Question about LG 23LS7D Television
This LG set is being used as a video monitor. After being powered on for 5-10 min. the screen goes blank, leaving power indicator light green. When power button pressed off, then on video returns for another 5-10 min. then video is lost again. There is no change at all in the screen when power button is hit first time(green indicator changes to red 'standby' in lower right corner) and when pressed again video returns with no sign of problem...until it's gone again.
  • 8457 Answers
SOURCE: My LG 32LC7D set was
Ur power inverter board is dead.
U need a new one.
U getting power don't mean it good.
Posted on Aug 24, 2009
itvrepair
  • 28 Answers
SOURCE: my lg plasma tv stays on standby
is you already change the power board,is possible
your y board is out...is a big board on the left side of the tv
Posted on May 19, 2010
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
IN POWER SUPPLY SECONDRY SIDE ( 5V,12V,&24V) ALL CAPASITER REPLACED SET OK
Posted on May 25, 2010
budmrtn
  • 11361 Answers
SOURCE: Hi, I have a 37lc46 LG LCD which takes ages to
Replacement power supply is used?
You need to verify the DC output voltages of the power supply first and make sure this power supply has no bad caps with leaking/bulging tops. It goes into standby can also be that it detects fault some where in the set.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 07, 2010
SOURCE: TV always in standby mode and can't display channel. Need press many times
Go to Badcaps forum online
Posted on Dec 07, 2011
Mx4000 128mb on xpsp3 problem
in windows power settings, you ajust the time the monitor runs and shuts down one setting is do you want the monitor to stop after 5,10 or so mins you answer never that will cure the shut down
Jul 06, 2010 | XFX GeForce MX4000, (64 MB) Graphic Card
The monitor goes blank after a few min, it comes
Are you sure that your computer isn't just going into power saving mode? Not sure what operating system you have but go into the screen savers tab or video properties and find out how your system is set up for power saving It may be starting before your screen saver does so the monitor would just go black.
Dec 18, 2009 | ViewSonic PF775 17" CRT Monitor
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Monitor only stays on for 30 sec. & then goes off then if I remove the power cord & re-power it up it comes on for another 30 sec. then goes back off
Howdy folks. There are only 3 things that can go wrong with a screen. Since you both are experiencing the same symptoms, let's ask the same question: When the screen goes blank, is the power button still green or is it orange? A green light indicates a good power supply and a bad screen. An orange light indicates a bad power supply but a good screen. I used to take them apart and try to fix them but they just aren't worth the trouble because they are so inexpensive nowadays.
Either way, I'm the bearer of bad news. It looks like you'll both be getting new screens. Please don't hold it against me when you rate my solution! ;-)
Jan 04, 2009 | E-Machines eMachines Monitor E15T4
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Pc screen goes black green light stays on
Well since you seem to have tried a bunch of thing why nor go a bit more and replace your video card. Below is a link to your PC:
http://support.packardbell.com/uk/item/index.php?pn=P280110001&g=1400
Dec 21, 2007 | Computers & Internet
Screen goes blank
Screen going black would indicate a data flow problem- but then you would see a warning saying words to this affect or a back light/inverter problem. If by looking slightly sideways at the sreen you can see 'shadow images'[try a moving image to be syre] then you have a backlight /inverter problem If you see nothing at all ckecj the data cable pins- one or more may be bent
May 23, 2007 | LG L1910S (Silver) 19" LCD Monitor
Televison & Video Logo
32 people viewed this question
Computer Repairing
Computer Repairing
