WHEN TRYING TO REINSTALL THE ORIGINAL SETTINGS IT SAYS THERE IS NOT A HARD DRIVE ON THE COMPUTER OR IT IS NOT SET UP
  • 99 Answers
Did you replace a new hard drive? if yes,check the jumper settings,if you are using one ide cable only ,the jumper of your device,should not have the same settings one of them is the master and the other one is slave,but if you are using diferent cable thats no problem with the settings.try also to check the power supply of your device.insert it properly.
Posted on Mar 29, 2008
SOURCE:
I have a hp Pavillion dv800 with AMD microprocessor. i installed windows 7 and it was working OK but then some of the drivers were not so I formated the hard drive and tried a restore with the original...
Pull the hard drive, remove the battery AND the BIOS battery. Let it sit for 300 seconds. Then replace the BIOS battery and the main battery, but NOT the hard drive, then go into BIOS SETUP, and choose the default settings. Then boot to a bootable CD (such as Hiren's BootCD 15.2, or Parted Magic). Then set the boot options to NOT BOOT to the hard drive. Then reinstall the hard drive, and boot to your Windows installation CD, and reinstall the OS of your choice.
May 10, 2017 | HP Pavilion dv8000t Notebook
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Lost hard drive!
If you have the "System Restore" set of CD-ROMs that were shipped with the computer, you can use them to reinstall Windows to the "factory" settings.
If you no longer have those CD-ROMs, contact Fujitsu, and order a replacement set. $20 ? $20 for courier-shipping?
Nov 14, 2009 | Fujitsu Siemens Computers & Internet
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
Dell dimension e520 reinstalling the XP Media center
connect your hard drive to other computer and then have it clean by scanning with antivirus. and then copy the important files on it to the working computer. after copying the files thats the time to return back the original hardrive to the dell dimension and then reformat and reinstall the system again again. please use original operating from dell or what ever is applicable.
mlenavz
Jan 31, 2009 | Dell Dimension E520 PC Desktop
Acer Aspire 3680 will not detect hard disk. In command prompt where should be, there is
Hi there,from the sounds of it this lovely little excercise is due to the hard drive failure,either that or no OS - XP disk is dead or damaged.
If you have the original restore disks from the 3680.
You could try reinstall and test from there,If your contents were important then try to remove hdd take to another computer and see if the drive recognises on the other machine,
If it allows access ,copy all your settings and documents straight away because it could die shortly,hopefully not tho....
Once the back up of your docs and settings and hdd back in your computer then use the restore disk to revive your machine,
This process wipes the C Drive and does a complete reinstall of all the required softwares and in the correct order too...
It should take 15-20 min to load onto the machine and about 40 minutes to reinstall all the RESTORE to Factory Defaults Settings.
Just let it do this process from start to finish and it should eject disk when done and reboot by itself.
when it starts up again it will be back to the windows activation screen and the ready to start loading up if your have the original restore disc,
Once your happy with it and its working,
CREATE A RESTORE POINT
How do I create a restore point?
START>ALL PROGRAMS>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE<Select NAME this as
"FRESH INSTALL JAN 2009"
This will help you return to the point when everything was working,
If you should'nt encounter any more problems,
There may be a Hidden Partion on your hard drive that may allow you to restore from that.Then all thats needed doing is the bios settings will need to be changed to select the XP CD on bootup or the hidden partion on bootup then select save and reboot,It should be straight forward from there.
Just about finished,
Dont for get to do your windows updates for SP2 and then turn off the update functions.
And BACK UP the new install to DVD blank so you can restore
any other time you have issues
I hope this helps but that should cover itn for you,
If you need more help please let me know.
Thanks Misterdj
Jan 14, 2009 | Acer Aspire 3680 Laptop
Computer wont start
Have you tried doing a system restore? This will pretty much wipe the entire hard drive and reinstall the original factory settings and software. To get to the system restore screen turn the laptop on then as soon as you do that press the F8 key, then follow the instructions.
This again will reformat the hard drive and then reinstall the original system/settings, just as if it were out of the box.
Nov 13, 2008 | Dell Inspiron 2200 Notebook
I have tried to repair windows 2000 professional on my desktop (Dell Optiplex GX150). I misplaced the original W2000 cd that came with the computer. I tried to repair using a new W2000 pro that I bought....
You can do a full installation, just make sure you set it so it leaves the filesystem intact (no format) so the windows will get reinstalled but all your files are still stored in the computer. I have done that many times on my own computer.
Aug 06, 2008 | Computers & Internet
Disk boot failure
there are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
Apr 04, 2008 | Computers & Internet
Unlocking external drive
You may have the encryption set on the drive - meaning it needs a password to access the Maxtor. Is this problem on the original computer you installed the Maxtor or on a different machine? Either way try reinstalling the Maxtor software. If you do not have it you can get it online at:
http://support.seagate.com/rightnow/mini_software/otiii_mini.exe
Jan 03, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Open Questions:
WEBROOT TechnICal SupPoRt pHone ~II+[[18OO8-O31O69}} NumbEr u.sa//vs Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
Computers & Internet Logo
26 people viewed this question
Ekse
Alun Cox
