Question about APC (BE500U-WEB) (BE500UWEB) UPS System
Ups not giving back up
From last 6 months,in case of load shading,my ups in giving back up for only couple of seconde.for that reason,i charged my ups for 6 days continuously,still i am facing the same,waht can i do????how to charge it??
  • Manoj Guna
    Manoj Guna Feb 18, 2013
    I am having V-Guard Splender Plus 600 UPs,Its not giving backup more than a minute.How to recover this?
    Problem Solver:
  • 14 Answers
How old is this UPS? Is power failure frequent? Anyway I think you batteries will be gone faulty. You may have to replace them.
Posted on May 24, 2010
The power went out , the battery back up will not restart after the power came back on , it starts and in 2 to 3 seconds it kicks off. It is a 1300 apc
In some cases you need to remove all load from the UPS and let it charge up for a few hours in the off position before they will restart. It is also possible that the UPS was damged when the power failed. In that case, check your warranty as you might be able to get the unit replaced.
Jul 05, 2011 | APC Computers & Internet
My ups is not giving backup?
The main reason for not giving backup is improper charging or insufficient charging. Or if the UPS is about 18-20 months old, the battery is unable to give backup. or these are not the cases, the wires inside the ups, above the battery ,connected to the +ve and -ve ports on the above or side of battery are not properly connected or are loosen. try to tighten them with yourself with a plier or goto a shop for a better result. Hope this will help. Thanks for using Fixya.
Nov 17, 2010 | Computers & Internet
Does not power on but indicates charging
There could a couple of problems that would be the reason that the UPS is not able to power your equipment.
1. You have exceeded the output limits of the UPS. If the power demand from all the devices exceed the UPS' capacity. The model that you indicate should be able to power a total of 1000 watt load for about a few minutes. If should be able to power your computer, monitor, modems/routers easily, but if you have a laser printer attached, it will not be able to sustain the demands of the printer. Try removing any heavy loads like printers and see if this will work.
2. The battery in the UPS needs to be replaced. The battery in a UPS is only good for a few years. After a while it needs to be replaced because after a while it is not able to supply the needs of the UPS. If the battery is more than 2-3 years old it should be replaced.
Hope this help you.
Jul 02, 2010 | APC Smart-UPS 1000VA UPS System
My UPS does not start
I'm guessing that during the power outage, the ups battery completely discharged. Now it will take about 14-15hrs to recharge it.It will not support any devices until it is fully charged. Remove all load devices and let the battery restore to full charge before re-connecting the devices. If the battery does not recover, it needs to be replaced.
Apr 16, 2010 | APC MasterSwitch Power Receptacle - Power...
My kin-1200 ap doesn't charge the battery properly.
The reason for this is that the UPS, is unable to efficiently charge those BIG batteries, you see they generally only charge at a low rate, anyway, of say 10% - 15% capacity, of the-battery-usually-charged. Now with these BIG 40 Amperes by 2, well, there simply isn't enough "Juice" to charge them up... (Oh it might do in a month or so)... from that UPS's Charging Circuit. You will most likely have to rig up some other higher rate charger for those BIG batteries. OR modify the charging circuit IN the UPS. They need to be charged at about 1 Amp or maybe more. See it is simply Charge over Time... 40 amps at 1 Amp will take 40 hours.. 40A at 2A = 20H & so on. If only 1/2 flat 2A over 10hours.
Feb 07, 2010 | Powercom King Pro UPS System
APC UPS XS900 is claiming the battery unit is disconnected
HEY !! it's under warranty. I had one of these freak out on me in much the same way once in a while. I did the online help on APC's website. STAND YOUR GROUND if you don't get the answer you want. I held strong even after the "tech" said repeatedly that it was a building wiring fault, which it's not, and harassed him into exchanging it for a new one. Good luck
Nov 01, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
How Icalculate the back periode of ups?
look at back of ups, it will have rating plate
eg
230V 3000VA
pf= .7 2100WATTS
72V DC
in this case we have a 230Volt 3kVA ups at .7power factor giving a total of 2100watts of power.
batt is 72Volts DC
ups on bench, batt at full charge with lamp load, usually I connect 75% load eg 1575 Watts, then fail supply and time batts to batt alarm point.
recharge and test again.
can be done with any size ups, other way is to put in data into makers web site and they should give approx batt times for different loads.
Sep 07, 2009 | APC Smart-UPS RT SURT6000RMXLI (APC9672)...
APC back UPS 400 fails to give back up
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
Oct 12, 2007 | APC Back-UPS 400VA (BK400) UPS System
APC (BE500U-WEB) (BE500UWEB) UPS System Logo
294 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
