Home | Acer | Aspire 5100 PC Notebook | My acer aspire 5100 key...
Acer Aspire 5100 PC Notebook
Problem for Acer Aspire 5100 PC Notebook
My acer aspire 5100 keyboard,usb
By ajlar on Mar 29, 2008
my acer aspire 5100 keyboard,usb mouse unusable
Same Problem
Mar 09, 2009
-   After force shutdown my laptop 5100 acer, keyboard, mouse, USB even Sound are not working. Please can I have your's help!!!!!!!!!!!
jeee -   jeeeee
Mar 04, 2009
-   I have the same exact problem. it is funny you should mention the dent or melt down that appears right below the windows key on the keyboard. i thought something had pressed down on the laptop to make that dent but it is clear it has something to do with the keyboard and mouse freezing. it first started by the usb mouse not working in the usb ports in the back and then proceeded to all the other usb ports not recognizing the mouse before it froze. What works coz i need to be able to get back to work? -   Bash007
Feb 03, 2009
-   Humm, have the same model (BL51 to be exact) with the same no keyboard, mouse or USB working. There is also a melted down dimple below the windows button on the KB, very interesting.
Unfortunatly, the HD failed a while back and I replaced it, now the whole laptop is kaput. -   Guest
Feb 01, 2009
-   Hi! i have a problem with All ports and keyboard,mause dosent work, can you halp me!-   arti_005
Feb 01, 2009
-   when download a picture from my camera my screen when black after i reboot keyboard and mouse and usb stop working remove battery and unplug over night then i retry mouse was orking windown open so i try to reset pc on manufacture default pc stop in the middle of installation now have nothing working no mouse no keyboard and no window will never buy from acer again my laptop only 3 years old try tech support at acer they wont 150.00 by hrs to help bad bad service-   yvestrembly
Best Solution
posted on Sep 11, 2008
Helpful)
gitmo
Rank: Apprentice
Rating: 86%, 4 votes
A temporay solution is to use a pcmia card with usb port slots. That way you can connect a usb keyboard, usb mouse or any other peripheral device thru this slot. It has worked for me for 1 month so far. It is the most inexpensive way to temporarily fix this aspire 5100 manufacturer defect. I believe that this model easily overheats and affects the motherboard in areas that control dvd, usbs, keyboard and mouse. I am contemplating a suit against Acer for this 'lemon' of a product. There has been no recall nor support from Acer to fix this problem and they continue selling this and other defective products. Feel free to email me at gitmodotcom@aol.com from comments or questions. Ray=)
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Somewhat Helpful)
ERajs
Rank: Apprentice
Rating: 71%, 2 votes
My Aspire 5100 has the same problem. There is also a small dent under the Microsoft button as though something melted underneath. I believe that my fix will require a new mother board.
Was this helpful?
Yes
No
Solution #3
posted on Jul 03, 2009
Very Helpful)
shiezcal
Rank: Apprentice
Rating: 100%, 1 votes
hi there pntbrshro172
I did what you have in your post. It worked for me. The mouse and keyboard worked perfectly fine but when i restarted my acer, it had the same problem. i can't put my laptop in my freezer everytime i'll be using it.LOL..you have any other solutions?thanks a lot for your help..i really appreciate it..
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Feb 10, 2009
Somewhat Helpful)
pntbrshro172
Rank: Apprentice
Rating: 80%, 5 votes
O.K If you follow these instructions to the letter ,I can help you get your system up and running again.Acer motherboards have the CMOS battery hardwired in its frame work and cant be changed This is where your problem is.Unlike most other computer brands you can change out the CMOS battery like a watch battery.
First Dont panic.
Now go to a computer supply store and get a de-magnatised computer screw driver set and cpu thermal paste ( artic silver).
Remove battery
Remove all srews from the back of the laptop
open and remove back cover.
Remove the Hard drive,and ram stick
Flip laptap bak upright and remove title bar strip or power bar strip (its the plastic strip above the keyboard) its only snapped in so be gentle .Remove the screws that are visible here.
Remover keyboard and unplug the circuit stip to both the keyboard and touchpad mouse.
Remove the power plug leading to your screen.
