Question about Intermatic 10 Amp Mechanical Indoor Timer
Setting Timer How do I set the timer?
    Guru:
  • 351 Answers
Without the model number it is difficult to advise you on the setting proceedure .. here is a site that you can find the manual and read how to set the timer. ..
http://www.google.com/#hl=en&source=hp&q=intermatic+timer+manual&rlz=1R2ACEW_en&aq=f&aqi=g1&aql=&oq=&gs_rfai=&fp=8760bbf0a0f5f1ee
Posted on May 12, 2010
How do you set a hager eh010 timer
switch the timer off or disconnect
turn the thermostat setting to low
that way it will not work when the solar section is producing enough hot water and when the temperature in the hot water system falls below the thermostat setting it will switch on the power
usable hot water temperature is around 60 degrees c and anything over that will scald the skin within minutes
low thermostat setting is 55 -65 degrees c
Aug 06, 2016 | Solar Hardware & Accessories
Will a three way lamp work with a pin timer?
http://waterheatertimer.org/How-to-set-timers.html
Yes..you must turn lamp ON to the setting you want (high, medium, low)... and timer will not change that setting, but timer will turn lamp on-off
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
May 14, 2014 | Woods Mechanical Inwall Timer 59017
Intermatic pool timer instructions
Timer is not identified. Do you have control center that controls heater, pump etc, or individual timer that controls pump?
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment.
Is this a new installation? Or did timer work before and stop working? What voltage are you working with?
Jun 24, 2013 | Intermatic Hardware & Accessories
Need instructions to set timer
1) Copy following link for setting analog timers:
2) Copy following link for setting outdoor timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
3) Add comment and describe timer in detail, and/or attach phot so timer can be identified
Dec 12, 2012 | Hardware & Accessories
Dryer not turning on.........before I would change the timer setting and it would would work.......after a couple of weeks, when i change the timer setting it wouldn't turn on at all. Question is
Definitely sounds like a timer problem. Sears Parts Direct should have your part. The model # you supplied is incomplete to determine if you have a gas or electric dryer. Check the model # again and go to Sears page to find the correct part.
May 08, 2012 | General Electric DBXR463EG Dryer
After I set my #055671 2-outlet timer to my turn on and turn off times, I cannot get the my lamp to turn on automatically. What setting should the timer be set on ?? Auto off, Auto on? or what?
There is no repair for defective timer.
I suggest setting timer programs, and then press clock button and timer returns to current time.
At this point the timer is operational, and then do not mess with manual override button.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Correct setting is either AUTO ON -or- AUTO OFF setting.
Auto ON, means lamp turns ON immediately and programming resumes at next set point.
Auto OFF, means lamp turns OFF immediately and programming resumes at next set point.
So you have to wait for time to arrive at set point to see if timer is working.
Troubleshoot from link above:
Check that correct time is set.
Check programming for conflicts and overlaps.
For example ON 8:00 pm Tuesday and OFF 10:00 pm All-days-of-week will cause timer not to operate as expected.
Test outlet with cheap circuit analyzer to ensure that electrical problems are not causing problem.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Hardware & Accessories
I lost instructions on setting the timer.
I Googled in Diehl digital timer and located a website that had the exact timer I have. Included in the list of information was a manual with instructions on setting the timer. I downloaded the instructions and set the timer. Exactly what I needed.
Jan 17, 2010 | Solar Digital Electronic Timer 20/40/60...
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the...
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
set.)
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
level.
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
played.
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Oct 31, 2009 | JVC KD-G210 CD Player
I have an MTD8 timer, that fits into my main electrical board
MTD8 Timer - Instruction manual
1. This timer has a total of 8 ON / OFF programs.
2. MANUAL ON / AUTO / MANUAL OFF for easy setting.
3. Switchable 12 / 24 hour mode.
4. 16 timer combinations are available as follows:
Monday
Tuesday
Wednesday
Thursday
Friday
Saturday
Sunday
Mo, Tu, We, Th, Fr, Sa, Su
Mo, Tu, We, Th, Fr
Mo, We, Fr, Su
Mo, We, Fr
Tu, Th, Sa
Mo, Tu, We
Th, Fr, Sa
Sa, Su
Initial operation:
1. When the timer is first connected to mains power, it will take up to 12 hours to charge the internal battery.
2. The settings can be defaulted by depressing the R (reset) button.
Setting Current Time.
1. Press the C+ (clock) button and hold, then simultaneously press the W+ (week) button until the actual day is displayed. Continue by pressing the H+ (hour) or M+ (minute) button until the current hour or minute is displayed. When setting, the W+, H+ and M+ buttons can be held down for rapid forward counting.
2. Release both buttons. The weekday and time will be set according to your selections.
3. To set incorrect time (etc.) repeat the settings.
Settings for programs:
1. Press the Timer button (Clock) and release. The first ON setting can now be made.
2. Press the W+ button to set the day or blocks of days. Select the ON time by pressing the H+ button and then the M+ button.
3. Press the Timer button (clock symbol) again to finish the first ON setting and enter into the first OFF setting. Repeat step 2 to set the first OFF setting.
4. Press the Timer button again to finish the first OFF setting and enter into the second ON setting. Repeat steps 2 and 3 to program the remaining settings.
When setting block dates, the ON and OFF times apply to all dates in the block.
I.E. Selecting block Mo, Tu, We, Th, Fr, Sa, Su and setting ON to 10:00 and OFF to 16:00 means that the selected times automatically apply to all the indicated days in that block.
Specifications: 230Vac 50 or 60Hz. 16A Inductive load. 20A Resistive load.
Battery backup >100 hours. Accuracy: +/- 1 minute per month. Temp: -10 to +40 deg C.
Apr 18, 2009 | Hardware & Accessories
Alarm setting??
Try "playing" with the CountdownTimer feature: Setting the CountdownTimer 1. Press TIMER ON/OFF to enter timer setting mode. The red TIMER icon will flash on the display. 2. To select countdown time, use the TRK (SEARCH?TUNE) / buttons to select the correct time. Press and hold to fast forward or fast reverse countdown time. 3. Press TIMER ON/OFF again to activate the timer. The unit will beep twice to indicate countdown has started. The red TIMER icon will remain lit during countdown. 4. Press TIMER ON/OFF to turn timer off at any time or after it has sounded. good luck
Nov 05, 2005 | GE Slim Spacemaker 7-5295 CD Shelf System
Intermatic 10 Amp Mechanical Indoor Timer  Logo
120 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
