-560 Convergence ICs and possibly a couple 3.5amp pico fuses. also if the small wire borke off inside the flyback you will need to replace the flyback as thats the wire for the focus control block. You can get the replacement parts at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 21, 2008 | Sony KP-53HS30 53" Rear Projection...
Zenith
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 10, 2008 | Zenith R49W36 49" Rear Projection HDTV
No picture no sound
First check to see if you have any voltage at test points with a digital meter.
You may need a repair manual for this.
Since you hear some noise your main fuse is ok.
Try checking this tp voltages first.
BE CAREFUL, wear gloves
Feb 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
Picture is to dark
On the CRT PCB, there is a ceramic capacitor attached to the screen voltage circuit. Disconnect it and the voltage may come up. If it does, replace it. check your 200 volt line and see where it is, also. If this doesn't help, let me know.
Jan 13, 2007 | Samsung TXK3276 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
