Question about Car Audio & Video
Install dual xd1222 into a 1993 dodge intrepid
How to install dual xd1222 into a 1993 dodge intrepid
    President:
  • 2,317 Answers
The best way is to get a stereo installation kit designed for your car. It will have the surround for the new stereo to fit where the stock stereo fit. Also, it comes with a wiring harness that you connect the new stereo to then it plugs in to the stock radio plug. Most local automotive stereo stores should carry them.
Posted on May 12, 2010
Dtc Code P2314
2002 Dodge Intrepid Ignition Coil Circuit Codes: Electrical ...
www.2carpros.com/.../dodge-intrepid-2002-dodge-intrepid-ignition-coil...
Aug 13, 2008 - 2002 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 130000 miles. Getting the following codes. P0353 P2302 P2305 P2308 P2311 P2314
What are 2002 Dodge Intrepid trouble codes PO442 and ...
www.answers.com > ... > American Cars > Dodge > Dodge Intrepid
What does the Error Code P0846 on 2002 Dodge Intrepid mean? .... Trouble code P2314 means: Ignition coil E, secondary circuit - malfunction Trouble code .
Oct 29, 2015 | 2002 Dodge Intrepid
How do you replace pit arm bushing in a 2004 dodge intrepid
Well it's a bit tuff , if I remember your air cleaner tubes got to come out, there is a lock that is between the two bolts , do one at a time , much easier, unhook outer tie rod remove the bolt for that side then remove it from wheel well , change bushing install then do other side
Sep 03, 2014 | 2004 Dodge Intrepid
Alterntor installation on dodge intrepid
Okay, installation for an Intrepid...what year and size motor please?
Aug 21, 2013 | Cars & Trucks
How to replace water pump 99 2.7
Hope this helps you....
Instructions
  1. Prepare the Dodge Intrepid
    • 1 Lay out a drop cloth underneath the Dodge Intrepid to protect the floor from coolant spills. Designate an area to lay out each part alongside its bolts and connecting hoses and wires. Use a drop cloth here as well, some of the parts will have traces of grease and coolant.
    • 2 Disconnect the negative battery cable, using a screwdriver to unscrew the clamp that secures the cable to the negative (-) post. Pull the cable away from the battery post.
    • 3 Use a jack to elevate the Dodge Intrepid and jack stands to shore up the jack. Release the pressure in the radiator by removing the cap. Take out the drain plug located underneath the radiator. Catch the coolant in a resealable container
    • 4 Use a grease pencil to mark on the timing belt its position in each pulley before removal. This will save time when reinstalling. If needed, replace the timing belt and skip marking the old one.
    Remove the Damaged Pump
    • 5 Locate the water pump on the Dodge Intrepid. It's mounted on the front of the engine block and connected to the radiator and various other parts through a series of hoses. It's rotated by the timing belt. Study these parts, as you'll have to remove them.
    • 6 Disconnect or remove the parts in front of the water pump, using an adjustable wrench. In the most common Dodge Intrepid engine--the 2.7L--you'll find, in order: the upper radiator crossmember, fan module, accessory drive belts, crankshaft damper, timing cover, timing chain and guide wires.
    • 7 Unbolt the water pump from the engine block, using an adjustable wrench. You may have to use a chisel to gently break the seal between the mount and the pump. Discard both the pump and the bolts.
    • 8 Clean off the mounting area with a shop rag.
    Install the New Pump
    • 9 Inspect the new water pump to ensure it's identical to the old pump and free of any metal splinters or debris.
    • 10 Arrange the new water pump on the mount. You won't need sealant for the o-ring on a Dodge Intrepid. Hold the water pump and o-ring in place as you secure it with the new bolts. Tighten them with a torque wrench to 105 inch pounds torque in any order.
    • 11 Install the timing belt and wires, using the grease pencil marks to guide you in installation. Install the rest of the parts in the order removed. The camshaft must be reconnected with a torque wrench at 125 foot pounds torque.
    • 12 Replace the radiator's drain plug and refill the radiator with the amount and type of coolant specified in your owner's manual. Release the jack and jack stands.
    • 13 Attach the negative battery cable to the post and tighten the screw on the clamp. Crank the Dodge Intrepid's engine and check for leaks. Then, close the hood.
Read more: How to Install a Water Pump in a Dodge Intrepid ' eHow.com http://www.ehow.com/how_4508707_install-water-pump-dodge-intrepid.html#ixzz29Q1ZC1uZ
Oct 15, 2012 | 1999 Dodge Intrepid
NECESITO, VER COMO VA LA CADENA DEL TIEMPO DE INTREPID 2.7 2000
2000 Dodge Intrepid 2.7L SFI DOHC 6cyl
Fig. After the timing chain is installed, the timing marks should be aligned-2.7L engine (click for zoom)
Espero que esto le ayude. Suerte, y recuerde calificar esta respuesta.
Nov 09, 2010 | 2000 Dodge Intrepid
How do you change the oil pressure sending unit on a 2001 dodge intrepid
Hello
I incloses a link for a replacemint part ypu will need a socket for this sender . un plug the wire from the sender place socket over the part turn to left to loosen, replace with new one , tighten with socket ,, install wire end
http://www.1aauto.com/1A/OilPressureSwitch/Dodge/Intrepid/1AOSU00002/185174?utm_source=google_base&utm_medium=comparisonshopping&utm_campaign=gb_api_nobr&utm_content=OSU
Jul 12, 2010 | 2001 Dodge Intrepid
How to install a 194 bulb in a dash of a 2002 dodge intrepid
  • HOW TO INSTALL A 194 BULB IN A DASH OF A 2002
Nov 18, 2009 | 2002 Dodge Intrepid
Wiring for the 97 Intrepid radio
Do yourself a big favor & buy the adapter plug for the harness, that converts your Chrysler harness to easy install of aftermarket stereo. Any autoparts or audio store should have them.
Jun 04, 2009 | 1997 Dodge Intrepid
2.7 99 dodge intrepid skips when warm
solid lifters? i could be wrong but i think they are hydraulic lifters. ive had quite a few of them not pump up when re-installing the valvetrain and cause a tick. pull off the valvetrain and check to see if all the lifters/tappets are firm with no squish. that might be your problem
May 06, 2009 | 1999 Dodge Intrepid
Car Audio & Video Logo
296 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
