Question about Canon MF3110 All-In-One Laser Printer
There is a message called "Paper Jam". What can i do for this?
    Scholar:
  • 97 Answers
Look in your printer manual. It will tell you how to pull the paper out. If you can't see it in the front you can probably open it in the back somehow.
Posted on May 12, 2010
Hello I have a paper jam error message and there no paper in the paper path at all, how do I reset the message please Thanks in advance
Hello!
You can not reset the jam error.
If you are SURE that you do not have any paper at all, probably your machine have a broken sensor or a broken gate.
I advise you to call a tech.
See you!
Sep 05, 2011 | Gestetner DSc232 Copier
Tip
Paper Jams
The most common error message is the notorious paper jam message. You do a quick look and then determine there is no jam. What next? Well here is a tip that will save you possible a service call. If you find a sheet of paper that has jammed, look at it closely. It is all together as one piece or is there the tinest of pieces missing? It only takes a tiny piece to cause a jam error. Pull the print cartridge out and with a flashlight look inside the printer and especially at each roller and see if there is any hint of a piece of paper. Look closely because you can miss something. Next open the paper tray and make sure the paper guide is firm against the paper. This will cause a jam. Just drove an hour and a half this week for this issue. The paper guide was not up against the paper causing the jam. If you have a small vacuum I suggest you vacuum out the printer because there are times that the sensors can get covered with paper dust causing them to fail. Hope this helps!
on Oct 26, 2011 | HP Office Equipment & Supplies
I had a paper jam and cleared but I still get the paper jam message. I cannot see any evidence of paper.
Where was the paper jamming at? On this model printer there are several things that could cause a jam or false jam. You paper pickup roller or sensor could be be bad, The fuser could be bad and prevent the paper from pulling thru or one of the paper ath sensors could be failing giving a false trigger. If you would like to call us at 318-769-9040 we would be glad to help you.
Corporate Computer
www.ccl-la.com
Aug 17, 2010 | HP LaserJet 4 plus Printer
Erroneous paper jam message. Unit sat without paper or cartridge for 3 months. When it was plugged back in without paper, the paper jam error shows up.
it seems that the head cannot move from its initial position to the paper margin position. check for any objects in the paper path. Put a paper (not more than 220 gsm) in the paper tray and press eject button. Push paper to go inside the printer. It will come out with the paper or object in the path. If it did not give solution call the service call centre.
Aug 14, 2010 | Epson PictureMate (C11C556001) InkJet...
K eep getting message paper jam press select to continue x the jam has been cleared
the sensors that detect the presence of paper are either detecting paper that one cannot see, they are dirty or broken. if you have checked according to manufacturers specs on jam removal and still have a jam indication, that means a technician will need to be called to assist.
Apr 04, 2010 | Office Equipment & Supplies
Printer says there is a paper jam and there is no paper in there.
first thing you need to do is will do the overriding the error
1. open the pritner access door fo the printer
2. if the printhead or ink cartirdges already in center remove the ink cartridges and the printhead
3. If the printhead already removed close printer access door., Turn Off the pritner then after 10sex turn It own.
4. Now your pritner should detect no printhead installed not paper Jam., If you still recieved paper jam error without the pritnhead installed you need to have a printer replacement call kodak toll free number 1 800 421 6699 ext 05
5. Now if the message is pritnhead not installed., reseat the printhead and the ink cartordges then close the pritner access door., If your ecived same message paper jam., You need to replace the printhead you may also call kodak 1 800 421 6699, and have your free printhead replacement.
Most of the time overriding the error message solve the problem
Nov 17, 2009 | Kodak ESP 5 Printer
Paper jam message on HP C4599 when there is no jam
I had the same problem. I called HP and went through the steps they had asked me to go through to fix it. It took about an hour. Nothing worked. They offered me a replacement. I said no, and they offered me a $150 gift card for Staples.
Apr 10, 2009 | HP Photosmart C4580 All-in-One InkJet...
Paper Jam
because of your paper sensor is not working or jam
Feb 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
Canon MF3110 All-In-One Laser Printer Logo
85 people viewed this question
old marine
old marine
