Question about Kenmore 71279 Bottom Freezer Refrigerator
GE refrigerator...Model GSS25WGMD..'frig won't cool..freezer fine
GE side-by-side refrigerator...Model GSS25WGMD WW...Freezer seems to work fine...current temp 15 degrees...'fridge does not work...current temp 59 degrees. Repairman has been here three times.
Original problem was 'fridge gradually wouldn't stay cold...freezer slowly got warmer too...repairman came out...coils in back of freezer all frosted over...repairman changed a "Controller Card" and a sensor...believe it was a "defrost sensor." Freezer worked fine...fridge didn't get below 60 (still doesn't). New repairman..same company...changed the "Control Card" again. No change... Original repairman returned yesterday;... changed the "fan motor" and sensor in refrig... No change... Repairman's giving me song-and-dance that refrig might not be repairable...says might be broken wire...I don't believe either of his "theories"...the fridge just sits there no bending and twisting like an airplane...I used to be an fighter jet (Phantom)electrician...and since this is a refrigerator...not a fighter jet or rocket ship, it should be repairable.
    President:
  • 2,468 Answers
How about the damper vent door between the refrig and freezer compartments it it open as to let cold air pass
Posted on May 12, 2010
  • 1 more comment
  • bobwittenber May 12, 2010
    Vent is open...I have the refrig set at 9 (max) and the freezer at 5. I believe the repairman changed the sensor which controls the damper yesterday. I don't her the fan running...yesterday after he changed the fan and the control card(that's the third control card)...I heard the fan work what I believe to be normally for about a minute...but then it just slowly decreased in speed and has never really run fast again.
  • danny Hendrickson May 13, 2010
    check the door switche(s) as they can also be culprits in the circuit,SxS use series/parallel switch combinations and one can easily cause a problem in these circuits
  • bobwittenber May 13, 2010
    ...the lights in both the freezer and fridge go on and off when switch is open/closed.
    I'm really disappointed in the service company. Been here three times over the past 9 days...they've changed the contol board 3 times the fan once and a couple sensors. I've had to take off of work nine hours to accomodate their schedule...they have never once looked at a repair manual or wiring diagram and they've never "shot" a wire...not one. Now they won't come until Friday...cost me $490.00 so far. I just can't believe there is something catastrophically wrong with a refrigerator that's just over 7 years old...never moved other than to clean behind and under it once a year or so. How is my thinking messed-up...???
FRIG NOT GETTIN COLD FREEZER SEEMS TO BE WORKING OKAY IT IS A GE SIDE BY SIDE
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Refrigerators
I have a GSL25JFPA BS that the frig side will not cool properly. Repalced the mother board. t stat in freezer and thermistor in frig. Freezer works fine. Damper will open when first plugged in but closes...
Unplug the refrigerator and then plug back in. Using multimeter check between J3-1 and J3-4.
Must be done within 10 seconds of starting. You should have 6 VDC. If you do replace damper, if not replace motherboard.
Jul 06, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Frig wont cool but freezer works fine
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | GE GSH22KGPBB / GSH22KGPCC / GSH22KGPWW...
Freezer not worknig.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | GE GSS25JFM Side by Side Refrigerator
GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model # GSS20IEPA WW Fridge warm...freezer is fine
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 28, 2009 | GE GSS20IEP Side by Side Refrigerator
Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Jan 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hot
check to see if the fan at the compressor is running
Jun 17, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE side by side frig: JSS22JEMC WW
sounds like defrost or fan problem let me know and I can help you
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 71279 Bottom Freezer Refrigerator Logo
406 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
