Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Wireless signal appeared to faulter all lights on the router went to fixed green. We unplugged and re plugged router as this appeared to resolve problem in past. We are now left with only the green power light and no broadband signal at all.
  • 31 Answers
* take a paper clip press and hold the reset for 1 minute, while holding the reset unplug and replug the power cord 3 times..( make sure the reset is shouldn't be released )
* then release the reset then unplug and replug the power cord
* the login to the router set up page with 192.168.2.1 by typing these numbers in the address bar of the browser
* if u enter the router page then on the left side u can find a column
in tht column click restore factory settings under utilities
* then leave the password blank and click submit
* then click on restore default
* then after the completion of the reset u need to see the internet status --- saying connected ( in the upper right corner )
Posted on May 12, 2010
  • 4,281 Answers
For that you need RESET your router then reconfigure it.
You can RESET router with RESET button it is in back side of router press it for 10 seconds so all settings defaults.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Also change channel type to 3 or 6 or 11 and save so you get better signal.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
How do I resolve my internet port light being amber on my wgr614v7 netgear router
Recommend that you go one step at a time.
1) unplug the wireless router.
2) reset your Cable modem or DSL modem. Wait until the lights show the Wide area network or WAN is working correctly before applying power to the Netgear wireless router.
3) After a minute or so, its signals should change from amber to bright green.
Repeat if necessary. If this doesn't provide the connectivity that you need, a call to your Internet Service provider may be necessary.
Sep 06, 2010 | NetGear WGR614 Wireless Router
The signal light is blink and cant get a signal from the wireless computer. Do i need to reset my router?
First off, the computer gets the signal from the router, not the other way around. Secondly, depending on the amount of walls, thickness of walls, amount of interference, the range on your router may not be far enough to reach your computer. If you used to get a signal and no longer can, unplug everything and plug it back in after a minute, that usually fixes the problem. If there is still no signal, try moving your computer closer to the router, or the router closer to the computer. If it is simply that the router does not have enough range, consider upgrading to a wireless n router.
good luck, let me know if you need more help
Dec 29, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Wirless router not working
it seems to be a problem with your ISP.May try these steps.
1. disconnect the router from the computer and the modem.
2. now connect the Ethernet cable to the modem & to the computer and see if that works.
else contact your isp.
for more help.
moz-screenshot.pnghttp://www.ikarmatech.com
Sep 08, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Solid red power light
pls check the power supply this happens when the router's supply is faulty or the power outlet in WALL ,
otherwise try this see for RESET button on the back of Router press it for 30 SEC when ur router is ON and it will resolve for sure let me know if it doesnt solve i can help more
RATE ME WELL !
Regards
Zohail
May 17, 2009 | 2wire (1000-400108-001) Router
Have good signal, keeps dropping off the internet
The problem here could be the Wireless Channel.
All you have to do is the following:
1. Log into your router at 192.168.1.1 that is the default unless changed by user,
2. Click on Wireless Tab
3. Change the Wireless Channel to 6 instead of 11 or change it from 11 to 6.
4. Apply settings and you shold be fine.
You need to do this because your router is conflicting with other wireless devices that are present nearby on the same frequency.
If this does not solve just try other Wireless Channels.
Thanks.
Hope this solves your problem.
Apr 04, 2009 | Linksys WRT54G2 Wireless Router
I cannot keep my connection to my wireless modem/router.
the router may be bad i would take it back and exchange it
Dec 27, 2008 | 2wire 2700HG-B Router (2700HGB)
Wireless not working
Yes, There could be alot of things that are causing your Operating System to not obtain signal from your Wireless Router....I would first of all try troubleshooting this by;;
1st - Unplug your High-Speed Internet Modem and Wireless Router for 30 seconds apprx.
2nd - Restart your Computer.
3rd - Once your computer is logged in and at desktop, Plug-In your High-Speed Modem then wait until all lights appear that show your Modem is online then plug-in your Wireless Router then wait about 30 seconds then try to connect to your Wireless Connection.
If these do not work make sure that, you do not have your Wireless Router. I would also recommend that a way to create and obtain a signal strength that the computer can reach please go to the following website http://www.mythings.com/tips/1664/Where-to-Put-Your-Wireless-Router This should assist you with making a stronger signal strength.
Oct 25, 2008 | Computers & Internet
Wireless router not working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 10, 2008 | Linksys Wireless-G WRT54G Router
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
