Question about HP ProCurve 2626 (J4900B) 24x10/100 Mbps Networking Switch
How can I access and configure and manage hp 6262
How can I access, configure and manage hp 6262 switch .
    Problem Solver:
  • 10 Answers
Connect ur pc network cable to ur switch through ethernet port nd open hyper terminal of pc nd configure it similar to other switches>>>>
Posted on May 12, 2010
What is the default ip address for hp 2510-24 j9019B switch ?
Switches don't have an address, think of them more like a traffic intersection with 24 roads.
When you plug a device into the switch, that device gets assigned an ip address.
For example:
  1. Phone line comes in to your house and stops at your modem, your modem is plugged into the switch. The modem picks up the private network address 192.168.0.0
  2. Your computer is plugged into the switch. It picks up ip 192.168.0.1
  3. Your friends computer is plugged into the switch. It picks up ip 192.168.0.2
This carries on until you have filled all the sockets on the switch.
The ip's here are only on your personal network, to find what your external ip (your modem -> internet) is just type 'whats my ip' in the google search and it will show you your public ip address.
Nov 24, 2015 | HEWLETT-PACKARD Hewlett Packard HP...
Printer not printing first 3 left characters
There are 2 kinds of 6262 that have vastly different hammer asm, but most likely you have a hammer issue. If it is a 12 or 14 you would need
IBM 5665720 HAMMER COIL 6262 Refurbished
It can also be a cable or card, but those normally have errors reported.
PS I don't know why the wrong pick is coming up for that part on fixya, but the site has no pic as the part is super old.
Nov 04, 2015 | IBM 6262 Printer
Broken input
The Bugera 6262 takes a standard 1/4" jack -- readily found online, music stores, or even Radio Shack. If you can solder, this is a basic fix, but will require that you pull apart the amp a bit. If you don't feel comfortable doing that, then I would suggest sending it in for repair. Try finding someone local to do this, rather than shipping it to the Behringer repair center. Best of luck!
Apr 04, 2014 | Behringer Bugera 6262 212
How do i switch to windows wireless configuration utility
If you are using Windows XP, Vista, or Server 2003, you have an option in how your wireless network card is managed. You can choose to use your manufacturer's Configuration Utility software, or you can use the configuration software built in to Windows.
If you wish to switch between your manufacturer's Wireless Configuration Utility and the Windows Wireless Zero Configuration service:
1. Go to Network Connections (from the left panel of My Network Places)
2. Right click on the icon for your wireless network card, and choose Properties
3. In the Properties dialog box, choose the middle "Wireless Networks" tab
4. Check or Uncheck the box on the top that enables Windows management of wireless connections
5. Click OK
A reboot is recommended. If you are using any form of WPA or 802.1X security, you will likely need to reboot the computer before you will be able to access your wireless Access Point -- even if it is configured correctly.
Even when both the manufacturer's software and the Wireless Zero Configuration services are running, the Configuration Utility should detect when Windows is not managing the connection and give you access to its own configuration options.
Likewise, Windows should detect when it is not enabled to control the wireless network configuration, and disable access to the Windows configuration options.
Advanced Troubleshooting:
Before proceeding, be sure to download a local copy of the manufacturer's software and driver should you find yourself with a disabled network card and a need to reinstall the software.
A. If you suspect that Windows is interfering with your wireless network, regardless of the setting, you can disable the underlying service. If the Wireless Zero Configuration service is disabled, Windows will not be able to manage the wireless network -- regardless of any setting. To permanently disable the Wireless Zero Configuration service, click Start, Run, and input services.msc and press Enter. In the Services window that follows, find the Wireless Zero Configuration service, double-click it, and change the startup option to Disabled. Reboot. If you still have issues, uninstall and reinstall your manufacturer's software now that the Wireless Zero Configuration Service is disabled. It should set itself up correctly now.
B. If the Manufacturer's configuration software is interfering with Windows' management of your wireless card, consider uninstalling your Manufacturer's software. Windows only needs the driver in order to communicate with your card and manage the wireless network. Everything else is optional. Remove the software from Add/Remove programs. The uninstall program might give you an option to uninstall everything except for the driver, or it might have separate Add/Remove Program entries for the utility. If it does not, then reinstall the software using the local copy you downloaded and look for an option that installs only the driver.
