Question about Motorola Mobility MOTOROKR EM30 Cell Phone
There is some loose connection at my charger connection...we have to carefully adjust the connection till it starts charging and should not touch while charging....soo can u pleasee help me with solution at vinaychataraju@gmail.com
    Problem Solver:
  • 6 Answers
The best solution is to change the charging point socket whick will cost u around 250 rs.
Posted on May 12, 2010
Repairing Charging cord on Braun shaver cord
no--simply because there are live wire connections to the transformer that people will touch and then seek compensation for that carelessness
best if you junk it and simply buy a new charger
Jul 10, 2016 | Braun Syncro 7526 Electric Shaver
Display would not turn on. I have replaced the battery and still no display. Do I need the charging cord to get it going?
The battery charger is only used to recharge a low battery.
If the console does not light up after pedaling. connect the battery charger to the machine and then plug it into an electrical outlet.
If the console powers up, your battery is low and needs to be charged.
Leave the battery charger connected to the machine for 24 to 48 hours to charge the battery.
It is okay though to use the machine with the battery charger connected.
If that still does not work, check over all main cables for loose connections or fraying. Especially those to the battery and to the console.
Verify that the speed sensor is 2mm (about a credit cards thickeness) from the speed disc on the alternator.
Please be sure to disconnect battery cables before adjusting speed sensor or touching any other electrical components.
If anything else comes up we would be happy to assist you, contact our Tech Support Team at 888-713-2880 or visit us online at
www.sportsmith.net
Jun 20, 2015 | Stairmaster 3400CE Upright Exercise Bike
The charger is broken and i need another charger also the pieces of the charger is stuck where you are suppose to put the charger
You can charge your tablet through the USB port on your desktop computer. Just plug it in with the USB cable that came with your unit. It's slower charging but who cares?
Those pins are delicate. Be careful when inserting and removing.
The USB is designed to power on first and then the data is transferred.
Forget about taking it to a repair shop. The charges will be more than the tablet is worth and it's not likely they will have the part.
Dec 30, 2013 | Proscan 10.1-Inch Internet Tablet,...
Turns off right after startup chime lens does not retract
This can happen when you use a battery that is almost without charge. Please remove the battery and charge it, before placing it back. Then be careful not to touch the lens, till the camera has a chance to retract it.
After you place the battery the lens should retract.
If the battery is really charged. You should not think it is charged, because you had it on the charger till the light indicated battery full.
There is also a chance you stopped the lens while it was coming out. A sensor detected this. To avoid damage to the lens construction, the camera switched off automatically. Also remove the battery and after a few seconds replace the battery and switch on the camera. Careful you don't touch the lens again.
Dec 26, 2013 | Sony Cyber-shot DSC-H5 Digital Camera
Asus charger won't charge
Stop using that charger. I sounds like you have a break in the wire and when you hold it in the right position, the two pieces touch and current flows. Unfortunately the heat is probably being caused by arcing and is a potential fire hazard.
Apr 06, 2017 | ASUS Original 19v 3.42a Ac Adapter Charger...
How come my htc diamond is not charging
Either you charger is dead(internally)or replace the battery.Sometimes the cords connected to the charger is cut off(Unseen but appears when ran thru a DMM analyser).If the charger works with other units the charging input is internally loose and needs opening by someone who knows the insides of a really costly cellphone.
Dec 05, 2010 | HTC Touch Diamond Smartphone
I have iphone 3gs. Battery got drained yesterday(1st time it got drained) and i put it on charge., it was charging till morning. It chareged only half when i saw in the morning. Then i removed i connected...
sounds like your charger is bad..you need to replace it and if that doesnt help i would contact apple or your service provider for replacement options...apple is 1800myiphone
Jan 15, 2010 | Apple iPhone Smartphone
I Have an Acer Aspire laptop and evertime you plug in the charger it will show no signs it's connected and the laptop is now out of battery so it will not turn on at all. Even when my charger is plugged...
Please Please Please change your charger right away .. I Got 2 Acer laptop last week and both had same probelm ..if there would be any fluctuations in voltage from your adaptor it will fry up your laptop and you will be in big trouble. Please dont do any experiments on your adapter and change it right away. I Got one laptop last week and customer tried so many angles like you did and fried up his laptop's motheboard already.
Hope you will listen to my suggestion. new charger is not very expensive.
Good Luck !!
Sep 30, 2008 | Computers & Internet
It will not charge
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. click here Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. 5. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models. click here
Aug 16, 2007 | Nokia 6111 Cellular Phone
Motorola Mobility MOTOROKR EM30 Cell Phone Logo
52 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
