Question about Logitech LX7 Cordless Optical Mouse
The usb receiver is connected but my mouse can't work
    Scholar:
  • 97 Answers
Is there a switch on the bottom to turn it off after use so the batteries don't die out so quickly? You may need to replace the batteries and learn to use that switch.
Posted on May 12, 2010
yooperbud
  • 8637 Answers
SOURCE: Wireless Gigaware 26-990 unable to connect
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 20, 2009
yooperbud
  • 8637 Answers
SOURCE: MS wireless notebook optical mouse 4000
Posted on Jan 28, 2009
leecom72
  • 4806 Answers
SOURCE: Wireless laser mouse stopped working. KB OK. Tried Everything
Under the mouse near the optical lens there should be a small connect button, press that and the button on the receiver too.
Also make sure the batteries in the mouse are new or fully charged.
Good luck
Posted on Jun 28, 2009
joe7379
  • 93 Answers
SOURCE: Laser mouse just quit working (red light is no
Sounds like you simply need to replace it as they are pretty finaky to fix. If it was dropped or jarred it may have dislogged the laster out of its holding spot in the mouse. But honestly it probally better off to just replace it.
Joe
thydzik
  • 86 Answers
SOURCE: Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Posted on Jul 21, 2009
Keyboard does not type
If all the keys on the keyboard have stopped functioning follow the instructions below to reconnect the keyboard.
This problem is likely to be a lost connection. The connection between the mouse and the USB mini-receiver or the keyboard and the USB mini-receiver can be lost due to several reasons such as:
  • Low batteries
  • Moving the USB mini-receiver from one USB port to another
  • Moving the USB mini-receiver to another computer
  • Plugging the USB mini-receiver into a USB hub or other unsupported device such as a KVM switch (your USB mini-receiver must be plugged directly into your computer)
  • Using your cordless mouse/keyboard on metal surfaces
  • Radio frequency (RF) interference of more powerful wireless devices such as:
    • Wireless speakers
    • Computer power supplies
    • Monitors
    • Cellular telephones
    • Garage door openers
Eliminate any problem sources mentioned above that might be affecting your devices.
Follow the procedures below to reconnect your mouse and keyboard.
  1. Make sure the USB mini-receiver is directly and securely plugged into a working USB port on your computer.
  2. Make sure the mouse is turned on. The on/off indicator on the bottom of the mouse should be green. If the on/off indicator is not illuminated, press and hold the red connect button on the bottom of the mouse until the on/off indicator is green.
    On / Off Indicator
  3. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your mouse. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  4. Quickly press the red connect button on the bottom of the mouse for 1 second, then release it. The power indicator will flash briefly and then turn green. The mouse is now connected to the receiver.
    Red Connect Button NOTE: Holding down the red button on the mouse for more than 2 seconds may cause your mouse to turn off instead of connecting. If this occurs, start again at step number 2.
  5. Move your mouse to see if the cursor moves. If the cursor follows the mouse movements, your mouse is now connected.
  6. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your keyboard. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  7. Quickly press and release the red connect button on the underside of the keyboard.
    Keyboard Connect Button
  8. You will hear a short beep. The keyboard is now connected to the receiver.
  9. Test your keyboard to see if it is working. If the mouse now works but the keyboard still does not, see Knowledge Base article 9144.
Dec 14, 2010 | Logitech Cordless Desktop MX3200 Laser...
Cannot get mouse to work
1.
If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2.
Restart the computer. This can resolve the problem, at least temporarily, so that other troubleshooting steps can be applied.
3.
Move the mouse or keyboard closer to the receiver
The receiver is the hardware that receives the wireless signals from the keyboard and mouse and communicates the data to the computer. Most receivers connect to a USB port, either directly or by a cable, but a few types of receivers connect to the PS/2 ports.
. Make sure that the keyboard and the mouse are within 100 centimeters (39 inches) of the receiver. If the receiver is attached to a cord, position it so that it is on the same level surface, close to the mouse and keyboard.
4. Replace the batteries with a fresh set of alkaline batteries and make sure they are correctly installed. If the mouse or keyboard is not working, then replace the batteries, even if the mouse/keyboard software indicate the batteries still have a charge.
