Question about OKI Office Equipment & Supplies
"%d dpi" warning on OKI C5600
I get a "%d dpi" warning every time I try to print something with my OKI C5600. Please help. Reinstalling driver didn't help.
SOURCE: does anyone know what is
According to the Oki service manual that problem is related to the fuser. The reference is that there's some media stuck in the unit, they recommend replacing the fuser but it's possible just reseating it with power off will allow it to clear the code.
Posted on Apr 21, 2008
falsafat
  • 31 Answers
SOURCE: On Oki C5600 printer with error message
Try this procedure, don't know if it will work on your models.
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
Posted on Apr 12, 2009
  • 628 Answers
SOURCE: OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Posted on Apr 20, 2009
  • 22 Answers
SOURCE: Machine flashing K Toner Sensor Error - how do I
See if this works - switch off at mains, pull black toner part way out, push back in, switch on again.
Posted on Feb 21, 2010
SOURCE: How do i solve fatal error 980
If you have 980 fatal error and have checked that there is no paper stuck in fuser or you have removed the paper and still have error, then you should contact Oki, there is a fix for this exact problem, if you contact them they will send you a patch which you will need to run on the printer. This will fix your problem
Posted on Mar 02, 2011
Strange clicking noise OKI C5600
it is not the toner it is the drum. just replace the drum and it will be fine. you may of noticed your printer has been printing a little streaky. i have had this problem with my c5600 and after i replaced the k drum (the noisy drum) it was fixed intill 4 months later when the blasted thing broke again
Jun 02, 2010 | OKI C5400 Laser Printer
OKI C5600 error code 411 says toner cartridge is empty (isn't)
Kedves Mindnyájatok!
AZ alábbi hibaüzenet jelenik MEG AZ OKI C5600dn kijelz?jén Minden szín? tonernél. Sot MEG AZ eredeti sárga-NAL van.
Chip cserével lehet orvosolni SEM a problémát. Eddigi javaslat volt: 4 db toner éS alaplap csere. Ennyiért pia con színes nyomtatót is lehetne mar venni. Tudnak segíteni? Van Valami praktikus javaslat a hibám orvoslására?
További Szép estét kívánok!
Lacika
Oct 26, 2009 | OKI C5650n LED Laser Printer
How do i put paper in the bypass feed of the OKI C5600 printer? I can't find the bypass tray or how to put thicker paper through the machine.
The bypass feeder or multipurpose tray as OKI call it is situated above the standard or 1st cassete paper tray.
It is usually hidden. Ther is a door door with an handle. Pull the handle to open it and then extend the tray.
For images and instructions on how to feed the paper, check page 13 and following pages of the User Manual you can download from here:
http://www.c5600.co.uk/library/documents/c5600/C56uEN1.pdf
Also, I leave you the link to the support homepage for your copier. On the left side of the page there are several useful inks (to download drivers, software and documents, how-tos, explanation of errors, etc.):
http://www.c5600.co.uk/index.asp
Aug 19, 2009 | Ricoh Aficio 250 Copier
Apr 20, 2009 | OKI C5500n Printer
On Oki C5600 printer with error message " Order k drum" and does not let me print. Can any one help how to reset and clear this message?
Apr 12, 2009 | OKI C5500n Printer
Toner warning
THE TONER CONTAIN NEED TO BE WASHED OUT WITH SPECAL CHEMICALS, PRINTS NEED MAINTNANCE, OVER FLOW CONTAINER MAY HAVE TO BE EMPTYED ALL SO, CORRORNA WIRES NEED TO BE CLEANED
DRUM MAY MAY NEED SERVICE ALSO
ROD
Feb 03, 2009 | OKI C5200n Laser Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
OKI 520 ELITE
Kindly check the DPI settings . May be more DPI this time.
Best Regards
Rafique
Feb 19, 2008 | OKI MICROLINE 520 Matrix Printer
1,654 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
