Question about Olympus EVOLT E-500 Digital Camera
E-500 lock-up My e-500 locks up when shutter button is pressed. It appears to lose power, but ISO reading is visible in viewfinder. Has anybody experienced this problem before?
  • hogger69 Apr 19, 2008
    same problem here. have to reload battery to look at pica taken and view the screen. but everything goes dead when i click the shutter button to ttry to take another pic.
  • Anonymous Oct 24, 2008
    same problem it stil is on even when i shut it off i have to remove the battery and turn it back on to see the menu and review pics but i cant take pictures its not even my camera its my schools and i dont know what or how it happened
Shutter speed too low and aperture probably set at wide open [3].
You will find that after two minutes the shutter will respond but you will get a blurry picture.
This setting is rarely used but you only learn from playing with different settings.
Olympus instruction manual needs to be in a better language for the beginner to learn.
Posted on Oct 12, 2008
Canon t3i will not fire
Have you got the camera set for mirror lock up. Check and disable if appropriate. When mirror lock is selected the first press of the shutter button moves the mirror up the second press fires the shutter
Mar 23, 2017 | Canon EOS 600D Rebel T3i Digital Camera
I had my D5000 for a month now, recently i noticed something with my camera. looking though the viewfinder only, whenever i focus (half pressing the shutter button), the view from the viewfinder moves up,...
Welcome to the real world of photography, using the viewfinder is a whole new experience in the crating of fine photographs. Aside from this what you are actually seeing is the VR turning on and locking onto the target, you should actually feel this happening as well (if you are holding the camera correctly) What you are experiencing is normal. Thank you for the excellent description
Jan 18, 2011 | Nikon D5000 Digital Camera
How do i turn the auto ISO off?
In the Basic Zone modes, you don't. The camera automatically sets the ISO in the range 100-800.
In the Creative Zone modes (P, Tv, Av, M, and A-DEP), press the ISO/Flash Exposure Compensation button (rightmost button in front of the top LCD panel). This will display the current setting on the top panel. While looking at the top panel or in the viewfinder, turn the command main dial (just behind the shutter release button) to change it.
Apr 14, 2010 | Canon EOS 40D Digital Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
The viewfinder of my minolta x700 is always black
Check if the mirror is locked or stuck. If the viewfinder is dark, it means there is something wrong with the mirror.
Feb 14, 2009 | Minolta Photography
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Will not take picture
Some digital SLR camera have a mirror lock and others have a viewfinder shutter In each case this will be a knob in the region of the viewfinder that turns. Check that this model has it and it has not be inadvertently turned. Then come back
May 21, 2007 | Nikon D70s Digital Camera
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamp lights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamplights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
161 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