Remove the battery cover to access the batteries. For keyboards, the battery access cover is found on the underside of the keyboard. When replacing the batteries look for the positive symbol (a plus sign +) imprinted near the battery compartment or battery cover. Make sure the positive end of the battery is oriented to the positive side of the compartment.
5.
If you have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert it into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
6.
Resync the wireless keyboard and mouse connections.
Resync the keyboard and mouse connections for receivers with a connect button .
Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers.
NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
Sep 10, 2010 | HP Wireless Optical Mouse
Wireless USB works, but mouse itself doesn't
Sir/Mam good day,
Is your mouse device also wireless? you need to resync it with it's receiver,
you may follow the methods below to make your wireless usb mouse works.
You need to press the button on your wireless mouse receiver, and make sure that the light on your wireless mouse
receiver blinks. But you need take note that some newer model of microsoft devices are permanently fixed to their receiver
and can't be reset. If your devices don't have a button, here's what to do:
If a dialog box appears on the screen in how many seconds, you need to follow the instructions from it. Or else, you need
to do this:
press and release the connect channel button on your wireless mouse, and make sure that the light from your receiver works
and the status on it's light is steady. If this happens then the synchronization is successfu. But if the problem is still
the same you need to repeat the previous steps once again.
As for the wireless mouse for notebook, this problem come out when the micro switch on the underneath of the mouse was not
released. You can use a pencil or anything with a sharp point to released it.
There are a lot of options why your wireless mouse receiver won't work, and a lot of solutions. Here's some of them:
*Try different ports on your computer, if the connection to some usb ports are not working you can connect to other ports
and see if it will work.
*And also the cables that are included with the wireless receiver, try to use another cables if the
device is still not working.
*If you're device is connected to a usb hub, disconnect it from the usb hub and directly connect it to
the available ports on your pc and see if it will work.
*When fixing this type of problem you need to have only one usb device
connected to your computer, which is in this case, your usb wireless mouse.
*When you have other usb devices, you need to
plug it out.
*If the methods mentioned previously still won't work, you need to reinsert your
wireless mouse batteries or install a new one.
*Another possible remedy to this problem is checking the interference, your wireless
usb mouse together with its receiver should be a distance away from anything that
transmits signals such as cellphones, radios or other similar devices. And also
any metal objects. because such things might interfere with the signal of your
wireless mouse.
* If the problem persists after doing all of the above steps, maybe it's time to update
your wireless mouse drivers, For installing latest driver update with your wireless
mouse, see the documentation that is included in your wireless mouse.
* If all of the methods above did not solve your wireless mouse problem. You can
connect your wireless mouse to another working computer to see whether the problem
lies with your wireless mouse or to the computer which your wireless mouse is
connected.
Final instruction:
If all of these methods fail, you better have your wireless usb mouse be check
by a professional computer technician in order not to further damage your device.
Hope this helps. Good luck and God bless
http://online-pcrepair.blogspot.com/
Jan 11, 2010 | Silver Jeans 1660-13SL Mouse
Jan 20, 2009 | Computers & Internet
Wireless mouse not working
The Mouse you got from Radio Shack, did it have a seperate USB receiver that you plugged into the USB port?
When Radio Shack checked it out at the store and it worked to me means that it should have a seperate receiver not associated with your keyboard.
Disconnect the mouse receiver from the USB Port and reinstall the software from the CD. When the program asks you to plug in the mouse receiver into the USB, do so. It should then work. If not, then use the following info to get the mouse to communicate with the mouse receiver.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 18, 2009 | Logitech Cordless Desktop S 510
A4Tech R7 problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
if that doesn't work try
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Dec 31, 2008 | A4tech R7-10 Mouse
Dec 24, 2008 | Computers & Internet
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
IBM Optical Mouse doesn't work
Nov 11, 2007 | IBM Optical Travel Mouse 2224P0480
Re: kensignton wireless mouse, connected but not working
have you checked the battries in the mouse as the battries that com with the mouse don't last long and have you pressed the connect buttons on receiver and mouse as somtimes usb power receivers loose connection on laptops try this one. hope this works
Aug 13, 2007 | Kensington Mouse-In-A-Box Optical Elite...
Logitech LX7 Cordless Optical Mouse Logo
136 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
