Question about Dryers
Amana Dryer Model# LED20AW S/N#. S 9707026456 The only way it runs if you hold the srat button down.
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryerAmana Dryer Model# LED20AW - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
Amana 7300 tandem Dryer
Did you find a solution? Mine is doing the same thing.
Jan 05, 2012 | Amana DLE330RAW Electric Dryer
How to change an amana dryer belt on a model # led20aw
Here is the diagram for the Amana dryer belt routing.
Here is a video to show you how to open the dryer.
Oct 02, 2011 | Amana Dryers
I have an model led20aw it is not heating. Heating element is good. What else could be the problem
First make sure you have 240 Volts going into the dryer. If you do you would need to chase all the wiring for a loose connection (usually burnt). First look at the timer, then there are thermostats near the element to be checked and there is a switch mounted on the outside of the motor; it has two "bigger" wires connected to it. Sometimes the connection burns loose at that point.
May 20, 2011 | Amana Dryers
Amana dryer model no led20aw will not start
When the dryer won't heat or will not start it is the thermostat/thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help....
Dec 31, 2010 | Amana DLE330RAW Electric Dryer
Amana gas dryer Model #ALG866SWB: When pushing
The motor is bad and needs to be replaced.
Jul 23, 2010 | Amana ALG643RB Gas Dryer
Amana Dryer will not work,will not stay on,makes funny noises
during the process of moving your dryer, it sounds like the drum became dislodged. With the dryer off, open the door and try to move the drum by hand, if it sounds like something is 'dragging' them the drum is off its bearings. IF it is, the quickest way to get help to take it apart is go online to youtub, type in your dryers name and model number and ask how to replace drum
Apr 27, 2017 | Maytag MDE2706 Electric Dryer
How to install drum belt in Amana Model LED20AW.
HIya,
Cabinet Removal- Maytag & Amana Top Load Washing Machine
Remove the two (2) screws (item #21 on the attachment below) from the bottom of the front panel. Once the screws are removed, pull out on the bottom of the front panel until the spring clips release for the cabinet top.
Diagrams:
http://www.pcappliancerepair.com/model-display.php
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
How to install drum belt in Amana Model LED20AW. This model does not have front or back panels to remove. Fabio
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Getting to heating element/thermal fuse for amana model LED 20AW
I just replaced mine by taking the bottom off, but in hindsight I think I should have been able to do it by just removing the lower front panel. With long arms, you should be able to reach back and loosen the two bolts holding it in place. Good luck!
Apr 05, 2009 | Amana Dryers
Amana dryer led20aw need wiring layout
Below is a link that will provide you with a wiring manual.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Hope this helps!
Dave E. (Illeagle)
Jun 15, 2008 | Amana Dryers
Dryers Logo
77 people viewed this question
Top Dryers Experts
