Question about Ovens
Maytag Oven will not heat up
I have a maytag oven (model MGR4450BDW) -- when I turn it on, the igniter rod (excuse my terminology) lights up but the flames do not light up along the aluminum rod to heat the oven.
Any idea what it may be?
  • swade88 Mar 29, 2008
    coolguy008,
    I did notice that when I turn on my oven, while the igniter does light up, I do not smell any gas or it does not appear to be any gas flow along the aluminum rod running along the gas rod.
    Genius:
  • 3,422 Answers
HI,
The best solution is to call a technician and get it fixed.If you still want to try then you can follow the below steps.
If your oven is an electric range then please click HERE and scroll down you will find all the troubleshooting steps there.
If your oven is a Gas range please click HERE and go down you will find all the troubleshooting steps there.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 29, 2008
  • 3,037 Answers
Sounds like the gas valve may not be opening up
  • Benjamin Patri
    Benjamin Patri Mar 29, 2008
    Eliminate the gas valve first--Use a meter and connect the 2 wires off
    the valve to it.turn the oven on and you should either read 120v or 24v
    depending on the unit.If you have the voltage but no ignition the valve
    may be bad.However if you dont have the voltage i would suspect the
    heat board or thermostat as an issue.I would also check the
    pilot/burner for a clog from soot,even more so if the units propane.Let
    me know
  • Benjamin Patri
    Well with no gas smell, I would definitely say that it is a gas problem, most likely the valve, let me know whether you need any further help
6ya staff
SOURCE:
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
I have a maytag model # mgr5775qdw and the oven will not ignite. I know it is not the gas line as the burners all light, and the broiler lights as well. It is only the oven that does not heat. . .what...
This could be two possible problems. The igniter maybe bad, but doubt it. The igniter works both the oven and broiler, I believe on this model. The first thing I suspect is the switch in your wiring harness. The harness has a switch attached to it for each manifold. The switch for your oven maybe out.
Go to this site for diagram of parts: https://www.maytag.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10282172.pdf
Jun 18, 2011 | Maytag Ovens
Maytag Gasline Oven - everything works fine - range and brolier start immediately yet oven clicks but does not heat anymore. Was working fine but no longer heats.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 18, 2011 | Maytag CWG3100A Gas Single Oven
The broiler does not turn on in my Maytag free standing oven. The ignition light glows but no flame comes on. You can not smell any gas. Any suggestions?
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Jan 16, 2011 | Maytag Ovens
I smell gas when I turn on my oven. I replaced the gas line but have the same result.
Your Maytag wall oven is equipped with
pilotless ignition. Heat from the Glow Bar
ignitor lights the oven burner. With this type of
ignition system, the oven will not operate
during a power failure or if the wall oven is
disconnected from the wall outlet.
if it is plugged in and everything, your glow bar may be broken, which would mean you will either need to replace it, or get professional service.
Dec 25, 2010 | Maytag CWG3100A Gas Single Oven
I have a maytag pilotless ignition gas oven. the top burners work fine the broiler ignites fine. we just tried clean mode and its working too. the problem is we cannot get the oven to heat up. we turn bake...
Oven not Working or Oven not Heating
heatman101
Oct 13, 2010 | Maytag Ovens
Maytag oven does not light, glow bulb gets bright but burner does not turn on
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 21, 2010 | Maytag Ovens
Oven Stopped Working..
It sounds like the igniter. The oven is not getting a spark to turn on, and heat up. We had the same problem, but changed the igniter, and it works fine. Good luck!
Jun 02, 2010 | Maytag CWG3100A Gas Single Oven
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
166 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
