Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Flywheel keeps sheering the key after about 5 seconds of run time
    Top Expert:
  • Briggs & Str... Master
  • 10,875 Answers
Is the flywheel torqued right?? about 25 ft/lbs?
Posted on May 12, 2013
  • 905 Answers
The bearings on the alternator, or the end bearing on the engine, is likely seized. Engine tries to overcome, but ends up shearing the key. You might also be using the wrong replacement key as well.
Posted on Jun 12, 2010
I have a 6.75 Briggs and Stratton that always started on first pull. It is 5 yrs old. Started and mowed front stopped it and it will not fire again only pops through the carb. it has fuel. Plug is ok
popping through the carburetor if a sign it is out of time. the flywheel key has sheered. remove the cover on the top of the engine. take the nut off the flywheel and see if the two grooves are lined up with the key. if not replace the key and it will be good.
May 30, 2017 | Briggs Garden
How do i set the timing on a 33 inch craftsman walk behind mower?
There is not an actual adjustment for the timing. If the sheer key on the flywheel has sheered a bit, this will cause the timing to be off. This happens if you hit something with the blades. You would have to remove the starter housing, flywheel bolts and flywheel. remove sheered key and install new.
Jul 08, 2015 | Craftsman Garden
Model 31p977 flywheel torque spes what are they. flywheel key keeps sheering
not on a tape measure it doesn't so get the question tight if you want to ask for help
Apr 19, 2015 | Measuring Tools & Sensors
WHY FLYWEEL KEEPS SHERING THE KEY
Reset the ignition timing correctly before starting the engine.
Oct 13, 2014 | Garden
No fire at points on a 810 ford tractor
engine has partialy shered the crank sheer Key ---remove flywheel and replace with new sheer key-- should correct time ing and let the points arch
Mar 14, 2014 | Garden
Snow blower will not start
sheer pin on flywheel sheered off pull flywheel and replace sheer key
Feb 23, 2014 | Troy Garden
POPPING THRU CARB RUNS GOOD AT HIGH REVS ON 24 HP INTEK
I would lean more to the key on flywheel being partly sheered which will throw the timing off. that will happen if the motor has a sudden stop or jolt while running.
Nov 25, 2013 | Briggs & Stratton Measuring Tools &...
Flywheel keys keep going and going out of time
This is not a dryer question. A flywheel that has spun and sheered the keyway will require re machining. There is supposed to be in interference fit between the flywheel and the shaft and the key only helps retain the position. The key is soft to allow for serious trauma, but if the flywheel spins by much, it will fit too loose.
Jun 21, 2011 | Dryers
My son hit a log with my js25 walk behind mower now it won't run.
He more than likely sheered the key in the crankshaft. When the key bends or breaks it throws the timing off and the engine will not start. The key is there to prevent damage to the crankshaft when you hit an object. You will need to remove the engine cover and then use a puller to remove the flywheel. Where the flywheel connects to the crankshaft you will see the key which is either broken or bent. All you do is buy a new one and replace it.
Apr 23, 2011 | Garden
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
149 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