Remove the entire keyboard face plate with a few more screws.
Flip laptop back over and remove the fan the cpu heat sink and cpu.
Follow the wires leading from your screen to the clipset.unplug the black and white wires then remove the chipset.Pull the LCD creen wire through the board and remove the screen from you laptop.
Now all that should be left is your motherboard and dvd rom drive.
At this point your going to empty the information being held by your corrupted CMOS battery by FREEZIN IT!!! YES FREEZIN IT. Put mother board in your freezer for no shorter then 10 hours ,taken it out once ever 2 hour for 10 mins to warm then back to the freezer again. This process will clear the CMOS battery.
Now its time to put all back together.
Follow your step backwards until you reach the point of installing your CPU.
Take a cue tip with some rubbing alcohol and remove the old thermal paste from the cpu and heat sink. Now add a tick tak size amount to you CPU and reseat it in its housing (notice the small arrow on the cpu and housing indicting the direction for the cpu to set.) tighten down retainting screws. and install the heat sink.
Finish the process backwards until your laptop is back together.
Turn your pc on and you should be good to go.
I further recommend backing up all data and reformating your drive.Also change any settings in you BIOS to its default levels.
I rate this process a difficulty of 5 out of 10
R.Lee
Tech Specialist
FutureTechPC Hardware Acceleration
Was this helpful?
Yes
No
Solution #5
posted on Aug 18, 2009
Not Rated)
kohonar
Rank: Master
Rating: 0%, 0 votes
Acer Aspire 5100 PC Notebook main problem is Connection Problem, Software Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
Was this helpful?
Yes
No
Solution #6
posted on Aug 08, 2009
Not Rated)
juanmdoy
Rank: Apprentice
Rating: 0%, 0 votes
I've tried removing the battery, and some other measures to no avail. What did worked for me is: after the the acer screen appears, I held the function key down [FN] while pressing the [F6] key off and on. If your screen flickers from blank to where you can see the screen, then this should work. Turn the computer off, then back on when the acer screen is displayed, press the [FN] key and [F6] and keep the blank screen. That is it, the computer should boot up and the your regular screen should be visible with mouse and keyboard function.
If you can get the screen to flicker with [FN] and [F6] your keyboard and mouse is still working.
Ps. I tried [FN] and [F7] first, then [FN] and [F6].
Was this helpful?
Yes
No
Solution #7
posted on Aug 07, 2009
Not Rated)
ulobein
Rank: Master
Rating: 70%, 16 votes
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
Was this helpful?
Yes
No
Solution #8
posted on Jul 04, 2009
Not Rated)
JRUDMAN
Rank: Apprentice
Rating: 0%, 0 votes
I have a Acer Aspire 5100 with no touchpad, keyboard and mouse. I've been working on this problem for a few days and tried all of the above except the freezer fix. I managed to reset the CMOS by shorting the J2 jumper in the near the SODIMM slots. Still didn't fix the 3 dead devices. I had encountered this problem after installing XP and while updating SP3 after a reboot killed all 3 devices. I'm thinking that the acer boot CD may do the trick. I also found you could boot from the CD by pulling the HD out. This is becoming a mission. If I don't find a boot CD soon I'll be getting a PCMCIA card.
Was this helpful?
Yes
No
Solution #9
posted on Apr 15, 2009
Not Rated)
cperman
Rank: Apprentice
Rating: 0%, 0 votes
hi,
I had the same problem. I fixed it and I hope it works for you. Remove the hard drive, then I put in the acer windows reinstall cd and booted from it. It loaded windows and as I got to the install windows screen, I picked the repair windows option. at this point I realized the keyboard was working. I shut down the laptop using the power button and reinstalled the hard drive. Notice I did not continue reinstalling windows. I booted up and everything worked. I couldn't beleive it. I thought for sure it was a motherboard problem. Hope this works for you.
Was this helpful?
Yes
No
Solution #10
posted on Feb 18, 2009
Not Rated)
gcreamer
Rank: Apprentice
Rating: 0%, 0 votes
I had a similar problem with the Ace Aspire 5100. So, I got a P2A 1080 PPA 1080 4 Port USB 2.0 PCMCIA Card bought in JR and Windows Vista recognized it. So, I was able to connect my wireless mouse and keyboard using an usb connection.
