Question about Dometic Rooftop RV Air Conditioner
My 1990 Penguin unit has a leak. Can it be fixed?
My 1990 Dometic Penguin unit has a leak. Can it be fixed?
  • Michael Youngman
    Michael Youngman May 12, 2010
    Depends. Is it leaking from a pipe, a fitting, or a coil?
    Novelist:
    Champion:
  • 246 Answers
Leaks can be repaired, some quite easily and others while difficult to find - and get to - prove somewhat more difficult.
The problem with 'leaks' is sometimes they are 'high pressure leaks' which are some of the more difficult ones to find.
So... the answer to your question is yes - but.
I would try and get a very experienced Service Tech to fix the leak, and one who will stand behind his work.
good luck!
Posted on May 12, 2010
Dometic penguin air ac
either the fan motor or heat strip
Apr 02, 2014 | Dometic Rooftop RV Air Conditioner
I HAVE DOMETIC DUO-THERM PENGUIN ROOF AIR CONDITIONING ON RV. THE UNIT WILL RUN WHEN PLUGGED INTO ELECTRICITY BUT WHEN GENERATOR POWERED THE AC UNIT KILLS THE GENERATOR ENGINE. WHAT COULD IT BE?
What size & type generator? On start up the AC unit can draw as much as 17-18 amps in some cases, and if your generator is not designed for a quick draw like that it will die.
Jan 25, 2013 | Dometic Rooftop RV Air Conditioner
Duro therm , penguin 2 1988 model
ADDING FREON IS A LITTLE MORE COMPLEX AND BEST LEFT TO A PRO, YOU CAN MAKE SURE THE FAN IS OILED AND THAT THE FINS ARE CLEAN, TAKE NOTE IF YOU SEE A OILY SPOT ON THE UNIT THIS MAY BE THE SIGN OF A FREON LEAK ,, IT MIGHT BE WELDED AND RECHARGED .. THATS MORE BETTER THAN BUYING A NEW UNIT CUZ THESE AINT CHEAP ! JAY THE POOL PUMP GUY IN LONGWOOD FL
Feb 02, 2012 | Dometic Rooftop RV Air Conditioner
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
Problem w/ dometic penguin a/c. upgrade kit?
You know what, I have never ran into that yet in 15 years, so I think your best bet would be to go to, (dometicusa.com) and send then a quick inquiry to confirm, what would be required, they are usually pretty helpful believe it or not.
Aug 07, 2009 | Dometic Rooftop RV Air Conditioner
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
My Dometic 620315 Penguin roof a/c does not produce cold air.
If the compressor is running with no cold air the unit is more than likely no good. It can not be recharged. you need a new unit. If the compressor is not running you need to check the capacitors.
Mar 16, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
181 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
