Question about Microsoft Metrologic MS7120 ORBIT Barcode Scanner
Orbit MS7120 character scanning problem
I have an Orbit MS7120 which I am using to scan some Code39 barcodes. It normally works brilliantly but won't scan barcodes of 3 characters or less? I've also noticed that although most of the barcodes are alpha numeric a couple of them have a double quote character (these barcodes represent product codes and some of them have an "inches reference in them). Is there anything I can do to get the scanner to recognise 3 character barcodes or the quotations character? Thanks in advance for any help.
  • 38 Answers
SOURCE: Code 128 Barcode Problem
Hello paul blando. I think I can help you here. First, are you sure your barcodes with asterisks are Code128 like the others? Generally a Code128 barcode will look like: "(1234) 567890 (01) 123456" and wouldn't really use asterisks at all. However, I know that it is standard practice for people who make their own Code39 barcodes to start and end the code with an asterisk to denote a start/stop action. Could they be Code39? They would look like: "*123456789*". If this is the case, then I have the manual for the P370/P470 on my company's site here. Take a look at the Code39 Chapter and make sure to print and scan the pages to disable the check-digit transmittal. If that doesn't do the trick, then try the "recall defaults" or "reset to defaults" barcode to reset the scanner to it's initial defaults. That should put it on track. If you still have trouble, please feel free to send me a message or email me. I hope this helps. Good luck!
Posted on Jan 06, 2010
  • 19 Answers
SOURCE: I have an old barcode scanner and it has a problem
I have (2) Welch Allyn 3700/B scanners availlable for sale.
Posted on Jan 28, 2010
  • 91 Answers
SOURCE: We are using a Metrologic MS9520 (keyboard wedge)
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Posted on Nov 11, 2010
SOURCE: my metrologic orbit scanner ms7120 wont register with cash resgiter
I think you've answered your own question. Spilling water on any electrical equipment will inevitable cause failures. It requires a repair, which we can do for you.
If you require an help on this scanner please dont hesitate to contact us
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Posted on Jul 24, 2012
mechine730
SOURCE: ms 7120 barcode scanner does not scan some
i have 4 Digit Barcode From my Software i Printed it not reading the Font Name is (C39Hrp24DhTt)
Posted on Nov 20, 2012
The scanner works fine but it doesn't automatically submit the info. Is there a setting somewhere that allows it to work this way?
scan "enable CR suffix" from your manual. You may also have to scan "enable LF suffix", but try it without first.
Oct 12, 2012 | Metrologic Instruments MS7120 ORBIT...
My metrologic orbit scanner ms7120 wont register with cash resgiter
Jul 09, 2012 | Microsoft Metrologic MS7120 ORBIT Barcode...
Make buzz noise & fan comes on
1) Tes the voltage tension from you outlet wallet.
2) if the voltage is low from 10% , you must use stabilizer voltage.
3) If everything is o.k , you need to lube the fan motor, and tight the connectors
May 08, 2012 | Microsoft Metrologic MS7120 ORBIT Barcode...
Ms 7120 barcode scanner does not scan some barcodes
Sep 30, 2011 | Microsoft Metrologic MS7120 ORBIT Barcode...
SPACE problem. Hello i have Symbol LS 2208. I need remove space/gap from this code 09/ 5864 I tried to create rule for this (remove all spaces) but it wasn´t work - the scanner scaned no data. I use...
Hello, if all your barcodes have the same structure, it will an easy task. You would need to scan following barcodes from ADF chapter in the Product Reference Guide located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Create New Rule Send Characters Up To Space Character in Alfanumeric Section Skip Ahead 1 Send All That Remains Save Rule
This will by all scanned barcodes send all characters up to the space character, skip the space and send the rest of data.
Oct 22, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
Dec 02, 2009 | Symbol P370 Handheld
Zebra S4M Lable Printer Not Scanning
You might want to check the barcode ratio, bar width, printer speed and printer darkness. I am assuming that you are creating the barcode in some sort of label design package, correct? You either need wider bars, or make sure you have enough quiet zone on both sides of the barcode, so shrinking it might be the solution as well.
Apr 12, 2009 | Zebra S4M Thermal Label Printer
Need driver software
hi first you need to know what the interface is then if its keyboard wedge programme for keyboard emulation. if its serial you will need some type of pos programme to run it in if its usb it should be plug and play hope this helps 2dornot2d
Sep 18, 2007 | Metrologic Instruments Orbit MS7120...
Microsoft Metrologic MS7120 ORBIT Barcode Scanner Logo
396 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
