Question about Dell Dimension 8300 PC Desktop
How can I change the fan inside my computer? It's making too much noises
  • 540 Answers
  1. Shut down the computer through the Start menu.
  2. Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
How can I change the fan inside my computer? - notice.gif NOTICE: To disconnect a network cable, first unplug the cable from your computer and then unplug it from the network wall jack.
  1. Disconnect any telephone or telecommunication lines from the computer.
  2. Disconnect your computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before opening the cover. How can I change the fan inside my computer? - notice.gif> notice.gif NOTICE: Ensure that sufficient space exists to support the open cover—at least 30 cm (1 ft) of desk top space.
  1. Lay the computer on its side so that the arrow on the bottom of the computer points up.
  2. Open the cover:
    1. Facing the back of the computer, press the release button on the right side of the computer with one hand while pulling up on the top of the cover with the other hand.
    1. Press the release button on the left side of the computer with one hand while pulling up on the top of the cover with the other hand.
    2. Hold the bottom of the computer with one hand, and then pull open thHow can I change the fan inside my computer? - cvrop5.jpgwith the other hand.
  2. Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automHow can I change the fan inside my computer? - notice.gifurn off when you shut down your computer, turn them off now.
  2. Disconnect your computerHow can I change the fan inside my computer? - caution.gifattached devices from their electrical outlets, and then press the power button to ground the system board.
caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before you open the coverHow can I change the fan inside my computer? - notice.gif
  1. Open the computer cover.
notice.gif NOTICE: Before touching anything inside your computer, ground yourself by touching an unpainted metal surface, such as the metal at the back of the computer. While you work, periodically touch an unpainted metal surface to dissipate any static electricity that could harm internal components.
  1. Disconnect the cooling fan power cable from the FAN2 connector on the system board.
  2. Disconnect thHow can I change the fan inside my computer? - mprcsr6.jpgle from the PWR connector on the system board.
  3. Lift up the airflow shroud.
caution.gif CAUTION: The heat sink can get vHow can I change the fan inside my computer? - mprcsr12.jpgng normal operation. Be sure that the heat sink has had sufficient time to cool before you touch it.
  1. Remove tHow can I change the fan inside my computer? - mprcsr17.jpg:
    1. Release the retention module clip by pressing in on the tab and lifting the retention module clip up.
    1. Pull the release lever out until the heat sink is released.
    2. Lift the heat sink away from the microprocessor.
notice.gif NOTICE: Lay the heat sink down with the thermal grease facing upward.
Posted on May 12, 2010
    Sergeant:
    Champion:
  • 357 Answers
Take it to your nearest computer repair facility if you have never done any repairs yourself.
I hope this helps.
Have a nice day.
Posted on Jun 01, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 255 Answers
There's a lot of nice information at this link- http://www.tomshardware.co.uk/forum/8781-28-replacement-case-dell-8300
Fan makes noise on my Dell Inspiron One 19
Usually there is a fan on the CPU heatsink and a fan in the power supply.
Open the case and turn on the computer and use a small timber stick and poke it into the CPU fan to stop it spinning and if the noise stops then this fan needs replacing.
If it is OK the the fan in the power supply is faulty. I recommend you replace the power supply because there are dangerous voltages inside this power supply.
Jul 31, 2012 | Dell Inspiron One 19 (884116044949) 185 in...
Honda pilot 2007 blower fan making noise blower fan was replaced once still making noise
Either its developed the same fault or the fan motor bearing has failed, needs greasing or, if there's a belt, the belt is slipping.
Feb 22, 2012 | 2008 Honda Pilot
Dell optiplex GX280 PC when power on system no noise with fan after one hour making loud noise . I changed the CPU fan , also same noise, and applied heat sink paste to CPU and heat sink same noise....
There probably is another fan, located inside the power-supply, that is making all the noise.
Borrow a stethoscope from a nurse or doctor, and listen to the noise, to pinpoint "where" on the computer that is the origin of the noise.
Jul 16, 2011 | Dell OptiPlex GX280 PC Desktop
My computer fan making loud noise ,why?
fans tend to make loud noise right before they stop working!!! check to make sure that there is no clump of dust inside affecting the spin of the blades
Dec 16, 2010 | HP (219426-001) Cooling Fan
My computer started making a loud noise that will not stop. I am not sure if it is the fan or hard drive. The computer seems to be working fine. Any idea what could be making the noise?
In order to confirm the problem.. first of all turn off the pc and unplug the power cable from the back of the pc.... get a Philips head screw driver and open the chasis.... plug in the power cable and see where are you getting the noise from .... there are three fans namely one on the processor, the other a cooling fan and the last would be inside the power supply.. if its inside the power supply nothing can be done ... if its the cooling fan noise .... try to clean the vents or the cooling fan with the help of the dry cloth and if its the processor fan then its a serious issue ....
Apr 12, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
One of my fans has started making noise, how much time do i have to replace it? Am I right in thinking that it making noise that it needs to be replaced?
fan noises are usually caused by worn out fans. but can be also caused by IDE/power cables hitting the fan blades. you will have to open up the computer to see where the noise comes from.
if it is a faulty fan, replace it sooner than later as it will get louder and louder. then stop making noise all together when the fan fails.
Dec 09, 2009 | Dell OptiPlex GX270 PC Desktop
Acer aspire4920 makes loud noise at start up
This could be caused by the harddrive. There might be a bad bearing or something. Please backup all your data. You will probably have to replace the hard drive sooner or later.
May 07, 2009 | E-Machines T6524 PC Desktop
Cpu fan noise problem
You should check and make sure the inside of your computer isn't dusty. Dust will wreak havok on fans and shorten their life. Plus it likes to build up between the fan and heatsink which will overheat your processor. Take the fan off and spin it with your fingers. I like to open the little sticker on the bottom and put some 3 in 1 oil to lubricate it. A smooth spinning fan is a happy computer. It also reduces noise that a dirty fan makes. Hope this helps you.
Sep 16, 2007 | Intel D915GAG Socket 775 Motherboard -...
Dell Dimension 8300 PC Desktop Logo
136 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
