Question about Boss AUDIO SYSTEMS BV9455 Car DVD Player
Disc error - Boss AUDIO SYSTEMS BV9455 Car DVD Player
  • 1,596 Answers
Means It Cant READ format that it is set at OR it is NOT DVD CAPABLE Chesk Manual for format Settings, and Change as Needed.
Posted on May 12, 2010
Iomega Rev Disc Write Error
you might have finalised the disc on the first burn or you have not selected to burn a multisession disk
hope tis helps
Jun 07, 2012 | Iomega (32961) External REV Drive
Tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Feb 18, 2010 | Video Game Consoles & Games
Error 11
ERROR-11, 12, 17, 30 Dirty disc Clean disc.
ERROR-11, 12, 17, 30 Scratched disc Replace disc.
ERROR-10, 11, 12, 15, 17,
30, A0
Electrical or mechanical Turn the ignition ON and OFF, or switch
to a different source, then back to the CD
Feb 20, 2010 | Pioneer DEH-1800 CD Player
Error 12 and 15 what is that
30, A0
Feb 18, 2010 | Pioneer DEH-P2900MP CD Receiver...
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
Feb 18, 2010 | Microsoft Xbox 360 Console
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Hi what does Error 03 mean?
My endeavor has done this error 3 a couple of times and the cd changer basically shuts off all lights and won't do anything. Someone on another solution page said to slide a credit card back and forth in the cd opening to fix the problem. I've done this both times and it has made the changer play again as if nothing had happened : )
Nov 14, 2009 | 2004 Mitsubishi Endeavor
Disc Error
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide....
Apr 07, 2009 | Nintendo Wii Console
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
Dec 21, 2008 | Car Audio & Video
Bad Disc Errors
are they disks you burnt?
Jul 15, 2008 | JVC Televison & Video
Boss AUDIO SYSTEMS BV9455 Car DVD Player Logo
145 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
