Question about HP Pavilion dv6000z Notebook
Downloads sata driver - HP Pavilion dv6000z Notebook
    Problem Solver:
  • 8 Answers
Get Nvidia chipset drivers from here ...http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3224052
should have sata drivers
Posted on May 12, 2010
When I install Windows XP a sign tells me that finds no drive and cancel the installation
assume you are using a SATA hard drive?
Either the Hard drive is damaged (you can check this by accessing the BIOS at start up and seeing if it recognises the hard drive) or more likely, you have a SATA drive that you need the driver for. You can get this from the MSI site in the motherboard downloads section. You need to save this driver to a floppy or usb and when installing windows, and the prompt comes up to "if you have any scsi controllers..."... press F6 now" click F6 and let it find the sata controller, it should then install
Also check the condition of the sata cable..
Dec 29, 2010 | MSI K8MM-V Motherboard
I can't install my Operating System in SATA drive
What operating system?
If it is "XP"
Lie, tell it it is a "IDE" drive and watch what happens"
Feb 13, 2010 | Acer Aspire M3641 Dual Core E2200 PC...
I need sata driver for fujitsu siemens SCENIC P300
Here is link to fujitsu support for driver downloads. Hope it helpls.
http://ts.fujitsu.com/support/downloads.html
Good Luck
Nov 23, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
XP is Not Recognizing Sata H.D. and I Need a RAID Controller Driver
This one should be right for you, remember to put it on a floppy, since XP needs a floppy for a 3rd party driver during install.. good luck!
http://download1.msi.com/files/downloads/dvr_exe/sis_sataraid_floppy_mb.zip
Jun 02, 2009 | MSI 661FM3-V Motherboard
I have a problem on the hard disk which could not give power.
Hallow Dear,
____To understand the situation ____
Explain me how did you try to format your Drivers
(Most Common Error)
If you try to format & reinstall with winXP bootable CD (Witch is not injected SATA Drivers manually) Simply it will not identified your SATA Hard disk until you download & install manually SATA Drivers (pressing F 2 during installation to install Sata Drivers)
Use link below & select your System type and Model to Download SATA & other Drivers as necessary
http://support.acer-euro.com/drivers/downloads.html
Thank you & Best Regards
Dinu….
Dec 20, 2008 | Acer Aspire 5610-4648 Notebook
Please help urgent
hi.......
u can download them from http://driverscollection.com/?C=71 and u can find ways to install the sata drivers without a floppy at http://www.tacktech.com/display.cfm?ttid=414
Nov 21, 2008 | ASUS P5RD1-VM Motherboard
I have an Accer Extensa 5220 laptop which came with vista Home Edition. I wanted to down grade the OS to windows XP Pro. After formating the Hard Drive, I ran windows XP setup disk but keeps on giving the...
The problem of your laptop is the hard disk type. because acer 5220 laptop is using a SATA hardisk that automatic detected or supported by Vista. But in the windows Xp you need to download the sata driver for windows xp and save it to the floppy drive. In the beginning of windows installation press F6 to install another device or scsi the windows setup search your floppy drive for the sata driver and install it automatically. If you have cannot fix it just contact me i'm willing to help you
Apr 15, 2008 | Computers & Internet
Can not install windows xp
hubag, you need to check your bios. At boot up, press the delete key every 2 seconds & your bios will load. Make sure your SATA drive, (s) are listed example: {if your SATA drive is a Seagate the bios will show it as: ST3250823AS}. You should unplug any IDE hard drives connected to the system while installing Win XP. The Southbridge integrates a Serial ATA host controller that is SATA v1.0 compliant, supporting Ultra DMA 150 (SiS964 only). If you do not have your manual you can download it here at:
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=392&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
661FX-M(V1.0B)
Once the bios is set & see's your SATA drive so will windows.
If you can not set your bios to list your SATA drive windows will never install on your SATA drive. You can also use the above link & down load drivers, including a RAID driver.
Feb 21, 2008 | EliteGroup 661FX-M Motherboard
ASUS P5RD1-VM raid controller
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configur as boot from cdrom.
3. restart machin Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floopy insert when winxp setup asking F6 for additional driver.
Thank you.
YOGESH JADHAV
Sep 29, 2007 | ASUS P5RD1-VM Motherboard
Drivers
You have probably not installed sata/raid support floppy disc on the initial install of windows when prompted to press F6. You will need to find the make of the drive, then go to the manufaturer web site and download the HDD drivers to a floppy disc. The motherboard may also need the driver for sata/raid from the dell support site http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
May 22, 2007 | Dell Dimension 4600 PC Desktop
HP Pavilion dv6000z Notebook Logo
111 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
