Question about Kitchen Ranges
Kenmore Gas Range 362.75491990 Oven starts and warms to temp - then light blinks and F3 displayed with beeping. I replaced the oven temp sensor, but it still malfunctions. Could the control board be bad?
  • 10,515 Answers
Yes, this Model was Built by GE. Usually F3 on this Model indicate Oven Temperature Sensor. Using an Ohm's Meter, Test it for Continuity and it should Read approximately 1080 Ohms, if good.
If Oven Temp. Sensor is Good, then the Electronic Control Board is Bad and needs Replacement.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 12, 2010
Whirlpool electric range timer constantly beeps and displays E2-F3 I don't even use the oven I just want beeping to stop I press STOP which changes display back to clock, but soon it returns to E2-F3...
Hi
Thanks for using FixYa.
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
My Kenmore 790.95651001 locked door for cleaning and displayed an F3 and beeps will not unlock door
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 12, 2010 | Kenmore 46123 Stainless Steel Electric...
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Have a Kenmore gas oven. About midway thru bake cycle it flashes an F3 and beeps
F3 is a bad temperature sensor. Look in the top left or right of the oven for a short thin round metal piece sticking out of the back of the oven. Turn off the power to the range. Remove the screws,carefully pull the wires out through the front. Replace it with a new temp sensor and bake away.
Sep 26, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Display reads " -F3-
Replace the oven temperature sensor. Unplug the range. Open the oven. The temp sensor will be in the top right or left of the oven.A short metal piece about half the size of a pencil. Remove the screws,pull it out carefully. Disconnect the wire plug. Reverse this order to install the new sensor.
Sep 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
Continuous warning Beep & "F3" displayed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Jul 22, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
When using oven it beeps and displays f3
Could be one of 2 problems. Perhaps both.
Unplug the range.Access the control panel and unplug the ribbon connector from the control.
Wait 35 seconds and re-connect it.
If it continues to beep and code replace the temperature sensor.
Mar 15, 2009 | Kenmore Ovens
Kenmore electric range F5 and F3 warnings
May 13, 2008 | Kenmore 30169 Electric Single Oven
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
