Question about Maytag SDE3606A Electric Dryer
Wont start won't start, plugged in & breaker is on
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryerwont start - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
Starter motor won't work
Try turning the eng over with a socket and breaker bar the eng maybe locked up
Mar 02, 2013 | Cars & Trucks
No lights upstaires circuit breaker keeps tripping
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
Jan 18, 2013 | Electrical Supplies
Why does the 30 amp circuit breaker behind the battery box on my 1990 fatboy click once when i push the ignition button? The bike won't start.
Try to reset the circuit breaker. also check for an earth fault on the starter motor .If this is not a circuit breaker and is a relay, you should make sure everything is ready for a start, (ie : in neutral, sidestand up and clutch in and that the battery is charged.) the neutral light being "on" doesn't mean it is in neutral. I hope this helps.
Mar 08, 2012 | Motorcycles
Our 2008 dodge charger wont start,and the radio wont work,checked all fuses/circuit breakers/relays,all good,but it still won't start-cam somebody-PLEASE help me???
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 05, 2012 | 2008 Dodge Charger
THere is no electricity in the bedrooms and I can't get them back on?
If the circuit breaker will not reset - all the way off and then back on with a click sound. Then something you have plugged into the outlets in those rooms is probably shorted causing an over current condition. If the circuit breaker won't reset, shut off all lights and then unplug EVERYTHING and then see if it will reset. If it does, then replug everything one at a time until the electricity goes off again, that is the bad apple.But if it won't reset, then your breaker is probably bad. Yes, they do go bad, just infrequently.
Jan 11, 2012 | CUTLER HAMMER BR4040B200V BREAKER CIRCUIT...
I have a bathroom Broan 504/505 vent fan. This model just stopped working. I have power to the unit but for some reason it wont work. I pulled the fan plug from the fan housing & used an extension...
the motor is prob rated for 120-140 volts if your only getting 110 there is the problem see what the breaker is putting out at the box the light will still work but the motor needs enough amps to start sounds like a voltage drop issue
Aug 06, 2011 | Heating & Cooling
TV wont turn on????
Some models may have a small little hole in the back to reset the TV if not I believe it may burn out on you.
Have it chec by your localTV repair man
Jun 29, 2010 | Philips 50PL9126D/37B 50" DLP TV
Upsizing breakers
In short - NO. 15 amp circuits are intended for lighting and outlets and usually have 14 gauge wiring. A 20 amp circuit is usually wired with heavier 12 gauge wire which can carry the increased amps. If you plug in a 20 amp breaker into a 15 amp circuit you run the risk of overheating the smaller gauge wire and starting a fire.
Dec 04, 2008 | Square BREAKER CIRC HMLN 15A SP
Maytag SDE3606A Electric Dryer Logo
59 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
