I have a roper washer machine , I may have overloaded it , it will not go into spin now , in the spin cycle it adjatates
  • 52 Answers
It is most likely your drive coupling. This is a small rubber like piece that is positioned between the motor and the transmission. The easiest way to tell this is to look underneath the washer and see if you see pieces of something down there. Here is a picture of the coupling kit, so you'll know what to look for. If you don't see anything, you will need to take the case off the machine, then remove the motor. Then you can see if it's broken.
It could be the lid switch or the drive coupling. You should hear a click when you put the lid down and again when you open it. If you hear this, your lid switch is probably good. You can put a multimeter on it and test it for continuity to be sure. When you click it, you should get a reading.
Posted on Mar 29, 2008
SOURCE:
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
Feb 03, 2011 | Kenmore Washing Machines
Our whirlpool washers agitator doesn't agitate during the spin or wash cycles
I would asume you mean it does not adjatate during the wash or rinse cycles.If it fills and you can here the motor run after it fills/then it drains and does not spin and fills again for the rinse but does not adjatate ? I would guess you have a broken motor coupler ..Most shops will do that repair for under 100.00....If I had more info I could be more sure...anyhow if more info is needed just repost....I hope I help you if I did please give a vote...thank you good luck
P.S mod # helps so much
Feb 02, 2011 | Whirlpool Washing Machines
The agitate (wash cycle) does not engage-neither spin cycle
is it a top load kenmore washer?if so the motor coupler is broken,they brake if overloaded and just get old,let me know more-mike
Apr 16, 2009 | Washing Machines
GE WJSR2070B won't agitate
There is a drive block under your adjator. You must pull the adjator off. Get your fingers ( Man Friend LOL ) under edge of adjator & pull. You will see a plastic pat with screw in it . if you can spin with hand , replace it .
Mar 01, 2009 | GE WJSR2070B Top Load Washer
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
