I have a syncmaster 740B monitor with ghosting problems. Have tried adjusting via the monitor controls, including reset & auto but to no avail. Resolution is set to 1280 x 1028, 32 bit. Other details on the display are: CX721B(Analogue)on WinFast A180 DDL. When using "Auto" to adjust the image ends half way up the screen & requires manual adjustment to bring it bacik nto view. I can live with that, but the ghosting is a problem. Any tips?
  • 2 more comments
  • pdwood Mar 29, 2008
    Thanks, but the Samsung syncmaster 740b is an LCD screen.
    The screen resolution is as recommended by samsung for their Syncmaster 740B screen so I'd prefer, at this stage, to sit with the recommended settings. Thanks
    Have adjusted the screen refresh rate from 72 to 70 & to 60Hz. No change to the ghosting .
    Apologies. i checiked the liniks and perhaps my problem is not Ghosting as i first described. We have a screen saver (blanik screen)thats operates after 2 minutes. The images on the screen are as if the image is repeated (faintly). Once the image is changed, those images disappear and are replaced with a blurring of the new image.
  • 99 Answers
Try to replace the cable connected to your monitor,may be there is only a loose connection.if you have another PC,try it to another pc.
Posted on Mar 29, 2008
    Genius:
  • 3,422 Answers
If monitors, especially older CGA / EGA monitors, are left on for long durations, the electron beams cause the phosphors to glow. If the electron guns continue to do this for thousands of hours refreshing the same images, this can cause the images to be burnt into the CRT surface causing a ghost image to appear. This image will become permanently displayed on your monitor for the duration of its life. A resolution to this problem are screen savers, which are programs that generate a random set of images, lines or other methods of allowing the image to not remain static while the computer is not being used.
While new monitors (VGA / SVGA) do not have this issue, screen savers are still commonly used today; you can find screen savers in the screen saver download section.
Also don't forget to look at these two important links they will help you solve your problem.
1)Click HERE
2)Click HERE
Goodluck,
Please don't forget to accept the best solution
  • 1 more comment
  • Priya darshan Mar 29, 2008
    Was that comment for me?If yes then did you check the first link which i gave you the remedy mentioned is for a LCD screen please click HERE
    Did you try my solution?
    Try removing the screensaver.If it is under warranty then immediately contact the manufacturer and get it serviced looks like the problem is internal not with the settings or screensaver.
    Sergeant:
    Champion:
  • 277 Answers
Hi
run display property and click advance,, then click monitor change monitor settings screen refresh rate...
    Brigadier General:
  • 6,966 Answers
Try with a lower Screen Resolution and/or a lower Screen Refresh Rate.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
How to fix Syncmaster 2494hs touch menu problem?
Have you tried doing a factory reset on the monitor? If the problem persists, then it could be an electronics fault or a stuck button.
May 11, 2014 | Samsung Computers & Internet
Does not turn on
Hello
With any monitor, check the following to determine if the issue is MONITOR related or COMPUTER related.
1. Verify the monitor is receiving power - use a known good power outlet and plug it into the monitor
2. Samsung monitors have a light on the power button - are you getting any color light from this? Orange means it is in "stand by" mode and is waiting for the PC to send it a signal. Green means the monitor is getting a signal from the PC and the monitor is on.
3. With the monitor on, press the buttons on the monitor to bring up the OSD (on screen display) that changes the monitor settings. If you have a green light on the power button and press one of these buttons (AUTO works best), this will display the monitor adjustment options on the screen.
If you see the on screen adjustments, your monitor is working and the issue may be with your PC. Move the monitor to another PC and verify the monitor is working correctly.
IF you don't see anything on the screen and the power light is green, the monitor has failed.
This could be the lights that illuminate the screen have failed (something that happened to my Samsung Syncmaster monitors after about 6 years of use) or the screen has stopped functioning. In either case, replacement parts are hard to find and a monitor swap is likely.
