Question about GoVideo Go Video DVD/VCR Combo
Go video DV2150
When insert DVD to play, whirrs a bit and comes up with bad disc.
We had someone staying here who may have tried to play a Taiwanese dvd disk - would this affect it?
Have tried resetting defaults with no result.
Any ideas?
/Thanks, Caroline
  • 4 more comments
  • CDV1905 Mar 31, 2008
    My govideo worked well but suddenly won't recognize any movie DVD. Will read video or music CDs but error message unknown disc comes up with DVDs. Can this be fixed or should I give up on it?
    Tried factory settings etc. but no luck.
    Govideo worked until this week. Now comes up unknown disc or clean disk and won't read or write to DVD. Will read video CDs and music but no movie CDs.
    Tried resetting and no luck.
    Any ideas or should I get rid of it?
  • Anonymous Apr 12, 2008
    Tje DVD disc whirs then the bad disc sign comes up and nothing will play!
  • Anonymous May 11, 2008
    Suddenly won't play any DVD. VCR works perfectly. DVD shows "loading" and I can hear the usual loading sound, but no disk actually loads, and sometimes a "bad disk" message appears. Tried resetting to default settings, but nothing changed.
    Won't play any DVD. VCR works fine. When DVD is inserted, the loading message appears, along with the usual loading sounds, but the disk never load and some times a "bad disk" message appears. Tried resetting to default settings, but that doesn't work.
  • sasibabu May 18, 2008
    dvd is in bup mode i want see the movie right now
  • GoVideo Master
  • 1,550 Answers
Compra un disco limpiador de lentes laser e insertalo en el dvd para que se limpie si no se soluciona llevalo a un taller para que le den mantenimiento.
Posted on Mar 29, 2008
Whenever a disc is inserted, the macbook pro whirrs for a bit then spits out the disc. This happens everytime a disc is inserted. CD and DVD
The laser head is full of dust, try to clean it. If that fails the entire optical unit will have to be replaced.
Aug 22, 2010 | Computers & Internet
'bad disc' error message comes up every time I
Your optical pickup drive lens is dirty or needs to be replaced.  Run a DVD disc cleaning kit through it and see if that helps.  If not, then you have to open this thing up and clean the lens with a bit of rubbing alcohol and then try.  If that don't work you can either kick it to the curb or replace the optical lens.
Nov 13, 2009 | GoVideo Go Video DVD/VCR Combo
HP dvd play on my laptop malfunctioning
grinding sounds is from the dvd drive itself. Sounds like its not sitting properly in the drive or the holder that it sits in is going bad. Either way replace the drive and that will take care of the grinding sounds. Also the more grinding sounds that happen, the more of a chance you take on your dvds getting scratches on them and going bad eventually.
Jun 11, 2009 | Compaq Presario Notebook
No matter what disc I put in it wont play and Bad Disc comes up on t.v. I know the movie discs are good ones.
Hello marciafoxmar,
If you know for a fact that the discs you are putting in, then there is obviously something wrong with the DVD player. When you put a DVD in your player, can you hear it spinning the disc at all? If your DVD is not even spinning the disk, I'm afraid your DVD player might be toast. If it does spin your discs, try a lens cleaning disc (available at pretty much any home electronics store or large chain store that sells home electronics). If that does not help, let us know and also let us know if you would be comfortable opening your DVD player.
Mar 02, 2009 | GoVideo DV2150 DVD Player/VCR
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
Go video DV2150 not working
Try using a lens cleaner. It could be that the lens is just dirty. If that doesn't work, it could indicate a problem with the optical assembly, which may result in expensive repairs.
Try the leans cleaning first. Kits are available in most stores. Should that not work, then shop around for rates from various repair shops, and if the cost doesn't warrant it, best go in for a new unit..
Nov 07, 2008 | GoVideo Go Video DVD/VCR Combo
Keeps flashing "Bad disc".....
Try playing a CD instead of a DVD, if the audio CD plays normally that means that the laser on the DVD side is defective. This devices come with 2 laser picks, one for CD and the other one for DVDs.
Apr 04, 2008 | GoVideo DV2150 DVD Player/VCR
Dvd player problem
get a dvd cleaner from best buy. mine did the same thing, it would not play any dvds so i resorted to vhs, and once i had watched all of those, i finally got a dvd cleaner and now it works fine
Jan 20, 2008 | GoVideo DV2150 DVD VCR
"Bad disc" message
You can buy a CD/DVD player cleaner, which is basically a set of brushes attached to a CD. This will gently brush the CD/DVD laser and hopefully that will restore your player to full working order.
Jan 12, 2008 | GoVideo DV2150 DVD Player/VCR
Dvd player
Go Video 2150 sayss Bad Disc. Then movie started and stopped.
Dec 17, 2007 | GoVideo Televison & Video
GoVideo Go Video DVD/VCR Combo Logo
119 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
