Question about Fujitsu Plasmavision 42" TV
I took the power supply out of my fujitsu pds4233w-h plasma monitor to get it repaired and now as I am putting it bacdk in I'm not sure where the heat sheild goes. I'm looking for a repair manual for this unit as well. thx in advance
4 Suggested Answers
  • 534 Answers
SOURCE: fujitsu plasma code
Try this website for free download:-
http://www.retrevo.com/samples/Fujitsu-TV-manuals.html
Posted on Jun 09, 2009
  • 534 Answers
SOURCE: 42 Fujitsu PDS4221W-H, no power
A user manual is available from this link:-
http://safemanuals.com/user-guide-instructions-owner-manual/FUJITSU/PLASMAVISION%20PDS4221-_E
Check for a hidden power switch under the lower left or right under corner of the screen, ensure it is ON (- not sure if this switch is fitted to your model, but it does exist on other Fujitsu models).
Fujitsu no longer support or manufacture plasma screen TVs - therefore no parts are available from them. [Fujitsu only serviced to board replacement level - very expensive].
The Fujitsu models (generally, after 4 or more years use) suffer from cracked solder joints on circuit boards (due thermal cycling stress).
See Fixya tips:-
"Fujitsu Plasma 42" random shutdown - continuous flashing red led".
Posted on Oct 28, 2009
ekcnoel
  • 998 Answers
SOURCE: I NEED A POWER SUPPLY
Try to check this link.http://www.shopjimmy.com/fujitsu good day sir
Posted on Aug 09, 2011
Looking for a power supply for a NEC PX-42XRA4 plasma tv?
Paul, Check the attached links, not much on this power supply.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
NEC TV Power Supply Board
NEC Plasma TV Repair Part Number Guide for NEC Hitachi Fujitsu Plasma...
Repair KIT Capacitors FOR NEC Plasma TV P506Y1 FOR Power Supply Ypsu J011A...
REPAIR SERVICE FOR POWER SUPPLY BOARD OF NEC 50XP10 50 PLASMA TV
Mar 08, 2016 | NEC Televison & Video
P50XHA10US plasma monitor dead no power..
Check and replace the main power regulator board as card basis. There is practicaly no repair to plasma display power supply boards.
Sep 21, 2013 | Fujitsu P50XHA10 50 in. Plasma Television
I just got a new power supply installed in my Fujitsu 50in. Plasma P50XHA4OUS and cannot get the sound to work, we've tried everything, please HELP!
Assuming the power supply is exact replacement and you did not have this before--check the speakers to make sure not turned off.
If using a cable or sat box make sure sound not way down or off both with the set and the box.
Last but not least if sound is there with a DVD---something somewhere is set to wrong position.
Apr 27, 2012 | Fujitsu 50 in. Plasma TV
I need to swap motherboards from fujitsu t.v how can this be done?
If you remove the back of the tv you will see where the boards sit, you will have a power supply, Decoder/signal board plus other boards that convert the horizontal and vertical signal.
Mar 06, 2012 | Fujitsu PDS4233W Flat Panel Television
Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
Jul 11, 2010 | Fujitsu P42HHA30ES (Bundle) 42 in....
See Fixya tips:-
Oct 28, 2009 | Fujitsu Plasmavision 42" TV
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
Fujitsu plasma monitor 42" - keeps going to standby.
It is the soft wear protection system error. You should asked for service.
May 11, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
Black vertical line 3inches in from the left on my fujitsu PDS4233W-H plasma screen
If the line is all the way from top to bottom, it could be your upper and lower buffer boards or your plasma display unit is bad. I suggest you contact a servicer for your brand.
Apr 01, 2008 | Televison & Video
Fujitsu Plasmavision 42" TV Logo
187 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
