Question about Casio G-Shock GW300CA-1V Wrist Watch
I have a G shock (4765) it is always 2 minutes fast ? even if I reset it why
I cannot set the time on this watch! Is a G Shock 4765 AWG-100...HELP!
If you will browse through my TIPS and TRICKS, you will find the link for all Casio watch manuals. Download yours and follow instructions.
Apr 26, 2011 | Casio G-Shock G510D-1AV Wrist Watch
Setting the DST on my Casio G-Shock... plus 4 minutes fast!
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 18, 2010 | Casio Watches
G Shock G-600 Reset
Dual batteries should be installed [+ to -][+ to -]. There may be a hard-to-read diagram that shows installation. You may have to take the watch to a jeweler to get things straightened out.
Apr 26, 2017 | Casio G-Shock G600-1AV Wrist Watch
I have an older large wall clock - model 88100. It is 2 minutes fast. I've replaced the battery but it still runs 2 minutes fast. Always the same amount. Any ideas? With an atomic clock it should be right...
If it is a radio controlled clock and it is consistently out, then the hands need re-setting. I have hand a similar experience with my watch, so I fully understand the problem.
You can adjust the hand settings by pressing the right buttons!
If you have the instructions, then refer to the to adjust the hands. If you do not have the instruction, then go to the makers web site and look for manuals download.
Jan 22, 2010 | Watches
How to reset the chronograph hand back to zero (12
you can find an exper in the local shop where you buy the product and they will give you specific service
for your questions about your product.
In addition, i like to play world of warcraft. there is a reliable website for
all players to get cheap wow gold with the lowest price wihit in
10 minutes' fast delivery and you also can enjoy first class service
for your login.
Jan 08, 2010 | Omega Speedmaster Day Date 3520.50.00...
I am having difficulty lately in syncing my G Shock
you can find an exper in the local shop where you buy the product and they will give you specific service for your questions about your product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to get world of warcraft gold with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service for your login.
Jan 06, 2010 | Casio G-Shock GW500A-1V Wrist Watch
Need to fix time on Casio G-Shock
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Apr 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Atomic watch is running to fast, how to i reset the seconds
do a manual receive procedure
if you don't have the manual here's the procedure:
1-place the watch near the window (try to be on a clear area), the watch must be stable and the 12 o'clock side facing the window
2- press the D button for 2s untill the watch beeps
3- release the D button a message RC will be displayed
4-it take from 2 to 5 min to the signal to be acquired
hope it helps
give feed back
Apr 03, 2009 | Casio G-Shock Atomic MTG930DA 8VCR watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
523 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