Mar 12, 2013 | Acer Aspire 5536-5224 Notebook
Hi,this is pavan i want to b configure the HP procurve 2626 J4900B managed switch pls help me through anybody by giving the programme to configure it
What do you need it configured to support? Multiple subnets? VoIP support?
Here's an example to support 2 subnets, VLAN 1 Data and VLAN 2 Voice. This switch is the VLAN router for the site and it is also the default gateway for all the devices on the network.
show running-config
Running configuration:
; J4899A Configuration Editor; Created on release #H.10.50
hostname "HP 2650 dot 11 layer 3"
snmp-server contact "Your contact info here"
snmp-server location "Server Rack - Upper Switch"
time timezone -5
time daylight-time-rule Continental-US-and-Canada
interface 49
name "Uplink to HP2650 port 49 - 192.168.105.12"
flow-control
exit
interface 50
name "Uplink to HP2650 port 49 - 192.168.105.13"
flow-control
exit
ip routing
timesync sntp
snmp-server community "public" Unrestricted
vlan 1
name "Data"
untagged 1-46
ip address 192.168.105.11 255.255.255.0
ip helper-address 10.50.3.2
tagged 49-50
no untagged 47-48
exit
vlan 2
name "Voice"
untagged 47-48
ip address 10.50.3.11 255.255.255.0
tagged 1-46,49-50
exit
ip route 0.0.0.0 0.0.0.0 192.168.105.1
spanning-tree Always turn on Spanning Tree
spanning-tree priority 0 This switch is the master Spanning Tree operator.
password manager
password operator
Sep 20, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Hi, All our channel switch is broken, so
Try resetting up the printer whilst attached to that machine and reinstall the printer driver.
Feb 19, 2010 | IBM 6262 Printer
Trying to Configure HP ProCurve 2524 24x10/100 Mbps Networking Switch as DHCP and creating a VLAN and connecting Linksys access points to that VLAN
This switch will not function as a DHCP server itself. You will need to have a DHCP server on the VLAN with the access points to give out IP's to the wireless users.
HP has free design and configuration services http://www.procurve.com/customercare/services/design-center/index.htm
Feb 08, 2010 | HP ProCurve 2524 24x10/100 Mbps Networking...
The purpose of hp procure switch 2626
There is nothing special about these switches other than that they are managed. Managed means they have some means of connecting to them and "managing" them like you do when you configure a wireless router by going to some ip address in your browser to access the configuration. They usually are able to communicate statistics, set up virtual subnetworks, monitor ports, mirror ports, control which ports can access which others, set speed limits on ports, etc... A normal switch is "dumb", there is nothing to configure and it just does it's thing, connecting anybody and everybody that are connected to any of it's ports. Procurve switches are popular because they are great switches, there are other managed ones that can be had for much less, I use 48 port managed Linksys that have/exceed these capabilities for way cheaper... examples
Jan 28, 2009 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
How to assign IP address to HP procurve1800 switch?
The 1800 series do not have CLI so you should connect directly to any RJ-45 port.
I quote from the installation guide:
"In the factory default configuration, the default IP (Internet Protocol) address of the switch is 192.168.2.10 and the subnet mask is 255.255.255.0"
So set your PC IP address in the same subnet and access it through your web browser. If it has not the default configuration, interconnect the switch ports 1 and 2 and reboot it.
Hope this helps,
take care
AFO
Dec 31, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Desktop will not access internet
Your desktop and the internet don't belong in the same security context anyhow. Since you're using an HP, I assume you're running HP/UX; you probably just need to configure the Network Manager you've selected, typically using Tivoli Access Manager.
What exactly did you want to do to the internet, anyhow? You can often just log into a root domain proxy and accomplish a lot from there.
Otherwise, you need to know what you're doing first. Go to school.
May 30, 2008 | HP Computers & Internet
HP ProCurve 2626 (J4900B) 24x10/100 Mbps Networking Switch Logo
262 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