Good luck.
Was this helpful?
Yes
No
Solution #11
posted on Nov 19, 2008
Not Rated)
smythers00
Rank: Apprentice
Rating: 0%, 0 votes
I have precisely the same problem with my 5100-3123. I took it apart - a pretty involved task - and inspected my keyboard and mouse connection cables. Nothing was wrong so I plugged them back in again.
The good news for me was this got the keyboard working again, so there was some hope.
The Bad news, mouse was still offline and USB ports weren't working either. Plugging anything into the USB ports froze the system. I checked my device manager, it doesn't show any conflicts with the USB devices. It also did not show any mouse drivers or such present.
At this point, it's hard for me to tell if I can fix this with another mouse pad, or if the problem goes much further.
However, I think that PCMCIA USB card suggestion was top notch. Using one of those, I can grab a mouse and work around the problems (in theory).
So give your device cables another go... maybe they just became loose, or jolted out of poisition from dropping the laptop.
G'luck
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5100 PC Notebook
Questions and Unsolved Problems for Acer Aspire 5100 PC Notebook
Do you recommend Acer Aspire 5100 PC Notebook?
Answer
Answer
Acer 5100.  During a Full Restore this error message interupts the restore: (The... (More)
Answer
We are using AIM PRO This almost always happens with new users that when they get an IM they cannot... (More)
Answer
no power plug in power wire and nothing no bat light no nothing acer bl51
Answer
pci flash memory is not update i have got update cd but pci drive is not update
11 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 29, 2009
I have the same issue. One day I decided to charge my IPOD , so I plugged in the usb cable to my Acer Aspire 5100 Laptop and things went down the tube after that. My Laptop froze and there was nothing I could do but power it down. After that I re-started the computer but now keyboard/touch pads are frozen, there is nothing I can do. I also tried removing the battery for 24 hours but no effect. I am pissed at acer for not giving me any support on the phone. I guess Acer and all products are on my "no-no" list. Now I am thinking over removing the hard drive and restore the data as there is nothing i can do to get that bloody thing working.
Comment by Guest, posted on Jan 04, 2009
unusable usb driver for mouse
Comment by ricandom1824, posted on Dec 31, 2008
i have a Acer Aspire 5100 and one day went to use it and the keyboard mouse didnt not work. i tried hitting 'FN' and 7 but that didnt work because the keyboard didnt work. i also had my father(who is a computer tech) check it open it up and look for loose wires or any type of cable but he said everything was right. I checked on acers support which sucks and they said to take out the battery, keep it out 4 20min blah blah...iam sure if u have the same problem u know what they said. the only combo of buttons that do work are FN' left arrow and right arrow(to darken and brighten the screen) there is also a dent on the lower left part of the keyboard right between the 'FN' and windows butten. please if u have any info on how 2 fix this i would love to hear it...thanx god bless and happy holidays
-Dom
Comment by tommy_89509, posted on Dec 24, 2008
I have the same problem. I bought my Acer Aspire 5100-3357 from Office Max inFebruary 2008 and never had a problem until last Sunday. I turned onthe laptop and my mouse is frozen in the middle of the screen. I cannot even reload the restore disks or Windows again because I cannotuse the mouse or keyboard. I tried everything from a USB Mouse, abluetooth mouse, a usb keyboard and nothing. My USB ports will notrecognize any plug n plays like those.
I was thinking about buying another keyboard for the laptop on Ebay, but I think I'm throwing my money away???
I have not bought a PCMCIA USB card yet and tried that. I was hoping Icould find the solution. Everything else works, loads up to thedesktop, DVD drive works but I cannot navigate anything to reload.
Of course, my laptop is out of warranty and Acer will do nothing to help. Their support site sucks big time.
Any suggestions would be appreciated.
Thanks
Tommy
Comment by gitmodotcom, posted on Aug 09, 2008
usb ports, keyboard and mouse inoperable
Comment by tweed_bd, posted on Apr 01, 2008
I have ismilar proble like ajlar if any have solution then please let me know.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 5100 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
