Question about Sony CDP-CE215 5-Disc CD Changer
The cd sounds echoing and skips on the last end of the disk. What can cause this???
    President:
  • 1,851 Answers
If this problem occurs only at this cd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. That way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 12, 2010
What causes CD-player to skip while playing disks.
There can be a couple of reasons that the CD player is skipping.
One is that the disk has fingerprints or dirt on it. (Carefully clean it)
Two, the lens of the player is dirty. (Try a CD lens cleaner)
If neither solution works, your CD player has given up the goods and requires replacement.
Hope this helps you out.
-Steve
Apr 22, 2015 | Audio Players & Recorders
Cd player skips. Tried cleaner disc. Still skips
they do not work generally, can try blowing compressed air in bay, but not a lot short bursts and not so it causes frost. then wait a min . Also make sure you have no scratches on disk. Can use brasso LIGHTLY to resurface a disk
Jan 01, 2015 | Audio Players & Recorders
Toyota echo 2002 cd player (without cassette, marked 31804) Radio works fine, but when a put on a cd, it reads it and starts playing... with no sound. Any ideas? Thanks a lot
well , as with all discs, old player will NOT play all CDs.
not even close.
first ask an old guy for CDDA disk or buy one from walfart.
then try that, only these disks work in all players.
other disks may or will not work.
like DVD-R, CD-R and any other recordable disks will fail.
that is the acid test, if the CDDA disk works (real audio disk)
works then the drive is ok, if not, its bad. simple as apple pie.
Nov 14, 2014 | 2002 Toyota ECHO
Cds skipping
More than likely the optical lense needs replacing.
Jan 04, 2014 | Marantz DR-6000 CD Player
I have a 2006 Mazda 3 and the cd keeps skipping to the point that Im not able to listen to my cds
Sounds like your cd player is dirty or the disk you are trying to play is scratched and not useable?
You can purchase a cd disk cleaner at any department store or office supply. All you do is play the disk and follow the instructions. Some come with a mix of alcohol & water and have small brushed on the disk itself to place the liquid and this helps clean out your equipment. Others clean without liquid.
Check the disk itself for scratches and try wiping it off with a lint free towel. After cleaning your cd player, try playing it again and if it still skips - replace the cd. If a brand new disck skips in your disk player after cleaning it then your lazer might need repair and I would recommend taking it in to a local stereo installation and/or repair shop.
Jun 07, 2011 | Car Audio & Video
When Palying a CD Music skips (Media Player)
Greetings my friend, regarding on your problem try to check or clean your CD/DVD ROM. Try to clean it with disk cleaner cause sometimes we forgot to cleam the important part of CD/DVD ROM its eye the one that reads all the dat in the disk. So try to clean it and play the disk again after you clean. Also try to clean also the disk you want to insert in your CD/DVD ROM in order to prevent this problem again.
Jun 16, 2009 | Computers & Internet
My cd player skips
Unplug the unit, remove the cover and clean the laser lens glass with a Q-tip. Spray a bit of window cleaner on one end of the Q-tip (over a sink), then use that end to clean the objective lens of the laser. Then dry it with the other end. Wipe Carefully!
Do not apply pressure while cleaning, wipe slowly and then reassemble the unit and test. This is a common problem on many laser-based products, dust and smog get inside the unit and cloud the lens, causing it to skip or not read at all.
Feb 24, 2009 | Sony D-NF420PS CD Player
CD Player Skipping And Spinning Backwards!
Clean laser first. Near the laser there will 2 / 3 adjustable pots. Mark location on them all first. Pick one (then another) move a little left or right and see if you can get it working. If all fails return them to original positions nothing but time lost.
Apr 01, 2017 | Yamaha CDC-502 5-Disc CD Changer
Static and skipping
You might need to have it professionally cleaned / diagnosed. The problem might not be a dirty reader, but a misaligned tray. Many trays, over time, become misaligned. Some more than others. Depends on your use and abuse of the unit. The issues generally happen towards the end of the tracks.
- OPTiC
DJ Pro Lab
1200s.com
Apr 21, 2008 | Technics SL-DZ1200 CD Player
Tascam CD-RW recorder
Get a cd lens cleaner. and clean the lens. This is a CD with a small brush on one of the tracks. Usually this will solve your problem.
Feb 18, 2008 | Tascam CD-RW750 CD Recorder
Sony CDP-CE215 5-Disc CD Changer Logo
54 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
