Question about Canon imageRUNNER 5000 Copier
How to release the 004 code error - Canon imageRUNNER 5000 Copier
  • 231 Answers
This is a detected fault in the SSR
The Solid State Relay (SSR) has a short circuit, or the DC Controller is faulty.
The SSR is used to drive the heater circuit, and if a fault is detected, the copier is locked out for safety and fire prevention.
If you are not qualified, you should have a competent technician look at this.
Make sure you have fixed the fault before you think about resetting the error code.
After you have remedied the fault, and the device is safe, the error can be reset in Service Mode.
CAUTION
the error must be reset in Service Mode (COPIER>FUNCTION>CLEAR>ERR).
When you are sure it is properly repaired and safe, you can enter service mode by:
  1. Press user mode key (*) on the control panel,
  2. Press the 2 and 8 keys at the same time,
  3. Press the user mode key (*)
Be careful. Close observation will be required.
Posted on May 12, 2010
How do I fix error code 004-332
That error code signifies a developer home position sensor error. Can you move the carousel by hand? It also may be that a toner is leaking and has spilled onto the home position sensor.
Oct 04, 2014 | Xerox DocuPrint C525A Laser Printer
Error E0001 004
A E0001-004 is a fuser error code. You may have had a power surge and the copier got confussed and coded out. You will need to reset the error code in service mode. If it can not be cleared, you may have a problem with the fuser unit..... Good Luck
Jan 21, 2011 | Canon imageRUNNER C3200 Copier
I have a GE Universal Remote and I need the 3 digit codes for a Sylvania TV, a Sharp TV, and a Curtis Mathis TV. Can you provide these codes for me and the instrustion manual also?
There are two different lists of 3 digit remote codes for GE remotes. How old is your remote?
For a remote released before Aug 2002:
Sharp 004, 006, 012, 029, 095, 111, 112, 113, 122, 171, 173
Sylvania 004, 006, 008, 019, 062, 068, 069, 074, 075, 076, 077, 088, 116, 161,
183, 184
Curtis Mathes 000, 004, 006, 015, 105, 162, 171
For a newer remote:
CRT Televisions (only)
Sharp 004, 006, 009, 020, 063, 079, 095, 111, 112, 114, 122, 123, 124, 173, 226, 266
Sylvania 004, 008, 009, 062, 068, 069, 074, 075, 076, 077, 133, 135, 141, 161, 163, 189, 198, 227, 456
Curtis Mathes: 000, 001, 004, 006, 009, 015, 031, 049, 105, 109, 162, 171, 130, 358
LCD TV Sharp: 063
For combination units, please see the manual at the URL below.
The full code lists are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
I hope this helps.
(Note: the codes included in the remote are limited to those for TVs released 6 months or more before the remote was programmed. If your TVs are newer than the remote, you probably need a newer remote.)
Dec 04, 2010 | Televison & Video
Getting 004-332 restart error
Hi
Error code: 004-332
1. This type of error code implies that you need to restart the printer again.
2. However, do check to see if toner cartridges are seated in the proper position.
3. Also ensure that they have been locked in.
This is an error commonly associated with the Dell 3100cn laser printer.
Jul 14, 2010 | Dell 3010cn Laser Printer
Baumatic WQP12-9213 - Error Code 004?
hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Washing Machines
Dell 3000 0004-321 error code
code 004-321 Restart Printer will not shut of once I turn off/on the printer
Jan 25, 2010 | Dell 3000cn Color Laser Printer
Error Code E075-004 on a clc 1000 I have Re-position the transfer belt but I keep getting this error code and told to turn off and then on but the error keep commin back. I was also told that i had to go...
go to service mode by *2&8 * then you can release the error E075,Asterisk(*) button is in left side of control panel just lift the small cover .hope this will help
Jul 05, 2009 | Canon Office Equipment & Supplies
Error code 004-332 restart printer. Paper not
Check to see if your toner cаrtridges аre in the right position and locked in place. Then, stаrt the printer аgаin.
Jun 30, 2009 | Dell 3100cn Laser Printer
Code 004-332
Error code: 004-332
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
Dec 06, 2008 | Dell 3000cn Laser Printer
Lost owners manual and need to program remote to Panasonic
HRMC 15 Code Scanning method...
1.Press TV device button on the HMRC 15
2. Press Select and Mute simultaneously until TV device button flashes.
3. TV device Button should now stay lit.
4. Aim Remote at TV
5. Press The CHANNEL button UP ...repeat until your TV turns off.
6. Press Power Button to turn TV back on (Thus confirming you found the right code).
7. Press the TV device button to lock in code.
8. ENJOY !!!
Oct 22, 2007 | Hughes HRMC11 Remote Control
Canon imageRUNNER 5000 Copier Logo
125 people viewed this question
old marine
old marine
