Question about Garden
Clutch problem allen national 68 triple ride on mower
We have an allen national ride on triple blade mower. We haven't used it for a while and when we got it going the other day, it wouldn't go into gear because the rear blades are engaged and won't disengage. any idea what the problem could be and how we can fix it?
    Genius:
  • 1,354 Answers
The problem is you haven't used your machine for some time bceoz of that your mower gear is jamed just try to replyce gear oil then keep fo some time then try it will work
i hope you will solve your problem
Posted on May 12, 2010
  • moirasara May 12, 2010
    hi
    thanks for your suggestion. I will try that, but I don't know where the gear oil goes - I can't see anywhere to put it. Sorry to appear so dim, but any suggestions?
    Also the clutch/break pedal seems to have a lot of free play. Should I be tightening that up?
    Thanks
I just bought an old John Deere 68 riding mower but it does not cut grass even though the blade spins when engaged. I made sure the blade was on correctly but it still doesn't cut. I noticed the pulley...
Are you sure it is the correct blade and when it is turning the sharp edge is on the leading side? A spinning blade will cut grass even if the blade is dull. Did you lower the deck to the correct level?
Jun 28, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Blades stop in high grass
first make sure the belt is tight if you haven't checked it already then look at the gap on the clutch plate it maybe warn and slipping under heavy load
Apr 01, 2012 | Husqvarna Garden
Need a diagram of how to route the blade belt on my JD 68 riding mower
there should be a diagram on your lawn mower deck on the bottom side or on the left top side.
Jul 08, 2011 | Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Blades wont engage on a john deer riding mower
May be a safety switch not letting the PTO engage the clutch? Also check your voltage at the battery...too low a voltage won't let the clutch engage either. Should be between 13.3-14v at full throttle.
Sep 09, 2009 | Garden
Toro 216 triple mower . the electric clutch will not switch off leaving the blades in drive all the time . can the clutch be striped down and repaired
the switch where the blades are engaged try to unplug from the back of the switch if the blades are still engaged after you unplug the switch then the clutch is at fault. If the blades disengage and shut off after you unplug the switch then all you need is the switch!! The clutch can be repaired but the parts are very hard to get if you can even find them!
Aug 26, 2009 | Garden
My john deere riding mover the clutch will not disengage it still keep going.any solutions
With the engine OFF, reach underneath and locate the plug for the blade clutch and unplug it. Start up the mower and see if the blades are turning. If they are still turning with the clutch unplugged, REPLACE THE CLUTCH
Jul 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Blades won't spin on Craftsman II riding mower
get some one to sit on it and holding the brake try engaging the clutch...now with out getting to close laying down you can see if the linkage is working right....might just be a missed belt wheel.
Jun 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
97 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
