Question about Apple iPod shuffle 3rd Generation MP3 Player
What should I do during charging my ipod shuffle 3rd generation?..it should be swithc off?or turn on?. tnx
    Problem Solver:
  • 13 Answers
It really doesn't matter as long as you can see it in you itunes library then u know it's charging just keep one thing in mind read the manual to learn that ipod shuffle's and all ipod's have limited charging cycles meaning that someday ur ipod will die good luck
Posted on May 12, 2010
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
Ipod shuffle won't connect to itunes and is not visible in my computer
charge it up fully, or leave it plugged into the charger for about 3-4 hrs then try again. sometimes it doesnt recognize the device if there isnt enough battery power
Mar 08, 2011 | Apple iPod shuffle 3rd Generation MP3...
I was given an i pod shuffle as a gift from a friend but when i went to apple support the i pod had been disabled. how do i fix it so that i can put my own apple itunes on. thanks anne marie
To reset iPod shuffle:
  1. Disconnect iPod shuffle from the computer (if connected).
  2. Move the switch on the iPod shuffle to the OFF position. Note that when iPod shuffle is off, the green stripe by the switch is not visible. ht1655_1.gif ht1655_2.gif ht1655b_3.gif ht1655--4th_shuffle-001-en.png
    1st generation 2nd generation 3rd generation 4th generation
  3. Wait five seconds. For iPod shuffle (3rd and 4th generation), wait ten seconds.
  4. Move the switch to the play in order or the shuffle position. The green stripe will be visible in either position. For iPod shuffle (2nd and 4th generation), slide the power switch on (and you can see the green stripe).
Feb 24, 2011 | Apple iPod touch
My apple ipod has a restoration problem.
you have to use ipod reset utility.you can download it here..
http://support.apple.com/kb/ht1238
install it and just follow on screen instruction. after the process is completed, sync your shuffle to itunes.
after that your ipod shuffle would work as normal.
my concern is, dont ever try formatting again using format utility of windows, you might get the shuffle corrupted permanently.
Jun 27, 2010 | Apple iPod shuffle 3rd Generation MP3...
Unable to download programe
Try updating the firmware then try again.
Jun 07, 2010 | Apple iPod shuffle 3rd Generation MP3...
How to use an ipod shuffle charge
Use iPod Reset Utility to restore the following iPod models back to their factory settings when iTunes is unable to do so. The process completely erases all music and data and reinstalls the iPod software version listed below:
  • iPod shuffle (1st generation) - iPod Software version 1.1.5
  • iPod shuffle (2nd generation) - iPod Software version 1.0.4
download here
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
then install..
follow these instructions..
Using iPod Reset Utility
  1. Quit all running applications on your computer.
  2. Open iPod Reset Utility.
  3. Connect iPod to a USB port on your computer. Do not connect iPod to a USB port on your keyboard, or other non-powered USB hub.
  4. Click the Reset button.
  5. If prompted, enter an administrator name and password. Notice: Do not disconnect iPod during the reset process.
  6. When complete, quit iPod Reset Utility and open iTunes to load music onto iPod.
Jun 05, 2010 | Apple iPod shuffle MP3 Player
How do i charge my ipod shuffle 3rd generation when red light shows
You can charge the iPod by connecting it to the Computer using the supplied USB cable.
Good Luck!!!!!!!!!!!!!
Oct 19, 2009 | Apple 3rd Generation 1GB iPod Shuffle Pink...
I Pod shuffle (2nd. generation) won't hold a charge
Hold in the play button for 10 seconds to reset. If that fails:
iPod shuffle Software Update and Restore
Apple periodically updates iPod shuffle software to improve performance or add
features. It is recommended that you update your iPod shuffle to use the latest
software.
You can choose either to update or to restore the iPod shuffle software.
If you choose to update, the software is updated, but your settings and songs are not
affected.
If you choose to restore, all songs and data are erased from your iPod shuffle. All
iPod shuffle settings are restored to their original state.
To update or restore iPod shuffle with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software install file and follow the onscreen instructions to install the
iPod shuffle Update.
3 Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod shuffle software.
If you use the iPod Updater application and it doesn’t see that iPod shuffle is
connected to your computer, turn iPod shuffle off and turn it on again.
Mar 15, 2009 | Apple iPod shuffle Second Gen. Silver (1...
2nd Generation iPod Shuffle Wont Turn on and 3 orange lights sync
ALLOW IPOD TO RUN DOWN..BY LEAVING ON.THEN FULLY CHARGE.TURN ON AND IT SHOULD RESET ITSELF IF NOT LET ME KNOW.I WILL ADVISE FURTHER.RICHARDM69
Dec 04, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Orange light comes on ipod shuffle but no charge...
For first generation ipod shuffles : See this document :
http://support.apple.com/kb/HT1814
For the Second Generation of the Shuffle see this :
http://support.apple.com/kb/HT1407?viewlocale=en_US
If you cannot find what you are looking for in these articles, it is very likely your IPOD Shuffle will need service.
Aug 22, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod shuffle 3rd Generation MP3 Player Logo
149 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
