Question about Garden
The line breaks within minutes of use. Howshould the line be set from the spool?
    Sergeant:
    Champion:
  • 333 Answers
Is it old line? If so it could be brittle. Buy some new line
Posted on May 12, 2010
Testimonial: "It is a new line. I need the details of how it should be fed through the holes!"
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I don't know how to restring the weed eater
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
The string on my grasshog xp gh1000 4, feeds out within 5 mins. What am I doing wrong when I add new string?
Hello, W/D here.
Read all the way through this, with the spool in your hand, before you re-wind the spools. It will make much more sense!
Pull the spool off of the trimmer.
Look on the bottom of the spool. The decimal numbers next to the notches on the edge is your line size (e g. .080). If there are 4 notches, there will be different decimal numbers, indicating that your trimmer can take different line sizes.
Also on the bottom will be arrows, indicating the direction that you will need to wind the line.
Looking at the spool, you'll notice that it is actually 2 spools, and the divider between them has a slot in it. (This will be important in a minute). The section of the spool closest to the bump head is the outer spool, and the spool closest to the machine, with the flat side, is the inner spool.
Insert the proper sized line into the hole in the inner spool core about 1/8", and wind in the direction indicated by the arrows, until the line is just about even with the divider between the two spools, then place the line in the notch that is 180 degrees (on the other side of the spool) from the slot in the divider. When the line is in the notch securely, leave about a 6" tail beyond that, and snip the line.
Wind the outer spool in the same manner, but this time, the line will go into the slot in the divider, then into the notch, and also get a 6" tail.
Feed the tails into the grommets in the trimmer head, square them up, notches to grommets, and snap the spool in.
Push the spool in like you were bumping it to the ground (this frees up the advance for the spool).
Grab the two tails, and give a tug. The line will pull out of the notches and advance about 1".
It's a good idea to clean out the hole where tha spool fits onto the trimmer from time to time, and also to put some graphite dust in the hole every 8-10 times you re-wind the spools, just to keep the mechanism working freely.
Best regards, --W/D--
Feb 09, 2011 | Black & Decker Garden
Black&decker GH 1000 trimmer. The line breaks when spool is full
Try using a thicker line when using the thinner line it is good only for grass if you should hit fence or concrete it will eat it up and you will be pulling it out every 5 minites or less.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
Restring a Weedeater Max TE475Y
Google it,,,,you will find it.
Apr 27, 2010 | Garden
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
GL 315 strimmer chops the line up into small pieces and goes through a reel in minutes
the spool control teeth have worn out and is continuesly feeding line take out spool look at teeth in head if good replace spool if not need new head and spool
Jul 07, 2009 | Garden
Don't know how to rethread the line
Breaking off is a normal process. Set the centre of your line in the spool and wind the two strands in to the Spool, thread and re assemble. C
May 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