Nov 03, 2013 | Samsung SyncMaster S22B150N - LED monitor...
The auto-darken feature(monitor goes dark on dark
In your monitor panel you'll find 4 buttons. Press the menu button and get into Magic Bright. There you can choose the one that best suits you. You can even set to Dynamic contract where the monitor adjusts the brightness according to the elements on the screen
Jun 20, 2009 | Computers & Internet
Samsung SyncMaster 931BF 19" Monitor. Screen was working fine. But now after raising the resolution past 1280X1024, the screen wouldn't display anything. I tried it on my older monitor, a CRT. It...
This is because your screen is not compatible with any resoultion past 1280 x 1024. Look at your screen's specifications here: http://downloadcenter.samsung.com/content/UM/200602/20060210090838125_BN59-00521A-01Eng.pdf (Page 76 listed as Maximum resolution)
If you want to go past that, you must purchase and/or use a different monitor. Just be sure to look at the Maximum Resolutions BEFORE you purchase a new monitor!
Nov 25, 2008 | Computers & Internet
I have a Samsung SyncMaster 740B screen and it is flickering how to I fix this
Its probably the inverter board.It needs to be replaced. take it apart. and you will see a small circuit board.
Jun 11, 2008 | Computers & Internet
Samsung SyncMaster 712n monitor will have small blue & white tiny checkers on the screen. will go away if i click the mouse. sometimes the entire screen has those tiny blue & white checkers.
Surely the monitor lets you change it's 'standby' settings so that it doesn't show that; or change your computer's power savings modes not to include standby?
May 29, 2008 | Computers & Internet
My acer laptop with windows xp will not allow me to select the optimal resolution for my samsung moniter. How do I fix this?
The Samsung SyncMaster 730b is a 17-inch analog and digital TFT-LCD monitor delivering crisp, clean text and bright, vivid colors. This display offers a 600:1 contrast ratio, 300 cd/m2 brightness, 1280 x 1024 resolution, 160/160 degree viewing angle, scanning frequency of 30-81 kHz horizontal and 56-75 Hz vertical and 0.294mm pixel pitch
The SyncMaster 730b display offers the option of using either a digital or analog interface for viewing images and text. The Digital Video Interface (DVI) ensures a shaper, cleaner image and a more accurate representation of the original video source. Since video starts out digital in a PC graphics card, the digital output is directly interfaced to the digital input of the LCD panel and always provides the optimum quality image. In addition, no adjustments are required with a digital display, even when randomly changing resolutions. Input connectors for this display include 15-pin D-sub and DVI-D. Available in black, the SyncMaster 730b delivers a maximum of 16.2 million colors. The monitor is Windows Plug and Play DDC 2B compatible
The important stuff here would be the following:
(1) 30-81 kHz horizontal and 56-75 Hz vertical
(2) SyncMaster 730b delivers a maximum of 16.2 million colors
(3) 1280 x 1024 resolution
nVidia card settings should not exceed these monitor parameters. The monitor is not designed for more performance output without increasing liability toward failure. ?. Put your card settings, under the nVidia tab, at the following:
(a) Refresh rate set at 75 Hz
(b) Set colors at 16 million
(c) Set resolution slightly less than 1280 x 1024
It?s quite possible your monitor is at fault, but start with its optimal parameter settings for the display card first. The display card probably exceeds the monitor?s capabilities. Hopefully, this will stabilize your PC session and the blank outs cease if hardware is not faulty
May 23, 2008 | Computers & Internet
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Before we moved to a new house my samsung syncmaster 710v monitor was working fine but when I reconnected monitor to the cpu, no picture appears but green power led flashes and when i disconnect the...
First make sure all cables are tight and secured, and try pressing the Auto Button on your Syncmaster? It's for auto configuration.
If problem persist and if possible can you try using another known normal monitor/LCD? Also try your monitor using another cpu or laptop.
May 12, 2008 | Computers & Internet
Computers & Internet Logo
99 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
