Question about Sony Playstation 3 (PS3) Console
When i plug my ps3 into the tv using the hdmi cord i just get a blank screen. How can i fix this?
    Sergeant:
  • 240 Answers
Make sure HDMI is selected in the Video settings
Posted on May 12, 2010
4 Suggested Answers
shooty
  • 50 Answers
SOURCE: I was switching my PS3
so u must go n plug the hdmi cable in a tv dat support an hdmi feature so u can be able to fix the problem from the menu.....if it's not lkike that i think u can use the AV cable on a normal TV ....so u can fix it as well
Posted on Aug 19, 2008
flowtron2k2
  • 95 Answers
SOURCE: Playstation 3 HDMI
with redlight on...hold power button for 10-15 secs to reset the HAL registers (HDMI) should beep once..then 5 secs later once again
Posted on Nov 10, 2008
Sutibun
  • 186 Answers
SOURCE: My ps3 normaly runs on hdmi but i have to use a
http://ps3explained.com/intermediate/power-and-eject-buttons-hidden-uses/
Posted on Jan 24, 2010
My emerson tv say device control inactive
John, I've ran into this issue a couple of times myself. In most cases, there are easy fixes to the issue. #1, Does your TV have multiple HDMI inputs? They may be labeled HDMI1, or HDMI2, etc. I know this sounds strange, but many people don't realize that the signal source is important. #2, Connect the cord, from another device that you know works(laptop-monitor) to eliminate the possibility that your HDMI cord is bad. #3, (Probably most common) The PS3 is not the most stable platform when using the HDMI cord. Remember that the PS3 was one of the "pioneering" platforms using the HDMI connection.As such, the "auto-detect" feature is sometimes confused when switching between RCA inputs, and HDMI input. (Happens every time actually) To fix this, try a video reset on your PS3 system. It's fast, easy, and doesn't effect anything except the video/audio settings. I'll put in a link to get you started in that direction. It is the same with all models of PS3. Good luck! ^^
How To Reset PS3 Video Settings PS3
May 06, 2013 | Sony Playstation 3 (PS3) Console
I have my sony ps3 hooked into HDMI 2 and a blank screen. It stats unknown timing?
This has something to do with incompatibility and/or settings.
Aug 05, 2012 | Toshiba 37AV52U LCD TV
I have a panasonic Th-42pv500a. I'm trying to connect my ps3 Via HDMI but it won't work. The ps3 works in my other tv with the same HDMI cable. And the foxtel box works in the panasonic with the same HDMI...
the playstation detects that you are changing display settings. hopefully you still have the old red yellow and white cord that we all used to use to plug in stuff to your tv . use this cord to connect your playstation to the tv, it should pop up that you want to change display settings. then after you go through that unplug and recconect the hdmi and it should run you through it again, Another option - when you plug in your ps3 to the tv , turn everything on the tv and playstation. if nothing pops up turn off your tv and playstation , literaly unplug them from the outlet for a good minute then plug everything back in and you should fix it that way. hope one of these work
May 04, 2011 | Televison & Video
I was switching my ps3 from hdmi output to the red,yellow and white cords and after i accepted i switched my tv to av1 and there was picture and sound but it then asked me what format and i selected 1080p...
Easy to fix so don't worry ;)
While the PS3 is off (solid red led)
Hold down the power button until you hear the SECOND BEEP, quickly release.
This will reset the video settings back to default.
Feb 01, 2011 | Sony Playstation 3 (PS3) Console
When i plug my hdmi cable to playstation and the tv, i get no signal! when i plug that 3 different colour cable. i get good graphics.. how to fix my hdmi input for Ps3
plug both cables into tv select the input on tv that has the three different color cable plugged into it use this connection to navigate the menu on ps3 go into display settings and choose the option for 1080 p or 1080 i and then choose the input method of hdmi after doing so your picture will go blank you must then select the input on the tv that has the hdmi plugged into it your screen should then show the picture you must do this quickly because you only have 30 seconds or so to save the new settings before it resets back to the old output settings. click your x button to save and you should be well on your way to better graphics using the hdmi on your ps3!!
Dec 06, 2010 | Sony Video Game Consoles & Games
My ps3 turns on but nothing appears on the screen what should i do? i have all the cords plugged in
Your question is lacking a little information, but I assume you are using a HDMI cable. First you need to turn the PS3 on by the switch on the PS3. Then press and hold the On/Off button on the PS3, keeping it pressed until you here a clear beep and then a couple of seconds after you should hear a second beep. Once you hear the second beep take your finger off the button. Now as long as you are on the correct HDMI channel the rest should be on the screen for you to complete.
Please Note - If you have it working on a particular TV, then decide to unplug the PS3 and put it on another TV, there is a very good chance it will be blank again. This is normal because each TV has different setting, pixels, size, etc, and the HDMI has to be set to each individual TV. Once you get use to the settings. It takes no more than 1 minute to do.
Cheers, and hopefully this will solve your problem.
Feb 09, 2010 | Sony Playstation 3 (PS3) Console
My screen wont work i tried a hdmi cable but wouldnt work what do i do?
If you can get a display with the default setup (original cords) follow this procedure:
a) Plug in BOTH the HDMI cord and the other display cords to your TV.
b) On your TV, using the disignated video input (not HDMI) you should have the main screen
c) Go to settings, and then display settings. Set up your display to read HDMI. Your screen will go dark.
d) Quickly change your TV input from video to HDMI and it should still be displayed. Save the changes.
e) Shut off the system, unplug the original cords leaving in just your HDMI cord and your designated audio cord (preferably fiber-optic).
f) Turn it back on and you should be good to go.
Dec 01, 2009 | Sony Playstation 3 (PS3) Console
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Playstation 3 HDMI
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
I was switching my PS3 from using the hdmi cord to using the regular cord so i could use it on another tv. when i switched the cord settings it had to switch the tv settings on the PS3 from 1080p to like...
Aug 19, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
