Question about Krups Super Automatic XP 9000 Espresso Machine
Coffee beans keep getting stuck in the grinder on my XP9000 Krups. Is there an easy DIY method, can any parts be unscrewed by ourselves instead of having to lug it down to the service department? When purchasing coffee beans , how to tell whether it is caramilised or not? cos this machines does not like caramalised ones : (
4 Suggested Answers
SOURCE: Krups XP9000 fully auto unit will no longer grind
Perserverance...it's cheaper.
Also found a limit switch which i think is thermal so once removed the grinder is operational again!
Posted on Jan 27, 2010
SOURCE: krups xp9000 will not brew, but grinds beans.
I also have the same problem with my xp9000. The beans are grinding but no coffee is expressed.... Any advice????
Posted on May 30, 2010
SOURCE: My Krups xp7225 suddenly stopped
xp7225, the grinder in possibly plugged at the discharge,
you may have to remove the grinder to get it cleared-when doing so check the O-rings on the top plunger.
to disassemble start by removing the front trim. this is TRICKY, pull out a bit at the bottom and slide up at the same time it should release and you can access the shrews and remove the top, OYA remove the water tank and bean bin!
then remove shrews on top including under the the grate and the piston has a spring a the discharge shoot gently move it wile removing the 2 shrews holding the grinder in place, you may be able to gently lift the grinder up. wires are a bit long, place a rag or paper towel at bottom of pocket to prevent anything like shrews from falling though and you can remove the motor from the grinder by removing the shrews under it with a stubby shrew driver. BUT if the wires will not pull out enough..THEN you have to remove the sides and back.. remove by taking out the screws at the front and top leave the bottom and front in place..slide the back and sides together away from the back.....
open the cover over the wires MARK and record all wire positions unplug the the wire to to the grinder follow wires to find them.....if you have to untangle by removing the board USE CAUTION the connections are FRAGILE...up the spade connections first then lift the top of plastic and pull the board out and away!!! BE SURE TO NOTE WIRES there is ON wire diagram available !!!!
reverse to put things back together... GOOD LUCK
Posted on Oct 29, 2011
It always shows fill up beans but the beans container is full.. how to fix this problem for a Krups Xp9000
somewhere I read that there is a window /sensor that needs cleaned really good so it sees the beans
Jul 19, 2015 | Krups Coffee Makers & Espresso Machines
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
Xp9000 does not in form me that it has run out of beans, any help please , thanks
They only know that the beans is empty when it comes to compressing the grounds into a puck just before brewing. If the brew unit has nothing in the chamber to compress then it assumes you are out of beans.. Remove and thoroughly clean the brew unit and make sure grounds are exiting the grinder when the grinder is running.
Oct 19, 2014 | Krups Super Automatic XP 9000 Espresso...
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
Krups burr coffee grinder - When I push the power button it flashes on briefly and then stops. It has briefly ground some beans so it working to some extent. Any ideas what is causing the grinder to...
Empty the grinder and see if it will run with no coffee bean in it. Some times debris will get caught in the grinder because it got mixed with the beans from the factory. If it runs your good to go. If not then the mother connection are not solid and it will run off and on at will.
Oct 14, 2013 | Krups Burr Coffee Grinder
How do you change the blade? I bought a new one but can't get the old one off. Thanks
    • 1 Unplug your Krups grinder from the wall.
    • 2 Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.
    • 3 Put your safety gloves on and then grasp the blade of the grinder with your channel locks.
    • 4 Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.
    • 5 Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut.
Things You'll Need
  • Cloth
  • Safety gloves
  • Channel locks
  • Pliers
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Krups 203 Grinder
Krups xp9000 will not brew, but grinds beans.
May 14, 2010 | Krups Super Automatic XP 9000 Espresso...
GVX2 krups coffee grinder; how to open it?
I have the same issue. You need to take both dials off, then on the bottom, there are 4 tabs on the inside. Seperate the halves and you will see them. Towards the front and halfway back. Pry the halves apart enough to push the top towards the bottom and it slides apart pretty easy. The tricky part now is finding the replacement part. I have super glued my switch and I want to do something to try and repair it further. Maybe epoxy. I called Krups and they can't sell the part to me. I called one of their service centers and they can't sell the part to me. So, if someone knows where to get the part, I am all ears :)
Nov 25, 2008 | Krups Burr Coffee Grinder
Lots of disturbing noises, no coffee
It is is easy, if you know how to do it... as always
First take of the wather, trach bin etc,
Start with removing the cup wher the beans is stored, the adjustment knob for the mill is a tricky part. Remove it by bending out the side of the knob. Thereafter remove the screws from cup and those you on see on the top.
The front (silver frame) is removed by lifting it upwards, behind it you have 4 screws that has to be removed.
The last two screws is found under the wather tank.
Now you should had take away 11 screws, at least...
Bend the back of top and it will be off. Finally push the rest of the plastic cover backwards.
Do you know what the error codes says? I have know 6,8and no coffy...
May 11, 2008 | Krups Small Appliances Espresso Machine
Krups Super Automatic XP 9000 Espresso Machine Logo
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
