Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Error code "p3" appears in the digital panel with a little tool diagram. The rinse cycle doesn't work..
    Guru:
  • 351 Answers
That code is for the booster . probably the thermistor .. if there is a hobart service center in your area, you could get one there and instructions on how to replace.
Please vote!
Posted on May 12, 2010
  • 65 Answers
P3 error code is OPEN OR SHORTED BOOSTER THERMISTOR
Posted on Dec 15, 2010
Hobart LX30H - p3 code and not heating
i dont know i would have to google it
Dec 18, 2017 | Washing Machines
What does a P3 code mean? On a Hobart LXI high temp
P3 code refers to the probe near the airgap at the back. It is monitoring the rinse temp. P2 is the booser probe, and P1 is the wash tank. The control board will store error codes, so once changed, you can access the memory and clear it.
Jan 05, 2014 | Dishwashers
F&P GWL11 Washer Stops at rinse - Error Code 37
I hate to say it but it sounds like the controller. I used to have one that had a similar problem that was fixed with a diverter and a controller. Another year or two later it was doing the same thing, so we just replaced it. Just a warning.
Jul 08, 2012 | Fisher and Paykel Washing Machines
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is the error code dS for Neptune Maytag Washer MAH8700AWW?
Please advise me on any recalls and technical information involving error code 3E during a wash load, which appears related to be a faulty control panel. My machine is always shutting down each time it reaches the rinse cycle. Numerous consumers have been complaining about this same model at consumeraffairs.com. Replacement of the control panel is expensive at an average cost of 298 dollars and appears to be the corrective action for other consumers with error code 3E. Over current is not being detected at the motor. I'm disappointed with the quality of this washer considering I purchased it in 2005 for over 1,000 dollars. This problem has forced me to use a local laundry mat to wash my clothes. This error code is not listed in the User manual.
Aug 24, 2010 | Maytag MAH8700A Front Load Washer
LR CODE ON DISPLAY
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source..."Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 (ten being hardest) I'd call it a 3.5. If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job. It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear. Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer. The instructions don't ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@@$
Apr 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Rinse error
I'm not exactly sure what was going on as I tried again to push the rinse button possibly a little harder this time and now it is working fine.
Sep 26, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
GE Microwave JES1334WD Code -P3-
Are you sure it's not F3? That would be a shorted keypad ("membrane panel").
That's usually not too big a job for a DIYer, but if you'd like, we can do that for $39.95 plus parts.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
One good test is (with power unplugged) to unplug the keypad, then plug the oven back in and see if the error code shows up.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 16, 2008 | Microwave Ovens
F code appears, can't reset any functions
Adele, there are 13 different F-codes for this model. You will have to be more specific so we would be able to help you. In the meantime, unplug the washer from the wall, remove the bottom toe panel. On the inside of the front panel to the right locate the bottom of the door latch assy. There will be a teardrop shaped tab on it. Pull the tab down about 1/4 inch. The door will release.
Jun 19, 2006 | Kenmore Elite 45986 Front Load Washer
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
1,113 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
