Question about Toshiba TEC B-SX4 Thermal Label Printer
The printer is printing very light. Already
The printer is printing very light. Already installed new ribbon.
Error : excess head temp
Posted on Jun 18, 2010
Hi Gerry..I was looking for a solution to another problem and saw yours... Maybe you can increase the temperature of the sensor. To do this, go to the menu <3>ADJUST SET, look for "TONE ADJ<T>" if you are using "Thermal Transfer" or "TONE ADJ<D>" whether you're using "Direct transfer" and increase one of this values: +5 should be good... I hope this can help you.. Regards..
Fernando (fcejas@gmail.com)
Posted on May 27, 2010
My printer DataCard SP 35 started printing only in grayscale suddenly (with a colored ribbon). Before it ware printing colored cards.
I think rain doesn't have anything to do, unless you had your printer outside...
Maybe a light interruption could make your station start over without proper settings. Try checking your printer driver and see if it has the proper settings for ribbon and not printing on black dots.
Jan 17, 2014 | Datacard SP35 Printer
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
Starts off printing normal than fades. new ribbon in it
Check the new ribbon and see if the printer has worn out one spot.
If you move the print head manually side to side the blue knob on the ribbon should spin. If it does not make sure you have the correct ribbon and it is installed correctly.
Mar 08, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
It prints the yellow & magenta layers, then skips printing cyan & black (with screeching noise as the ribbon passes) to printing overlay (sometimes skips overlay), but stopped short of ejecting to...
Download the latest copy of the C30 firmware, Fargo created a fix by sending more power to the ribbon sensor. After downloading the new firmware, calibrate the ribbon covering the printer the best you can from light.
Nov 18, 2009 | Fargo Persona C30 Thermal Card Printer
My printer displays ribbon error. but there is ribbon inside
you can change which ribbon type is installed in the printing preferences of the printer driver.
make sure you have the right ribbon type selected.
CYMTKO vs. CYMTO, etc.
There is also a button that will auto detect the ribbon right underneath the pulldown menu.
May 26, 2009 | Fargo DTC550 Thermal Card Printer
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
296 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
