Question about LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone
How do you pair the blue tooth headset to the phone
  • LG Master
  • 6,993 Answers
visit the link below and follow the step/direction on how to pair your bluetooth headset with/to your phone.
http://www.wikihow.com/Pair-a-Cell-Phone-to-a-Bluetooth-Headset
Good luck.
Posted on May 12, 2010
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
CANNOT GET TO PAIR says it is but is not connected
Hi, It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps.
Thanks for using fixya.....
Nov 29, 2010 | Jabra Bluetooth Headset with Adjustable...
Code for sony dr-bt100cx bluetooth
Hi, when you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Hope that helps...
Nov 25, 2010 | Sony DRBT100CX Bluetooth Headset
How can I put use it on my samsung phohe
Hi, Problem solved. All you need to do is to know how to pair the headset with your phone. Ones you pair the phone to your headset,your done..
Hope it helps...
Oct 29, 2010 | Mizco Radio Communications
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Hope it helps..
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
How to put a hbh705 into pairing mode
Take care.
Aug 06, 2010 | Sony Bluetooth Headst HBH705 Sandcolor...
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I AM TRYING TO PAIR MY MOTOROLA HEADSET HS801 WITH MY NOKIA MOBILE PHONE BUT THE PHONE ISN'T FINDING THE HEADSET.
have you checked if the battery for the blue tooth is charged? And did you power the blue tooth device on, like wide that of the Nokia phone before you begin pairing?
If all the above are intact and the blue tooth is still not finding the phone, Then you have to test the blue tooth with another phone to be sure its not faulty.
Best regards.
Feb 19, 2010 | Motorola Mobility HS801 Consumer Headset
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
113 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
