Question about Philips GoGear ViBE Digital Media Player
When turning on my gogear vibe i get this message on the screen "nabit a pienest" then it shuts off what dows this mean and how do i get my device to work
shadow83
  • 496 Answers
SOURCE: System File Error on Phillips GoGear Vibe
you should be able to put it into recovery mode by holding the volume up button while hooking it up to the computer after that you should be able to do a recovery on it using the software provided with the player
Posted on Dec 07, 2009
fathitkf
  • 1871 Answers
SOURCE: I connect my device(philips gogear Vibe 4g.)The
Hello :
1: Unplug your Mp3 player . 2: Restart system .
3: Plug the Mp3 player again . If the system didn't recognize Mp3 player this time , then :
1: Go to [ my computer ] icon on desktop .
2 : Mouse right click .
3 : Scroll down to properties .
4 : On properties click [ Hardware] .
5 : Click [ device manager ] .
6 : On device manager check if all [ USB ports ] are properly installed and working fine .
7: If there are [ question marks or wrong marks ] on the ports then they don't work properly .
This is what you need to do , if they don't work properly ;
1 : Right click on the none working ports .
2 : Scroll down to properties .
3 : On general click [ reinstall the previous program ] .
8f47b2d.png My computer icon .
Device manager
USB mass storage device problem [ not working properly ] . Here you should right click on the none working device then go to properties and then ,
f4d6255.jpg\
Troubleshoot .
I hope this will help .
rate please !
Posted on Mar 27, 2010
  • 16 Answers
SOURCE: how to fix power problem of GoGear Vibe 4G
UR MUM
Posted on Jun 06, 2010
SOURCE: taking apart a gogear vibe 4gb
I was trying to find a way to take this apart as well, because a soda exploded inside my car while I was away for about 6 hours, and when I came back it was covered in sticky goo, inside and out. After a little fiddling, it was easy to take apart and reassemble.
On the back, remove the barcode sticker, there is a single very small screw. Remove that. You will need a very thin-shafted cross-headed screwdriver. After its removed, take a razor and slide it into the small crack in the casing closest to screw housing, and pop the back off.
After the back is off, there are 4 more screws to remove, 2 black screws near the bottom, and two smaller silver screws on the top, one on each side of the LCD screen. You may need tweezers to remove the smaller silver screws.
After all 4 screws are removed, take your razor and slide it in between the top of the LCD screen and the casing and pop it out. Take note at how it is removed, because it needs to be reinserted the same way.
If you need to remove the directional pad, its a bit tricky. I used my tweezers to pop the two tabs on the left out, and then popped the rest out going clockwise. It takes some time and patience, because the tabs might pop back in.
There you have it. Not difficult at all.
Posted on Jun 18, 2010
  • 638 Answers
SOURCE: I have Phillips GoGear Vibe 8GB SA2VBE08K It is
Use a pen tip or other sharp object to insert the RESET hole on the side of the player.
Here is a page which shows you how to transfer music over to your new Phillips Media Player. Windows Media Player sync is specific to Windows products. Do NOT use this to transfer music to your Phillips media player. Use the software supplied by the manufacturer.
If this solves your problem, please come back and rate our solution. Thank you.
Posted on Dec 27, 2010
Testimonial: "Great! That worked. Thanks so much!"
What does file not supported mean on my gogear vibe and how do i change it
Your Philips GoGear Vibe supports these formats:
audio
  • MP3
  • PCM
  • ADPC
  • Audibl
  • WMA
video
  • SMV
audiobook format 4.
More support info:
Philips GoGear MP3 video player SA1VBE08K ViBE 8GB
Dec 16, 2013 | Philips GoGear ViBE SA1VBE08K MP3 Player
My philips gogear mp3 vibe sends the message "must
First of all have you loaded the gogear from the philips media converter and is the whole space filled up. In some cases there must be a space on the memory as the system may work very slow if the memory is full. Try and delete some files in this case. Also load only safe files that are scanned and has no malwares.
Hope you try this out.
Oct 19, 2011 | Philips GOGEAR SA6045 MP3 Player
Go gear vibe has been frozen for about 25 min. wont shut off or anything
Hi, i stuck a pin in the reset hole, (to the right of the lock switch) and it shut it off, than all you have to do is turn it back on..
The Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Memory Full
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
Hope it helped..
Have a nice day.
Feb 22, 2011 | Philips GoGear ViBE Digital Media Player
When I turn it on, my device freezes on "updating... 99%".
if you have songbird, go to the tools menu at the top of the screen and select "repair gogear vibe"
Nov 23, 2010 | Philips GoGear ViBE SA1VBE08K MP3 Player
When trying to listen to the book i just downloaded, it says "you need to activate device for the same account the title was downloaded for"
It means you are entering the wrong user ID...I got the exact same error message trying to use my GoGear ViBE 4GB with an audio book I got from audible.com, I contacted customer support and the problem turned out to be that I was trying to log in using the wrong user name example I was using "username" instead of "username@emailprovider.com" when I finally got my username correct it worked just fine.
Nov 05, 2010 | Philips GOGEAR SA6045 MP3 Player
My Gogear Vibe MP3 is frozen on the playlist screen. Won't change screens, won't turn off, doesn't do anything when you plug it ino the pc
Try Resetting it, by getting a sharp edge (something) and pressing the button on the left side of the device..if that doesnt work, try waiting for the battery to die, the reset, then try charging it again. Hope this helps.(:
Jul 11, 2010 | Philips GoGear ViBE Digital Media Player
My philips gogear vibe will not turn on. it is charged.
when i hold down the turn on button.it would show the philips lable then just shut off. can you help me please.
Jan 07, 2010 | Philips GoGear ViBE Digital Media Player
Error message File System Error
Whenever I go to turn on my Philips Gogear audio video mp3 player, it shows the welcome screen but it doesn't go to the GoGear or the updating screens. Also, whenever I plug it into my computer through the USB cord, the charging screen doesn't show and it does not show that it is connected on 'My Computer'
Aug 20, 2009 | Philips GoGear SA3125/37 MP3 Player
Philips GoGear ViBE  Digital Media Player Logo
248 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
