Question about Motorola Mobility SLVR L7 Cellular Phone
I have a motorola slvr lc7 and my sd card slot is located on the back under the battery but how can I get the card to stay it won't latch
  • ladyt_11674 Mar 30, 2008
    yes, i've tried that but it stil will not click. Maybe its missing something that mskes it clickand stay in there
    Problem Solver:
  • 17 Answers
The latch that folds over the sim card needs to be pushed up toward the top of the phone to secure it. if you push it until you hear a click that means you broke something
Posted on Aug 11, 2008
    Brigadier General:
  • 7,752 Answers
You have to push the sd card into the slot till it clicks
Posted on Mar 29, 2008
Where is the sd card on a motorola bt60
Bt60 is a battery for several of our phones. Some of which may not have a SD card.
Typically the SD card slot is in the side of the phone, under the batter or near the battery. Look in your owners manual or on Motorola Support Find Answers Motorola Mobility Inc for instructions.
Mark
Motorola Support
Mar 01, 2015 | Motorola Cell Phones
How can i make a motorola razr v3i accepts sd memory card 4gb
    • 1 Hold down the "End Call" button for several seconds to turn the phone off.
    • 2 Remove the battery cover. Turn the phone over and push the clamp on the backside of the unit. The cover should slide up easily; remove it and set it aside.
    • 3 Locate the memory card slot. It is located directly under the battery under a black cover.
    • 4 Pull out the black cover gently to reveal the memory card holder.
    • 5 Slide and press the memory card into place.
    • 6 Replace the black cover on top of the memory card by sliding it back over the card and pressing firmly in place.
    • 7 Close the battery cover; place the cover on its grooves and push gently until you hear a click.
    • 8 Turn on the Motorola phone. If the memory card was installed correctly, you can save contacts and other data immediately.
Apr 11, 2012 | Motorola Mobility RAZR V3i Cellular Phone
Just got a motorola citrus and can't take picture without an sd card. Where does the sd card even go?
The SD slot will be located behind the battery compartment. Most of the time these phones are pre-installed with a micro SD card. If not, a 2G Micro SD card would be sufficient for most things. roughly 8-10 dollars.
Aug 26, 2011 | Motorola Mobility CITRUS Smartphone
I have a tracphone and i want to put that sims card in that motorola phone
The sim card slot is located under the battery. You have to remove the battery cover and remove the battery to find the sim card slot. Next to it there is a micro sd slot if you want to add extra memory to your phone.
NP
Jan 10, 2011 | Motorola Mobility ROKR E6 Smartphone
Sd card is apear unreadable when i insert to my motorola phone what should i do??
Hi, Please remove and re insert your SD card. Make sure it fit perfectly ob card slot. Then check the memory status on your phone. If still unreadable please use another good card to test on your phone to know the root cause. Still unreadable? The problem is on your phone Sometimes the interface between card and board get problem due to factory defect or misuse of card. In this case you need dissemble the phone to see the problem and get it repaired.
Dec 08, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Sd card format
Acording to motorola, The SLVR L7 is limited to a 1G micro SD card. Anything over this will not be usable in this phone.
Dec 27, 2008 | Motorola Mobility SLVR L7 Cellular Phone
My fone is lock and i forgot the password motorola slvr lc7 metro pcs
take the phone to a mobile service center and have them reset teh code for you.
Jul 01, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Where do you put the Micro SD card in a Motorola V3 Phone.
It depends on your carrier or phone model.
Verizon Wireless still uses the CDMA network. CDMA gets the phone user ID from a programmed chip hardwired to the phone instead of a SIM card.
Because of this, there is room underneath the battery cover, south of the battery on the right side of the compartment for a mini-SD card.
Other carriers such as T-Mobile, Cingular/AT&T DO use SIM cards to store user ID, so there is not room for a memory card.
I do know that the MotoRazr2 V9 from AT&T DOES accept Micro-SD cards.
But if you have a GSM carrier such as T-Mobile or AT&T, the Razr V3 does not have a card slot.
Mar 03, 2008 | Motorola Mobility RAZR V3
Slvr: Memory Card
look in your phone manual and look up to what size of expandable memory your phone can handle, for example a motorola SLVR L7 can only handle up to 512mb
Sep 23, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
