Question about Philips 30PW8420 TV
Tv won't turn on
So i've had a 30PW8420 tv for almost a year. I recently discovered a nifty little menu called "SAC" i believe (you access it by pressing 062596 and the menu button, and then holding down the Volume - and Channel - buttons)
This menu included many tings, but the msot important thing for me was the "Geometry" section, because the vertical and horizontal settings on the set were a little screwed up.
Anyways, the problem is i may have accidentally hit the wrong button at the wrong time. I was crolling through the menu, and i saw something that said like "activate SAMC mode" or along those lines. I did, and the tv shut itself off afterwards. i don't remember if those were the exact letters, but i'm 100% sure there was 4 letters. Now when i try to turn it on, i "hear" the sound of the tv powering on, and teh LED turning on, but then it shuts itselff off before the picture or sound comes.
Also, something interesting. I can turn it on by pressing the volume and channel buttons on the set itself. Weird, huh?
  • superjavs Apr 05, 2008
    Yeah, i got it fixed. I left it unplugged for 24 horus, plugged it back in, and it worked.
    Lesson learned: don't mess with the Service Menu :)
  • rickskye Aug 29, 2008
    I'm having a similar issue with mine actually. I was fooling around in the service menu and trying to fix the geometry. I adjusted the trapezoid option a bit too far and the screen went off. If I turn it back on, the LED stays solid for about 3 seconds, then blinks 3 times and the TV turns off. I know it's an error code, but how certain is the unplug option for a reset? I've heard it can be either 4 hours, or 24 hours, so I'm a little unsure.
Did you get any help yet with this problem?
Perhaps check out this forum.
http://www.highdefforum.com/showthread.php?t=25246
I think there might be a guy who can help you out with that problem.
Bunky
Posted on Apr 05, 2008
  • bunky_boy Apr 08, 2008
    Another question I meant to ask and perhaps more importantly.
    Did you manage to get your vertical and horizontal problems fixed using the service mode?
    I have some concave issues with my 4:3 screen and there's nothing in the user menus to correct that.
    Bunky
How to reset access code on magnavox 20ms233s
Hi. It's really necessary to have the original remote. All so called replacment do not have the "menu" button. In Philips TV's access code is not rquired. In your case, some channels are "whiped" and cannot be recalled. If you can go into setup-menu, things can be rearranged. There are numerous web-shops where you can buy an orignal remote. I recently bought an original remote for my DVD player. This however was at an on-line shop in Belgium. Just surch for Pilips on line shops in your country. Good luck.
Sep 10, 2014 | Philips Magnavox 20MT133S 20" TV
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
TV turned off by itself and now won't restart. Blinks three times pause and then eleven.
Google your make and model with the words blink codes at the end. This will take you to sites where you can look up your blink code to find out what is wrong with your set.
Aug 21, 2011 | Philips 30PW8420 TV
Need TV Remote code for Phillips 30pw8420/37
Have you check the manual universal remote? where you find the code, you have to cosiderate the philips on listed, then try all the code, before that tell him, how works this function the univeral remote.
Nov 21, 2009 | Philips 30PW8420 TV
Push power button to turn on tv, two seconds later, before the picture arrives, power goes back off
holding circuit for the power on relay not working. suspect bad micro relay failed.
Sep 20, 2009 | Philips 30PW8420 TV
Philips tv powered off and wont turn back on
There is a smt located at 7404 [C-6 Bottom] A common problem, does the tv make a sound like it wants to come on? Location 3239 should be small resistor, 3414 another resistor and a driver transformer at 5402 if it looks burned. See MCM electronics website and see if there is a kit to repair this. Or ask for part #s as per location of problem area mentioned. What you will be doing is changing the timing so all the components will come on at the same time. If this is done correctly you will notice the top of tv screen will flash red, green and blue lines. This will be the new norm each time you turn it on. But it will be OK. This is what the flashing green light is telling you. signed the Green Lantern7!!!!!!!
Sep 03, 2009 | Philips 30PW8420 TV
Finding AV channel without a remote control
Hi, I brought a EmersonTV model EWF2004 without a remote control and I can't find the AV channel to watch DVD's I hope you can help me
Sep 01, 2008 | Emerson EWF2004 20" TV
Philips 30PW8420/37 TV Won't Turn On
The led code indicates vert failure for one. ( 3 blinks )
The 2 blinks indicates excess beam current of which could be your picture tube or re-adjusting the G2 voltage on the HV transformer which is very critical on philips sets.
Apr 10, 2008 | Philips 30PW8420 TV
Changing the default channel
I believe you will have to have a tv tech. do this adj. , this is set in the factory service menu which he or she can access.
Nov 27, 2007 | Zenith H27E35DT 27" TV
Philips 30PW8420 TV Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
