Mitsubishi WT-46807 No power on
When I press the power on button the power indicator turns on for a few seconds and then shuts off. I opened the back pannel and discovered that two fuses f9ao4 and f9ao5 on the switch supplies regulator board are blown.
  • 2 more comments
  • Adam Phillips
    Adam Phillips Mar 29, 2008
    I am an electro mechanical technician with a class D 2m soldering certificate. I have the service manual for this unit and was hoping to fix this myself. I was looking for advice on what components to replace and where to obtain said parts.
  • Adam Phillips
    Yes error code 22 short circuit protect is correct. The two ic's and fuses where can they be obtaied.
  • Adam Phillips
    Thank you for your help. I would have never guessed the horozontal and vertical convergence IC's would have caused these fuses to blow. I will order the parts from the manufacturer and let you know if the repair is a success.
  • Adam Phillips
    Adam Phillips Apr 18, 2008
    I finally got the parts to fix my TV in the mail yesterday and today I am watching TV. Thanks for all your help. I want to leave a rating of fantastic for the help on this problem but because it took so long to get the parts I don't think I can.
    Sergeant:
    Champion:
  • 277 Answers
You need a service technician to fix it.. its a power supply problem...
Posted on Mar 29, 2008
  • 3,037 Answers
Well, obviously you need to replace them. What exactly are you looking for us to help you with.
  • 5 more comments
  • Benjamin Patri
    Benjamin Patri Mar 29, 2008
    do you need to know where to get new fuses?
  • Benjamin Patri
    Pushing INPUT and MENU simultaneously has to give you a flashing LED
    code on the front panel. My guess is that it's 2 flashes, then 2
    flashes, then repeat. But you have to check for this code after it has
    shut down and it's still plugged in. If you unplug the set, it will
    erase the error code, and you'll get 1 flash, then 2 flashes, then
    repeat, which means the set didn't detect an error.
  • Benjamin Patri
    it needs 2 STK392-570 convergence IC's along with the fuses replaced
  • Benjamin Patri
    you can get them straight from the manufacturer
  • Benjamin Patri
    Main support number 800-332-2119
    this number should let you order the parts
    thank you and let me know if you need any further help
  • Benjamin Patri
    Your welcome, please don't forget to rate this solution, and good luck
  • Benjamin Patri
    Benjamin Patri Apr 18, 2008
    you can contact Fixya if you want to rate me as fixya and they should be able to help you out otherwise I did get credit although not directly from you.
    I'm glad it worked for you
My Mitsubishi WT 46807 will not power up. The green light on the front stays on for approximately 2 seconds and then goes out with no audio or visual. I tried unplugging the set for about 15 minutes but...
yes!
When you turn set on and power light goes out do the self check this set has.
On front of set when light goes out press and hold both the Menu and Input (device) buttons at the same time and hold both for at least five seconds and then release both.
Power light will blink a two digit error code like 2 blinks,2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means. Make a comment here and I will assist you.
SD TECH
Nov 27, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
When i turn it on it shuts right back off
Please do the self check this set has:
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 16, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 won't stay powered up.
try giving the back cover a thump it may be dry jointed..
Sep 14, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Power on, few seconds off
Took it to the landfill today. Thanks for the reply!!!
Jan 25, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807
MY FRIEND YOU HAVE A POWER SUPPLY PROBLEM AND MAYBE THE CONVERGENCE IC'S ARE BAD.THERE ARE A FEW TRANSISTOR IN THE POWER SUPPLY THAT HAVE TO BE REPLACED FIRST.
CAYPIANAN@YAHOO.COM
Sep 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Powering down
THAT'S CORRECT, YOU NEED SOMEONE WITH ELECTRONICS SKILLS TO FIX THIS PROBLEM. YOU HAVE A POWER SUPPLY PROBLEM AND I BELIEVE THAT THE CONVERGENCE IC'S HAVE TO BE REPLACED TOO.SO CALL AN EXPERT IT WON'T COST MORE THAN $350.00
Aug 25, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Power trouble
You need a multimeter to diagnos the issue. I have one with the same problem that i had gotten for free. I found that two of the fuses that are soldered to the middle board are bad... i have not tried replacing them yet but i will repost.
Apr 19, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
