Question about Sony VAIO PCV-RS510 PC Desktop
Sony does a weird thing where they make their master the 10 gb hd and the slave the 120 gb hd. i need it the other way around. how can i do this safely without corrupting my drivers and such?
  • Sony Master
  • 32,281 Answers
This is a normal practice of setting up hard drive partitions.
The operating system and programs are stored on the C Drive and the data files are stored on the larger D Drive.
If you still want to re-size the partitions, a program called Partition Magic can change the partitions sizes to suit your requirements without upsetting Windows operating system and your programs.
Posted on May 12, 2010
  • 93 Answers
Disk priority order is usually dependent on physical wiring of drives to mainboard.
My first thought is;
in mainboard BIOS check what order is listed & what options it gives. (ie. change cables around, swap order of precedence etc.)
Otherwise 'mirror' copy the drive it should boot on to the drive it does boot to save drivers etc.
Note this overwrites the target disk contents!
Want to install wd1200jb-75cra0 as slave drive in dell xps420 with vista operating system operating master drive. do i need a driver installed first before it will recognize the wd1200 as a slave?.
there is a jumper setting on the drive itself that determines master and slave. Look closely at it, there is always a diagram of the pins to connect or disconnect for master slave setup.
No longer needed with Sata drives...
Feb 18, 2011 | Western Digital Cavier SE WD1200JB 120 GB...
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
Installing 500 GB EIDE HD in a SONY PCV-RX560
what are the jumper setting on the hard drive. make sure the old one is the master and the new one the slave.
Jun 13, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
Need to know what the pin placement is if i add another hard drive on the same ribon? whitch hd. is master and whitch is slave?
The hard drive that you have your operating system on is the master, and the one for storage is the slave. Normally. The slave is the secondary drive. Hope this helps
06castwo
Jun 12, 2009 | Western Digital Caviar 40 GB Hard Drive
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Hard drive not working
hi im josh in cebu phils.Friend if that happens whrein your 2nd hdd dont detect. Try to use these solutions. Check first the jumper of the hardisk whether it is stated as slave or master. if 2nd disk is master the jumper should be in the master and if it is slave the jumper must be slave. or try to use another IDE cable. put them as both master the first hdd in first ide slot and your 8 GB 2nd hardisk in 2nd slot as master also. or try to enter bios setup utility then try to check or detect the both device.thats all good luck
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Hard Drive
Hi I use Maxtor HD's and IBM Deskstars also, one of my pc's has 4 500 gb SATA drives [not in raid mode] and have had some problems also.
If you are using 2 drives then one should be set as master and one as slave. Same thing goes for cd/dvd roms, master and slave, and use 80 wire ribon cables. If you are using just one drive and the settings in your bios, and master or slave and what drive boots up the machine.
if using only 1 drive set it to master [in SATA it does not matter you can leave them all as masters, and only if the cd.dvd's are SATA also, if not they have to be set up as master & slave, set the bios to boot from cd drive 1st 2nd is your HD and last is if you still use them a floppy. On boot with the OS CD in the drive boot the pc and it will start the instalation of windows, delete any partitions, format the drive [NTFS] NOT FAT OR FAT32, and you should be able to do a fresh instal. As with 2nd hand drives as they were used on another pc they have hidden files left on the drive [unless the person that gave it to you has prepared the drive to do a proper instal if not windows gives you the option to delete, create and format the drive, to be ready to continue to instal windows.
HTH
Zues
Dec 21, 2008 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Oct 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Sony VAIO PCV-RS510 PC Desktop Logo
99 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
